problém naštartovať - C18XE
majo987
Mam taky problem ze ked nastartujem auto zdochne,otackomer vyskoci a hned padne - ked pridavam tak ide ale akonahle uberiem plyn auto zdochne a to iste co sa tyka otackomeru - ked motor bezi otacky ukazuje. Vyblikalo mi chybu 12-38-56-91
Ide o astru F c-18xe
edited by moderator
edited by moderator
palorep
- Dátum registrácie: 11 Feb 2006, 20:17
Tu mas kody sú sice v angline ale snad pomožu
podľa toho čo si vyblikal mas asi v prdeli alternátor vysoké napätie skús premerať kolko voltov dobíja.
12 Initiation of diagnosis. n/a
13 Oxygen sensor Open circuit
14 Coolant temperature sensor Voltage low
15 Coolant temperature sensor Voltage high
16 Knock sensor signal circuit No change in voltage
19 Incorrect Revs per Minute (RPM) signal (crankshaft sensor) Incorrect signal, check sensor
21 Throttle position sensor (TPS) Voltage high
22 Throttle position sensor (TPS) Voltage low
23 Knock control module signal Out of range
24 Vehicle speed signal (VSS) No signal
25 Injector valve 1 Voltage high
26 Injector valve 2 Voltage high
27 Injector valve 3 Voltage high
28 Injector valve 4 Voltage high
37 Check light (fault code lamp) Voltage low
38 Oxygen sensor circuit Voltage high
39 Oxygen sensor circuit Voltage low
44 Oxygen sensor Lean exhaust (weak mixture)
45 Oxygen sensor Rich exhaust (rich mixture)
48 Battery Voltage low
49 Battery Voltage high
52 Check light (fault code lamp) Voltage high
53 Fuel pump relay Voltage low
54 Fuel pump relay Voltage high
55 Engine Control Unit (ECU) faulty Check chassis earth and ECU connector.
56 Idle air control Voltage high
57 Idle air control Voltage low
61 Fuel tank vent valve Voltage low
62 Fuel tank vent valve Voltage high
69 Intake air temperature sensor Voltage low
71 Intake air temperature sensor Voltage high
73 Mass air flow temperature Voltage low
74 Mass air flow temperature Voltage high
75 Torque control (automatic) Voltage low
76 Torque control (automatic) Continuous signal, ignition retard long
81 Injector valve 1 Voltage low. Injector short circuit to ground.
82 Injector valve 2 Voltage low. Injector short circuit to ground.
83 Injector valve 3 Voltage low. Injector short circuit to ground.
84 Injector valve 4 Voltage low. Injector short circuit to ground.
87 Air Conditioning (A/C) cut-off relay Voltage low
88 Air Conditioning (A/C) cut-off relay Voltage high
91 Oxygen sensor heater Voltage high
92 Camshaft sensor Incorrect signal
98 Oxygen sensor heater Voltage low, open circuit
majo987
majo987
majo987
majo987
palorep
Tak to nieviem ked si meral to napätie tak to bolo nameraných 14,6 V pri volnobehu alebo zvýšených otáčkach pretože ono by sa malo od závislosti od otáčok a odberu pohybovať v rozpätí od 13,5 - 14,5 a kedže ty si nameral 14.6 tak to bude asi v háji alternátor a ešte ak budeš na budúce odpájať baterku tak sa nečuduj že ti odpáli altík resp diodový mostíkmajo987 napísal:Ale kde mam hladat chybu? potenciometer som meral a vypada to tak ze je uplne funkcny - co moze sposobovat to vysoke napatie
majo987
Bolo to namerane pri zvisenych otackach nakolko auto na volnobech nechcelo vobec ist . Ocictil som tie kontakty auto ide Ok ale z vyfuku smrdi benzin a vyblikal som tam tu 21 - auto islo OK aj bez lambdy
Vyhodilo to nespravna poloha skrtiacej klapky - Vie niekto ake napatie ma ist do toho potenciometra - lambdu mam odidenu :-( Dal som novu univerzalnu a nic
majo987
- spidy
- Dátum registrácie: 02 Apr 2006, 10:04
- Auto: Nemám auto
chlapi mam mensi problem s 92 Camshaft sensor Incorrect signal jednasa o motor c 18xel niesom si isty ale mam tusenie ze to je snimac vackoveho hriadela ale neni som si isty tak ma prosim uistite aby som sa nek vyvodil z omylu a juri kupil som si snimac od steva ale vyhadzuje mi stale chybo 92 sice on spominal nieco ze to je na motor c18xe je mozne ze to nepasuje na moje??? dal som to sem pretoze som nechcel tvoryt nove vlakno
- spidy
- Auto: Nemám auto
prave ze nie motor ide rovnako ako predtym akurat problem je ten ze aj ked som vymenil snimac ktory som zobral od steva naktorehosi mys dal kontakt tak aj napriek tomu svieti konrolka a po vyblikani je jedinbe kod 92 takze neviemn vobec co to moze byt i ked je pravda ze najrozumnejsie by bolo to dat na pocitac ale momentalne som vo svetom jury a tu neviem kam mam istiurai napísal:camshaft signal incorrect - nespravny signal snimaca vackoveho hriadela.
pochopil som, ze si snimac vymenil.
z akeho presne dovodu si menil ten predosly ?
zmenilo sa spravanie motora po vymene ?
