Strana 15 z 42
Napísané: 20 Apr 2010, 14:59
A aspoň zbežne si si prezrel aj toto vlákno?
Napísané: 20 Apr 2010, 21:13
od používateľa strano
Ake vlakno?
Napísané: 20 Apr 2010, 21:20
od používateľa dulo
Toto, celé, od začiatku tejto témy ohľadom OP-COMu
Napísané: 20 Apr 2010, 22:17
JAj to jasne, ze hej....aj som nejake odkazy snazil sa stiahnut, ale nefunguju uz, alebo mi to vypise nejaku chybu.
Napísané: 21 Apr 2010, 15:05
od používateľa swabel
Napísané: 21 Apr 2010, 23:27
od používateľa janda
Novy update
OP-COM 100315e
This version is the best - many new option but IT`S ONLY FOR LEGALL INTERFACE - NOT FOR CLONE !
Kód: Vybrať všetko
OP-COM Release 100315e - What's new
The vehicle list database is updated to MY2010. All of the control units of the new Astra-J is on
the list!
On-line product activation, Install the application, and within 2 minutes, you are ready to use it!
We strengthened our software protection, in order to make more robust, and yet user friendly.
Automated Internet based program update, with a click of a button!
Corsa-D EPS programming, and variant coding supported.
Astra-H, Zafira-B LUK Easytronic CAN Learn Gerbox Parameters, Clutch bleeding, Touch point
adaptation is supported!
Corsa-C, Meriva, Tigra-B Easytronic Learn Gerbox Parameters, Clutch bleeding, Touch point
Astra-H IPC Variant coding, and code index programming.
Astra-H ABS/TC/ESP Variant coding supported.
All of the currently available DIS, and EHU Code, Audio, and Temperature Index programming
is supported.
Astra-H/Zafira-B Speed dependant locking option programming in REC is now possible!
All of the currenty available UHP code index, and other programming option is supported.
Insignia engine code A20DTH full measuring block list added.
Insignia EPB (Electronic Parking Brake) measuring blocks, and adaptations are added.
Modified trouble code handling for the Vectra-C Z28xxx engines.
Improved compatibility for the Insginia, and the Astra-J with older interfaces (Rev. A, and Rev.
B).
New system driver for x64 systems (Vista, and Windows7).
Automated driver installer for both x64, and x86 systems.
Modified layout, now you can use any non-standard DPI settings in the Display Settings panel of
the OS. With older program, DPI settings other than 96 resulted problems in the screen layout.
Added trouble code descriptions for many control units, and corrected several small bugs.
Napísané: 22 Apr 2010, 07:49
Tak firma Autó M3 Kft. to mas uz na svojej stranke ako najnovsiu verziu
http://www.op-com.hu/Downloads_EN.aspx
aj "LEGALL INTERFACE - NOT FOR CLONE !" niekto casom prekona, tak uz len cakat a cakat....
Napísané: 22 Apr 2010, 10:27
Dakujem moc...Vrele vdaka
Napísané: 22 Apr 2010, 11:40
Za malo...
Napísané: 22 Apr 2010, 13:06
od používateľa Signum
swabel napísal:Tak firma Autó M3 Kft. to mas uz na svojej stranke ako najnovsiu verziu
čakame
Napísané: 22 Apr 2010, 17:46
Myslim, ze to nebude tak rychlo, aspon podla toho textu, ze zapracovali na lepsej ochrane. Ty z Vas ktory mate opcom dlhsie ako dlho ste cakali na spasenie?
service limit
Napísané: 25 Apr 2010, 18:36
od používateľa ceklis
caute jak mam nastavit servisni limit cez op-com na 10000km ??stale mi naskakuje 35000 alebo 18000 neviem to zmenitdik
Napísané: 25 Apr 2010, 21:44
A ake mas auto? Pridaj si podpis k profilu...
Napísané: 25 Apr 2010, 21:46
od používateľa kimino
tak ako swabel pise daj popis auta ale myslim ze servisne intervali sa nastavovaju bud na 30 alebo 50tis km :roll:
Napísané: 25 Apr 2010, 22:37
opel combo 2005 1.4 benzin
Napísané: 25 Apr 2010, 22:45
tak na benziny sa davali intervali 30tis km a myslim ze opcomom to tiez nezmenis
Napísané: 03 Máj 2010, 23:14
od používateľa leilak1
No som zvedavý čo dokáže viac nový op-com soft ak ho vyliečia mohli by vylepšiť tú komunikáciu aby sa dalo dostať v každom aute do REC a UEC programovanie ( astra H)
No ale o tom pochybujem ...
Napísané: 05 Máj 2010, 19:22
Na to som zvedavy najviac !!! :?
Napísané: 06 Máj 2010, 17:33
swabel napísal:Na to som zvedavy najviac !!! :?
no to je nas asi viac
zatial to len jeden manik rozpakoval ale sam nevlastni opcoma tak to nedokaze vyliecit a nikto iny sa toho este nechytil. Asi cakaju kym sa predaju stare zasoby a potom cinska ludova republika prispeje nejakym tym € na reverse engineering
Napísané: 07 Máj 2010, 20:25
Chlapi kde najdem nejaku verziu ktora je aj funkcna, lebo aj ta posledna co tu je tak pyta pomne registracny kluc. Existuje nejaka co by mi fungovala a nemusel by som si ju original kupit? Som si stiahol tu co tu dali naposledy OP-COM_090820d_EN-OK, ale ved aj taked chcem uz robit diagnostiku tak vypise ze musim zadat registracny kluc, alebo ze ju mam online aktivovat. Ja som mysle ze uz je to aj zaregistrovane, alebo aspon s generatoro klucov. Ak robim nieco zle tak mi niekto porad pls
