OPEL TIS a EPC
red baron
vedel by mi niekto nainštalovať EPC na W7 ?
mariaan1
Dátum registrácie: 30 Máj 2010, 10:52
Príspevok od používateľa mariaan1 »
ano skušal som to spustit aj ako admin, mam druhy profil ale vypisuje mi to to iste
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. Všetky práva vyhradené.
C:\Users\prestigio>SET PATH="C:\Program Files (x86)\Snap-on Business Solutions\G
lobal EPC\GM\jre1.6.0_02\bin";%PATH%
C:\Users\prestigio>c:
C:\Users\prestigio>cd "C:\Program Files (x86)\Snap-on Business Solutions\Global
EPC\GM\Configurator"
C:\Program Files (x86)\Snap-on Business Solutions\Global EPC\GM\Configurator>jav
a -jar Configurator.jar
2011-10-02 19:46:22,972 configurator INFO - ************************************
2011-10-02 19:46:23,347 configurator INFO - Configurator frameworkID=GM action=0
dbName=null
2011-10-02 19:46:23,347 configurator INFO - Configurator:configure
2011-10-02 19:46:23,347 configurator INFO - Configurator:configure Transbase
2011-10-02 19:46:26,092 configurator INFO - Transbase:configure service ports=35
4:357 ports=354:357
2011-10-02 19:46:26,092 configurator INFO - Configurator:configure Transbase:OK
2011-10-02 19:46:26,092 configurator INFO - Configurator:configure Tomcat
2011-10-02 19:46:26,170 configurator INFO - Tomcat:configure
2011-10-02 19:46:26,170 configurator INFO - ClientSettings:loadSettings:clientCo
unt=1
2011-10-02 19:46:26,170 configurator INFO - ClientSettings:loadSettings:OK
2011-10-02 19:46:26,170 configurator INFO - Tomcat:configure:configured:uptodate
2011-10-02 19:46:26,170 configurator INFO - Tomcat:configure:client count config
ured OK:ClientCount=1:ClentCountConfigured:1
2011-10-02 19:46:26,186 configurator INFO - Tomcat:configure:OK
2011-10-02 19:46:26,186 configurator INFO - Configurator:configure Tomcat:OK
2011-10-02 19:46:26,186 configurator INFO - Configurator:enumerate installed Web
Applications
2011-10-02 19:46:26,201 configurator INFO - Configurator:configure:WebApplicatio
n:GME:installed=false
2011-10-02 19:46:26,201 configurator INFO - WebApplication:configure
2011-10-02 19:46:26,201 configurator WARN - WebApplication:configure:total misco
nfiguration:installed=false:configured=false
2011-10-02 19:46:26,201 configurator INFO - Configurator:enumerate installed Web
Applications OK
2011-10-02 19:46:26,201 configurator INFO - Configurator:enumerate configured We
bApplications
bApplications OK
Products
2011-10-02 19:46:26,279 configurator INFO - Configurator:configure:WebProduct:GM
G:installed=false
2011-10-02 19:46:26,279 configurator INFO - WebProduct:configure
2011-10-02 19:46:26,279 configurator INFO - WebProduct:setVersionsStringAttempte
d : frameworkID= GM, productID=GMG, version='GME;4.16.1.482.51-O;|'
2011-10-02 19:46:26,279 configurator INFO - Tomcat:stopService:SBS_GM_TOMCAT6
2011-10-02 19:46:26,279 configurator INFO - Tomcat:stopService:OK
2011-10-02 19:46:26,451 configurator INFO - WebProduct:deleteWebProduct:removing
:GM:GMG
2011-10-02 19:46:26,451 configurator INFO - WebProduct:configure:removing:
2011-10-02 19:46:26,451 configurator WARN - WebProduct:delete:file is registered
but not exists
2011-10-02 19:46:26,451 configurator INFO - WebProduct:configure:removing:DsXml:
but not exists
2011-10-02 19:46:26,451 configurator INFO - WebProduct:configure:removing:JspCon
f:
but not exists
:OK
2011-10-02 19:46:26,451 configurator INFO - WebProduct:installWebProduct:install
ing:GM:GMG
2011-10-02 19:46:26,467 configurator INFO - WebProduct:installWebProduct:install
ing:webproductspath="C:\Program Files (x86)\Snap-on Business Solutions\Global EP
C\GM\Tomcat\webapps"
2011-10-02 19:46:26,467 configurator INFO - WebProduct:installWebProduct Module
:C:\Program Files (x86)\Snap-on Business Solutions\Global EPC\GM\WEBProducts\GMG
\GME\mace-core-201103.zip
2011-10-02 19:46:31,615 configurator ERROR - java.io.FileNotFoundException: C:\P
rogram Files (x86)\Snap-on Business Solutions\Global EPC\GM\Tomcat\webapps\PQMac
e\j\actions.js (PrÝstup je odmietnutř)
C:\Program Files (x86)\Snap-on Business Solutions\Global EPC\GM\Configurator>SET PATH="C:\Program Files (x86)\Snap-on Business Solutions\Global EPC\GM\jre1.6.0_02\bin";%PATH%
c:
cd "C:\Program Files (x86)\Snap-on Business Solutions\Global EPC\GM\Configurator"
java -jar Configurator.jar
ps: som vkoncoch ako teraz? :cry: :cry:
red baron
takže nikto nevie .......
KFL
Dátum registrácie: 20 Júl 2010, 10:09
Príspevok od používateľa KFL »
budem instalovat TIS aj EPC na Win7 64bit a dam vam vediet, ale zase tak rychlo to nebude
poznamka1: netreba to instalovat ako administrator, najdolezitejsie je spustit cmd.exe ako administrator a mozno aj ostatne baliky, uz si nepamatam
poznamka2: ked sa to dose..., tak je lepsie to uplne odinstalovat a nainstalovat znovu, niekde je tu moj prispevok kde spominam Perfect Uninstaller
viac vam poradit neviem, neviem kde mate zadrhel
mirek
Dátum registrácie: 28 Dec 2008, 12:25
Auto: Zafira A
Príspevok od používateľa mirek »
http://sk.fotoalbum.eu/cvrcek/a650269/00000001
Ahoj podarilo sa niekomu rozbehať EPC-ko pod W7 ?
Prešiel som na original Windows 7 s XP-ka.Predtým mi to šlo teraz si s tým neviem rady už týžden sa s tým trápim./som amater v týchto veciach/.
Vie niekto pomôcť prip.podať nejaký postup ?
EPC je origo na CD./dosť ma to štve že to nejde vzhľadom na to že som za to zaplatil dosť veľa./
Dík za každú radu.
Opel Zafira 2,2 DTI 2004
Y22DTR
KFL
My sa tu bavime uz o verziach 4.x, ale urcite ti nejako poradime, len nam musis napisat konkretnejsie otazky, napr. nejaky vypis, screenshot, ...
Su 3 veci, kde moze byt zadrhel:
1. instalacia
2. konfiguracia (posledna cast instalacie) - zaverecne nastavenia sa z roznych pricin nevykonaju spravne
3. prevadzka - nekompatibilta s novym IE alebo jeho nastaveniami
mirek
Auto: Zafira A
Jasné som si toho vedomý ale ako som spomínal mám cd zakúpené a bol by som veľmi rád keby sa mi to podarilo nainštalovať.
Pri inštalacii my na začiatku zahlási :
Aborting due to one or more errors during the installation procedure.Please contact your support specialist for more information.For additional information,check the loglifeat:C:/ProgramFiles/CommonFiles/BHPS/bhupdate.log
Y22DTR
KFL
Super! Takze instalacia je problem. Teraz si treba precitat, co je napisane v tom subore bhupdate.log :) Tam bude napisana pricina, kde a preco to zlyhalo. Skus ten subor najst a nahrat ho niekde na internet a potom sem daj link na stiahnutie.
mirek
Auto: Zafira A
OK tak po 14 hod.som doma s práce pozriem a dám hneď vedieť.
Y22DTR
mirek
Auto: Zafira A
Takže v súbore je toto:
[13-Oct-11 15:10:06] *****************************************
[13-Oct-11 15:10:06] *** PRODUCT INSTALL ***
[13-Oct-11 15:10:06] Current values, RAM: 1024 MB, Screen: 1920x1080, Platform: UNKNOWN (build 7600)
[13-Oct-11 15:10:06] JRE version: 1.4.2_03-b02
[13-Oct-11 15:10:06] ERROR, InstallCommon.initProgram(), getOSPlatform() failure
[13-Oct-11 15:10:06] >>> Aborting the installation due to one or more error(s) <<<13>>> Aborting the installation due to one or more error(s) <<<
[13-Oct-11 15:34:23] --- Installation End ---
Y22DTR
Rasto
mirek napísal:http://sk.fotoalbum.eu/cvrcek/a650269/00000001
Dík za každú radu.
Myslím si že Ti to už nepôjde a je to už veľmi stará verzia ..... . Skús to rozbehať cez Windows virtual PC - Windows XP mode.
mirek
Auto: Zafira A
Vedel som že pokiaľ prejdem na W7 tak mi to nepôjde ale že až takýto bude problém to som nečakal.Informoval som sa či nieje novšia verzia EPC-ka /kompatibilná s W7/žial nieje.Pre väčšinu nieje problém posťahovať to s kade tade kopirovať a robiť všelijaké tie úpravy pre mňa ako amatéra to problém je.Pokiaľ by existovala novšia funkčná verzia radšej si kúpim nainštalujem a idem bez problémov.
Ináč Rasťo možno troška podrobnejšie by som potreboval vedieť ako to skúsiť rozbehať cez virtual atď.
Dík
Y22DTR
Rasto
Jednoducho - pod win7 Ti beží winXP a v XP môžeš používať soft ktorý nejde pod win7. Legálne je Windows XP mode k stiahnutiu zadarmo s win7 profesional a ultimate. Viac na webe, nie som PC špecialista :lol: .
VeCeZ22YH
Dátum registrácie: 18 Okt 2010, 19:08
Príspevok od používateľa VeCeZ22YH »
EPC4 funguje len neviem nainstalovat Image Plug-In .resp som to asi nenainstaloval spravne. nedaju sa mi prehliadat obrazky. mal s tym niekto problem?
pozn. moze to byt prehliadacom? vsetko mam aktual v MoFi
VeCe 2.2 16V direct sedan
KFL
EPC obrazky vo Firefoxe ani Opere nejdu, lebo ImagePlugin je urceny len pre IE.
KFL
mirek napísal:[13-Oct-11 15:10:06] Current values, RAM: 1024 MB, Screen: 1920x1080, Platform: UNKNOWN (build 7600)
Napada mi niekolko moznosti:
1.Skus najskor nainstalovat aktualnu Javu - www.java.com
2.Virtual PC XP mode - legalne pre W7pro a Ultimate, ale malo by sa to dat rozbehat aj na HomePremium.
3.virtualne XP - pomocou VMware a pod.
4.pozret instalacne DVD, ci sa neda vypnut kontrola OS a vnutit mu instalaciu pre XP
5.niekedy pomoze Run in Compatibility mode - vsetky potrebne subory treba takto nastavit (skusenost s HP ovladacmi, na W7 sa z vysoka vybodli)
6.ked to inak nepojde, skus EPC4 podla tu spominanych navodov ;)
buci_vectra
Co som sa docital inde, tak EPC3 pod WIN7 je velky problem rozbehnut. Akoze da sa to, ale krkolomne.
Problem je z Javou :roll:
VeCeZ22YH
KFL napísal:EPC obrazky vo Firefoxe ani Opere nejdu, lebo ImagePlugin je urceny len pre IE.
KFL dakujem. ja som trubko. myslel som na vselico mozne ale toto ma nenapadlo. :oops:
mirek
Auto: Zafira A
Už mi to ide na nervy .Dal som EPC-ko známemu aby mi to rozbehal a zatiaľ nič.V Opli mi vedúci povedal že on má doma W7 a jemu to ide bez problemov./len asi nie ta verzia ktorú mám ja z roku 2009/Možno by som privital troška viac ochoty nakoľko som u nich nechal nemalé peniaze a zadarmo to nechcem.
Y22DTR
Ako? Viac ochoty z ich strany, aby ti poskytli legálny SW? Vieš koľko taký SW stojí? Nemyslím, že si u nich nechal viac za opravy, ako je hodnota, ktorú od nich žiadaš, hoc aj za nejaké všimné :wink: ... legálnu verziu z Opla by ti poskytol iba blázon, alebo človek práve idúci do kriminálu.
別のブランド
OPEL CORSA C 1.2 COSMO - ex
OPEL CORSA B 1.0 CITY - ex
Návrat na "OPEL VŠEOBECNE"
