vrzganie volantu
Moderátor: dulo
jasan21
vrzganie volantu
Príspevok od používateľa jasan21 »
ahojte pred cca mesiacom som kupil fronteru a vcera mi zacal vrzgat volant pri toceni...volal som kamosovi co ju mal tiez a povedal ze to robi kazda frontera no podla mna to je blbost lebo mesiac volant siel krasne chcem sa spytat ci sa to uz niekomu stalo a ako to vyriesil.
BTW mam v aute sedacky recaro a spolujazdcove je dost vysoko...montovali RECARO sedacky original ci to si namontoval predchadzajuci majitel?
auto je z nemecka
Vŕzgal mi aj volant na Omi, na starej aj na novej.
Tyč volantu prechádza v hornej tretine cez nejakú gumu alebo čo je to.
Zospodu som strekol WD40 a bol pokoj. Navždy
jasan21
pozeral som kde to moze robit a niekde pri prepinachoch svetiel lebo volant sa nedotyka nicoho no skusim tvoju radu ale neviem ci WD je najvhodnejsie riesenie lebo je stavane na vodnej baze...
dam vazelinu ked nepomoze tak pojde wd...dost neprijemny zvuk pri toceni volantom nielen premna ale aj pre pasazierov
WD40 nie je na vodnej báze:
Formulation
WD-40's main ingredients, according to U.S. Material Safety Data Sheet information, are:
* 50%: Stoddard solvent (i.e., mineral spirits -- somewhat similar to kerosene)
* 25%: Liquefied petroleum gas (presumably as a propellant; carbon dioxide is now used instead to reduce WD-40's considerable flammability)
* 15+%: Mineral oil (light lubricating oil)
* 10-%: Inert ingredients
The German version of the mandatory EU safety sheet lists the following safety relevant ingredients:
* 60-80%: Heavy Naphtha (petroleum product), hydrogen treated
* 1-5%: Carbon dioxide
It further lists flammability and effects to the human skin when repeatedly exposed to WD-40 as risks when using WD-40. Nitrile rubber gloves and safety glasses should be used. Water is unsuitable for extinguishing burning WD-40.
There is a popular urban legend that the main ingredient in WD-40 is fish oil.[2] Although it is unknown whether the formula contains fish oil, material safety data sheets for the product show that the main ingredient is Stoddard solvent, not fish oil.[3]
Mne to pomohlo.
jasan21
oki vyskusam...mam este synteticky olej ktory pouzivame vo firme na mazanie rezacich platkov na frezach sustruhoch a sice trosku smrdi no je jemnejsi ako WD...necham si poradit od od teba ak nie budem musiet pocuvat hlasnejsie hudbu :-({|=
jasan21
no takze som to rozobral nasprejoval volant som nedal dole len WDckom som prestriekal celu hriadel volantu a stale vrzga....niekde kde mam prepinace smeroviek...
volant nechcem davat dole koly airbagu
jasan21
zas ten problem....rozobral som to ten olej to len "zlepil".
problem je ze potrebujem tu objimku co drzi klakson aj airbag teda tam sa to zapaja a ked som bol v elite tak mi povedali 3-5 tisic SK....sa mi oci prekrutili....
vedel by mi niekto poradit? vraj to pasuje z vectry resp ma niekto tu objimku na predaj? proste potrebujem pomoc....vdaka
jasan21
:D asi si z toho spravim dennicek :D ani obraz ani zvuk.mna uz nikto nema raaad
jasan21 napísal::D asi si z toho spravim dennicek :D ani obraz ani zvuk.mna uz nikto nema raaad
myslis plastove otacave cudo, kade idu kable na airbag aj klakson ?
kontaktna jednotka volantu ...
chces foto ?
jasan21
jj toto myslim presne a za toto pytali od 3000 do 5000 sk v elite samotny predavac volal ich dodavatelovi a do telefonu mu povedal citujem:
"kolko? ste sa zblaznili? nie dakujem."
potom ako zlozil povedal sumu za toto kolecko s tym ze to je jeho cena bez rabatu a som sa otocil na päte.preto hladam nejaku alternativu
Návrat na "FRONTERA, ANTARA, MONTEREY, CAMPO, MOVANO, VIVARO - INTERIÉR/EXTERIÉR"
