ked je chyba v relatku k RJ, tak staci za par eur kupit nove.
ak nedava riadiaca jednotka benzin kvoli zlemu snimacu kluky, tak za 20 Eur mas nahradny snimac. niekde ho urcite mam
my ale potrebujeme presne informacie, inak je nam tazko radit
MAM PROBLEM, ASI Z ELEKTRIKOU
- Lubec
Ak by to bol kluc,tak by mu bud auto nenastartovalo, alebo ak, tak by mu neskor same od seba nezhaslo. Boli casy ked som imobilizer po nacitani strcil do skrynky. A nicomu nechybal.
Mam tiez za to, ze riadiaca jednotka nedava iskru, nie benzin pokial je vadny snimac otacok.
quattro
VeBe X25XE - Phoenix-ex
Tak tu sú sľúbené kódy:
P0201 cylinder 1 injector signal too large B-011
P0201 cylinder 1 injector signal to small B-011
P0201 cylinder 1 injector circuit open B-011
P0202 cylinder 2 injector signal too large B-011
P0202 cylinder 2 injector signal to small B-011
P0202 cylinder 2 injector circuit open B-011
P0203 cylinder 3 injector signal too large B-011
P0203 cylinder 3 injector signal to small B-011
P0203 cylinder 3 injector circuit open B-011
P0204 cylinder 4 injector signal too large B-011
P0204 cylinder 4 injector signal to small B-011
P0204 cylinder 4 injector circuit open B-011
P0230 fuel pump primary circuit signal is too large B-010
P0650 CAN bus no communication with CIM (Steering Column module) C-003
P0650 error display control light (MI) dysfunction IPC (instrument) B-008
P1550 Power steering Pressure (PSP) sensor out of Self - Test range
U2103 CAN bus communication nodes no C-005
U2103 CAN bus Rücksetzzähler overflow C-005
U2103 CAN-bus circuit malfunction C-005
U2103 No communication with CAN-bus (High Speed) C-005
U2103 No communication with CAN-bus (Low Speed) C-005
U2104 CAN bus (High Speed) Rücksetzzähler overflow C-005
U2104 CAN bus (Mid Speed) Rücksetzzähler overflow C-005
U2104 CAN bus Rücksetzzähler overflow C-005
U2108 CAN bus, no communication with ABS (anti-) C-003
U2108 CAN bus no communication with ABS / TC C-003
U2108 programmers / Replace control unit (SG) hardware and software B-003
U2139 CAN bus no communication with CIM (Steering Column module) C-003
A teraz babo raď... :roll:
Žeby ten povestný CIM modul?
