ESP mi nefunguje, alebo tam nie je????
Bydlisko alt: Sološnica
cito napísal:môžeš mi zistiť podľa VIN či mám ja ESP, lebo vlastne ani neviem aký mám typ ( myslím tie cosmo... ) VIN je W0L0AHM757G027762, zafiru mám 2006, 1,9 cdti
2AU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ
2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ
80I = VNITŘEK-ČERNÝ
80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ
80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ
A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO
A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ
AF8 = KONTROLA ZAMYKÁNÍ POSTRANNÍCH DVEŘÍ,OCHRANA PROTI KRÁDEŽI
AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ
AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA
AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ
ANY = KOLEJNICE A VÁZACÍ ÚCHYTY PRO NÁKLAD
AV4 = DĚLENÉ ZADNÍ SEDADLO
AWY = ZÁDRŽNÝ SYSTÉM ZADNÍ SEDADLO,RAMENNÍ,ZATAHOVÁNÍ,ODDĚLITELNÝ KOTVICÍ BOD BEZPEČNOSTNÍHO PÁSU
AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ
AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED
B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ
B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ
BF8 = ÚLOŽNÁ SCHRÁNKA,PŘEDNÍ SEDADLO,PRAVÉ
BL5 = LIŠTA KRYCÍ DVEŘE VNITŘEK,STŘÍBRNÁ
BLB = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,STŘÍBRNÁ
BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE
C60 = KLIMATIZACE
C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU
CT5 = PRO HOLANDSKO
CT5
D75 = KLIKA ÚPLNÁ VNĚJŠÍ
DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ
DDU = ZRCÁTKO,SESTAVA
DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ
DP6 = TĚLESO
DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA)
DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ
E4Q = ENJOY
E94 = KRYT
ECA = KLÍČ
FXB = POMĚR NÁPRAVY 3.65
G62 = 5 ŠROUB UPEVNĚNÍ KOLA
JL9 = ABS
K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU
K34 = REGULÁTOR RYCHLOSTI
K60 = ALTERNÁTOR,100AMP
KC7 = ELEKTRICKÁ ZÁSUVKA,ZADNÍ SEDADLO
KC8 = ZÁSUVKA,VÝSTUP POMOCNÉHO NAPÁJENÍ
KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA
LHD = ŘÍZENÍ LEVÉ
LPP = Z19DTL[LPP] NAFTOVÝ MOTOR
MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU
MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR)
N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM
NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE
NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE
NT4 = EMISE,EEC 05
OHA = MÍSTNÍ GM Z EUROPE OHA
P92 = KRYT,KOLO 16PALCOVÉ PROVEDENÍ CHAMPAGNE MR07
PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA
QGF = PNEUMATIKY,205/55 R 16-91H
QN1 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16
QQ5 = PRO VELKÉ NÁHRAD.KOLO
T9W = OBKLAD,VNITŘNÍ,TABITA
TM7 = BATERIE,60AH
TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ
TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ
TRP = RÁMEČEK,RADIOPŘIJÍMAČ
TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ
TTB = OSVĚTLENÍ VNITŘNÍ,STŘEŠNÍ, ZADNÍ KOMFORTNÍ A DVOJITÉ ČTECÍ,3. ŘADA
U07 = HOUKAČKA,TROUBA
U3C
U55
U66 = REPRODUKTOR,7
U68 = INFORMAČNÍ POČÍTAČ
U71 = ANTÉNA,ÚPLNÁ,STŘECHA
UA6 = OCHRANA PROTI VLOUPÁNÍ
UAC = INFORMAČNÍ PANEL LCD - VÍCEFUNKČNÍ
UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3
UH0 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,LH
UJ3
V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU
V3D = NOSIČ ZAVAZADEL VOLNÝ STŘEŠNÍ,ČERNÝ
V4M = VYBAVENÍ 5-STAR,SADA NCAP
VFE = NÁRAZNÍK PŘEDNÍ A ZADNÍ,OCHRANNÝ VÝLISEK,BAREVNÝ
VG2 = OCHRANNÍ VOSK, VYNECHEJTE
VNF = ODPOJOVAČ BATERIE
W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU
W4Y
WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO
XA3 = OPEL
XQ5 = PRO HOLANDSKO
Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI
Z0G = PRO HOLANDSKO
Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
cito
Dátum registrácie: 06 Sep 2009, 18:50
Príspevok od používateľa cito »
ja som to už videl, ale žiadne údaje sa nezhodujú s tými čo sú v tabuľke, pravdepodobne zle hľadám...
cito
nevie mi niekto poradiť kde nájdem to číslo 13......, podľa ktorého zistím do ktorej kategórie auto zaradím ?
maroš72
Dátum registrácie: 09 Jún 2009, 11:04
Príspevok od používateľa maroš72 »
v astre ESP mám,je to dobrá vec, ale v zafire nie je,dá sa to nejako dodatočne dorobiť?
Opel Insignia S&S Dynamic AT8,r.v.2018
Opel Zafira Tourer 2,0 CDTi 121kw, r.v.2013 -ex
Opel Zafira 1,9 CDTi 88kw, r.v.2008 - ex
Opel Astra H caravan 1,7 CDTI 74kw,r.v.2005 - ex
cito
Re: ESP mi nefunguje, alebo tam nie je????
Viete mi niekto podľa môjho VIN ( vyššie ) zistiť, či mám ESP, mal som starú zafiru 1999 a tam som ho mal, a žeby v novej nebolo? Nechce sa mi tomu veriť.
žiaľ mám zlú správu podľa VIN nemáš určite ESP :cry:
cito
Dík za rýchlu odpoveď Signum, môžeš mi prosím ťa poslať čo vlastne ja v aute mám, lebo ak pozerám rôzne výbavy, tak si akosiu neviem nájsť tú svoju.
Odpoveď si už predsa dostal v roku 2012
cito
Máš pravdu, dostal, ale len link na tabuľku, v ktorej nie je nič čo v mojej zafire, takže som z toho jasný ako tem predo mnou...
V prvom príspevku na tejto strane máš kompletný popis tvojho auta tak, ako zišlo z výrobného pása.
lesi
Dátum registrácie: 08 Feb 2008, 22:57
Auto: Zafira Tourer
Príspevok od používateľa lesi »
Signum, to z ktorého múdreho miesta čerpáš prosím ťa? Dík.
Opel Zafira Tourer 2,0 CDTi Cosmo r.v. 13
Opel Astra H 1,4 Enjoy r.v. 04
Opel Zafira B 1,9 CDTi Enjoy r.v. 05-ex
Opel Vivaro Life Westfalia 2.5 CDTi r.v. 07-ex
Opel Zafira A 1.6 16 V Elegance r.v. 99-ex
Fiat Marea Weekend 1.6 16 V LX r.v. 97-ex
lesi napísal:Signum, to z ktorého múdreho miesta čerpáš prosím ťa? Dík.
GM Global Connect
lesi
Auto: Zafira Tourer
Hodíš sem aj moje keď ti dám vin-ko?
Návrat na "ZAFIRA, SINTRA - ELEKTRO"
