ODBII Error codes
- buci_vectra
ODBII Error codes
Viem ze o chybovych kodoch je tu toho vela a aj Macil tu ma vlakno o tom, ale v tak obsiahlom rozsahu som to tu nevidel.
Len skoda, ze je to english
Codes of errors OBD II five-unit code of the error
First position:
P - is for powertrain codes;
B - is for body codes;
C - is for chassis codes.
Second position:
0 - general for Obd- ii code
1 - the code of producer.
Third position:
1 - fuel system either air supply
2 - fuel system or air supply
3 - ignition system
4 - auxiliary control by
5 - idling
6 - ECU or its chain
7 - the transmission
Fourth and fifth positions:
the ordinal number of the error
OBD II Error codes:
P0100 Mass or Volume Air Flow Circuit Malfunction
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0102 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0104 Mass or Volume Air Flow Circuit Intermittent
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0110 Intake Air Temperature Circuit Malfunction
P0111 Intake Air Temperature Circuit Range/Performance Problem
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0114 Intake Air Temperature Circuit Intermittent
P0115 Engine Coolant Temperature Circuit Malfunction
P0116 Engine Coolant Temperature Circuit Range/Performance Problem
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0119 Engine Coolant Temperature Circuit Intermitten
P0120 Throttle/Petal Position Sensor/Switch A Circuit Malfunction
P0121 Throttle/Petal Position Sensor/Switch A Circuit Range/Performance Problem
P0122 Throttle/Petal Position Sensor/Switch A Circuit Low Input
P0123 Throttle/Petal Position Sensor/Switch A Circuit High Input
P0124 Throttle/Petal Position Sensor/Switch A Circuit Intermittent
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
P0126 Insufficient Coolant Temperature for Stable Operation
P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
P0131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0142 O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
P0143 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)
P0144 O2 Sensor Circuit High Voltage (Bank 1 Sensor 3)
P0145 O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)
P0146 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
P0147 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
P0150 O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
P0151 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0156 O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0157 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158 O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0162 O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164 O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165 O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
P0167 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
P0170 Fuel Trim Malfunction (Bank 1)
P0171 System too Lean (Bank 1)
P0172 System too Rich (Bank 1)
P0173 Fuel Trim Malfunction (Bank 2)
P0174 System too Lean (Bank 2)
P0175 System too Rich (Bank 2)
P0176 Fuel Composition Sensor Circuit Malfunction
P0177 Fuel Composition Sensor Circuit Range/Performance
P0178 Fuel Composition Sensor Circuit Low Input
P0179 Fuel Composition Sensor Circuit High Input
P0180 Fuel Temperature Sensor A Circuit Malfunction
P0181 Fuel Temperature Sensor A Circuit Range/Performance
P0182 Fuel Temperature Sensor A Circuit Low Input
P0183 Fuel Temperature Sensor A Circuit High Input
P0184 Fuel Temperature Sensor A Circuit Intermittent
P0185 Fuel Temperature Sensor B Circuit Malfunction
P0186 Fuel Temperature Sensor B Circuit Range/Performance
P0187 Fuel Temperature Sensor B Circuit Low Input
P0188 Fuel Temperature Sensor B Circuit High Input
P0189 Fuel Temperature Sensor B Circuit Intermittent
P0190 Fuel Rail Pressure Sensor Circuit Malfunction
P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
P0192 Fuel Rail Pressure Sensor Circuit Low Input
P0193 Fuel Rail Pressure Sensor Circuit High Input
P0194 Fuel Rail Pressure Sensor Circuit Intermittent
P0195 Engine Oil Temperature Sensor Malfunction
P0196 Engine Oil Temperature Sensor Range/Performance
P0197 Engine Oil Temperature Sensor Low
P0198 Engine Oil Temperature Sensor High
P0199 Engine Oil Temperature Sensor Intermittent
P0200 Injector Circuit Malfunction
P0201 Injector Circuit Malfunction - Cylinder 1
P0202 Injector Circuit Malfunction - Cylinder 2
P0203 Injector Circuit Malfunction - Cylinder 3
P0204 Injector Circuit Malfunction - Cylinder 4
P0205 Injector Circuit Malfunction - Cylinder 5
P0206 Injector Circuit Malfunction - Cylinder 6
P0207 Injector Circuit Malfunction - Cylinder 7
P0208 Injector Circuit Malfunction - Cylinder 8
P0209 Injector Circuit Malfunction - Cylinder 9
P0210 Injector Circuit Malfunction - Cylinder 10
P0211 Injector Circuit Malfunction - Cylinder 11
P0212 Injector Circuit Malfunction - Cylinder 12
P0213 Cold Start Injector 1 Malfunction
P0214 Cold Start Injector 2 Malfunction
P0215 Engine Shutoff Solenoid Malfunction
P0216 Injection Timing Control Circuit Malfunction
P0217 Engine Overtemp Condition
P0218 Transmission Over Temperature Condition
P0219 Engine Overspeed Condition
P0220 Throttle/Petal Position Sensor/Switch B Circuit Malfunction
P0221 Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem
P0222 Throttle/Petal Position Sensor/Switch B Circuit Low Input
P0223 Throttle/Petal Position Sensor/Switch B Circuit High Input
P0224 Throttle/Petal Position Sensor/Switch B Circuit Intermittent
P0225 Throttle/Petal Position Sensor/Switch C Circuit Malfunction
P0226 Throttle/Petal Position Sensor/Switch C Circuit Range/Performance Problem
P0227 Throttle/Petal Position Sensor/Switch C Circuit Low Input
P0228 Throttle/Petal Position Sensor/Switch C Circuit High Input
P0229 Throttle/Petal Position Sensor/Switch C Circuit Intermittent
P0230 Fuel Pump Primary Circuit Malfunction
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0233 Fuel Pump Secondary Circuit Intermittent
P0234 Engine Overboost Condition
P0235 Turbocharger Boost Sensor A Circuit Malfunction
P0236 Turbocharger Boost Sensor A Circuit Range/Performance
P0237 Turbocharger Boost Sensor A Circuit Low
P0238 Turbocharger Boost Sensor A Circuit High
P0239 Turbocharger Boost Sensor B Malfunction
P0240 Turbocharger Boost Sensor B Circuit Range/Performance
P0241 Turbocharger Boost Sensor B Circuit Low
P0242 Turbocharger Boost Sensor B Circuit High
P0243 Turbocharger Wastegate Solenoid A Malfunction
P0244 Turbocharger Wastegate Solenoid A Range/Performance
P0245 Turbocharger Wastegate Solenoid A Low
P0246 Turbocharger Wastegate Solenoid A High
P0247 Turbocharger Wastegate Solenoid B Malfunction
P0248 Turbocharger Wastegate Solenoid B Range/Performance
P0249 Turbocharger Wastegate Solenoid B Low
P0250 Turbocharger Wastegate Solenoid B High
P0251 Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
P0256 Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
P0257 Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)
P0258 Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
P0259 Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)
P0260 Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
P0261 Cylinder 1 Injector Circuit Low
P0262 Cylinder 1 Injector Circuit High
P0263 Cylinder 1 Contribution/Balance Fault
P0264 Cylinder 2 Injector Circuit Low
P0265 Cylinder 2 Injector Circuit High
P0266 Cylinder 2 Contribution/Balance Fault
P0267 Cylinder 3 Injector Circuit Low
P0268 Cylinder 3 Injector Circuit High
P0269 Cylinder 3 Contribution/Balance Fault
P0270 Cylinder 4 Injector Circuit Low
P0271 Cylinder 4 Injector Circuit High
P0272 Cylinder 4 Contribution/Balance Fault
P0273 Cylinder 5 Injector Circuit Low
P0274 Cylinder 5 Injector Circuit High
P0275 Cylinder 5 Contribution/Balance Fault
P0276 Cylinder 6 Injector Circuit Low
P0277 Cylinder 6 Injector Circuit High
P0278 Cylinder 6 Contribution/Balance Fault
P0279 Cylinder 7 Injector Circuit Low
P0280 Cylinder 7 Injector Circuit High
P0281 Cylinder 7 Contribution/Balance Fault
P0282 Cylinder 8 Injector Circuit Low
P0283 Cylinder 8 Injector Circuit High
P0284 Cylinder 8 Contribution/Balance Fault
P0285 Cylinder 9 Injector Circuit Low
P0286 Cylinder 9 Injector Circuit High
P0287 Cylinder 9 Contribution/Balance Fault
P0288 Cylinder 10 Injector Circuit Low
P0289 Cylinder 10 Injector Circuit High
P0290 Cylinder 10 Contribution/Balance Fault
P0291 Cylinder 11 Injector Circuit Low
P0292 Cylinder 11 Injector Circuit High
P0293 Cylinder 11 Contribution/Balance Fault
P0294 Cylinder 12 Injector Circuit Low
P0295 Cylinder 12 Injector Circuit High
P0296 Cylinder 12 Contribution/Range Fault
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0305 Cylinder 5 Misfire Detected
P0306 Cylinder 6 Misfire Detected
P0307 Cylinder 7 Misfire Detected
P0308 Cylinder 8 Misfire Detected
P0309 Cylinder 9 Misfire Detected
P0311 Cylinder 11 Misfire Detected
P0312 Cylinder 12 Misfire Detected
P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
P0325 Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)
P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
P0333 Knock Sensor 2 Circuit High Input (Bank 2)
P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
P0335 Crankshaft Position Sensor A Circuit Malfunction
P0336 Crankshaft Position Sensor A Circuit Range/Performance
P0337 Crankshaft Position Sensor A Circuit Low Input
P0338 Crankshaft Position Sensor A Circuit High Input
P0339 Crankshaft Position Sensor A Circuit Intermittent
P0340 Camshaft Position Sensor Circuit Malfunction
P0341 Camshaft Position Sensor Circuit Range/Performance
P0342 Camshaft Position Sensor Circuit Low Input
P0343 Camshaft Position Sensor Circuit High Input
P0344 Camshaft Position Sensor Circuit Intermittent
P0350 Ignition Coil Primary/Secondary Circuit Malfunction
P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
P0353 Ignition Coil C Primary/Secondary Circuit Malfunction
P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
P0355 Ignition Coil E Primary/Secondary Circuit Malfunction
P0356 Ignition Coil F Primary/Secondary Circuit Malfunction
P0357 Ignition Coil G Primary/Secondary Circuit Malfunction
P0358 Ignition Coil H Primary/Secondary Circuit Malfunction
P0359 Ignition Coil I Primary/Secondary Circuit Malfunction
P0360 Ignition Coil J Primary/Secondary Circuit Malfunction
P0361 Ignition Coil K Primary/Secondary Circuit Malfunction
P0362 Ignition Coil L Primary/Secondary Circuit Malfunction
P0370 Timing Reference High Resolution Signal A Malfunction
P0371 Timing Reference High Resolution Signal A Too Many Pulses
P0372 Timing Reference High Resolution Signal A Too Few Pulses
P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
P0374 Timing Reference High Resolution Signal A No Pulses
P0375 Timing Reference High Resolution Signal B Malfunction
P0376 Timing Reference High Resolution Signal B Too Many Pulses
P0377 Timing Reference High Resolution Signal B Too Few Pulses
P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
P0379 Timing Reference High Resolution Signal B No Pulses
P0380 Glow Plug/Heater Circuit "A" Malfunction
P0381 Glow Plug/Heater Indicator Circuit Malfunction
P0382 Exhaust Gas Recirculation Flow Malfunction
P0385 Crankshaft Position Sensor B Circuit Malfunction
P0386 Crankshaft Position Sensor B Circuit Range/Performance
P0387 Crankshaft Position Sensor B Circuit Low Input
P0388 Crankshaft Position Sensor B Circuit High Input
P0389 Crankshaft Position Sensor B Circuit Intermittent
P0400 Exhaust Gas Recirculation Flow Malfunction
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0403 Exhaust Gas Recirculation Circuit Malfunction
P0404 Exhaust Gas Recirculation Circuit Range/Performance
P0405 Exhaust Gas Recirculation Sensor A Circuit Low
P0406 Exhaust Gas Recirculation Sensor A Circuit High
P0407 Exhaust Gas Recirculation Sensor B Circuit Low
P0408 Exhaust Gas Recirculation Sensor B Circuit High
P0410 Secondary Air Injection System Malfunction
P0411 Secondary Air Injection System Incorrect Flow Detected
P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
P0413 Secondary Air Injection System Switching Valve A Circuit Open
P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction
P0416 Secondary Air Injection System Switching Valve B Circuit Open
P0417 Secondary Air Injection System Switching Valve B Circuit Shorted
P0418 Secondary Air Injection System Relay "A" Circuit Malfunction
P0419 Secondary Air Injection System Relay "B" Circuit Malfunction
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
P0440 Evaporative Emission Control System Malfunction
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0442 Evaporative Emission Control System Leak Detected (small leak)
P0443 Evaporative Emission Control System Purge Control Valve Circuit Malfunction
P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
P0447 Evaporative Emission Control System Vent Control Circuit Open
P0448 Evaporative Emission Control System Vent Control Circuit Shorted
P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
P0450 Evaporative Emission Control System Pressure Sensor Malfunction
P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
P0452 Evaporative Emission Control System Pressure Sensor Low Input
P0453 Evaporative Emission Control System Pressure Sensor High Input
P0454 Evaporative Emission Control System Pressure Sensor Intermittent
P0455 Evaporative Emission Control System Leak Detected (gross leak)
P0460 Fuel Level Sensor Circuit Malfunction
P0461 Fuel Level Sensor Circuit Range/Performance
P0462 Fuel Level Sensor Circuit Low Input
P0463 Fuel Level Sensor Circuit High Input
P0464 Fuel Level Sensor Circuit Intermittent
P0465 Purge Flow Sensor Circuit Malfunction
P0466 Purge Flow Sensor Circuit Range/Performance
P0467 Purge Flow Sensor Circuit Low Input
P0468 Purge Flow Sensor Circuit High Input
P0469 Purge Flow Sensor Circuit Intermittent
P0470 Exhaust Pressure Sensor Malfunction
P0471 Exhaust Pressure Sensor Range/Performance
P0472 Exhaust Pressure Sensor Low
P0473 Exhaust Pressure Sensor High
P0474 Exhaust Pressure Sensor Intermittent
P0475 Exhaust Pressure Control Valve Malfunction
P0476 Exhaust Pressure Control Valve Range/Performance
P0477 Exhaust Pressure Control Valve Low
P0478 Exhaust Pressure Control Valve High
P0479 Exhaust Pressure Control Valve Intermittent
P0480 Cooling Fan 1 Control Circuit Malfunction
P0481 Cooling Fan 2 Control Circuit Malfunction
P0482 Cooling Fan 3 Control Circuit Malfunction
P0483 Cooling Fan Rationality Check Malfunction
P0484 Cooling Fan Circuit Over Current
P0485 Cooling Fan Power/Ground Circuit Malfunction
P0500 Vehicle Speed Sensor Malfunction
P0501 Vehicle Speed Sensor Range/Performance
P0502 Vehicle Speed Sensor Low Input
P0503 Vehicle Speed Sensor Intermittent/Erratic/High
P0505 Idle Control System Malfunction
P0506 Idle Control System RPM Lower Than Expected
P0507 Idle Control System RPM Higher Than Expected
P0510 Closed Throttle Position Switch Malfunction
P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage
P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
P0533 A/C Refrigerant Pressure Sensor Circuit High Input
P0534 Air Conditioner Refrigerant Charge Loss
P0550 Power Steering Pressure Sensor Circuit Malfunction
P0551 Power Steering Pressure Sensor Circuit Range/Performance
P0552 Power Steering Pressure Sensor Circuit Low Input
P0553 Power Steering Pressure Sensor Circuit High Input
P0554 Power Steering Pressure Sensor Circuit Intermittent
P0560 System Voltage Malfunction
P0561 System Voltage Unstable
P0562 System Voltage Low
P0563 System Voltage High
P0565 Cruise Control On Signal Malfunction
P0566 Cruise Control Off Signal Malfunction
P0567 Cruise Control Resume Signal Malfunction
P0568 Cruise Control Set Signal Malfunction
P0569 Cruise Control Coast Signal Malfunction
P0570 Cruise Control Accel Signal Malfunction
P0571 Cruise Control/Brake Switch A Circuit Malfunction
P0572 Cruise Control/Brake Switch A Circuit Low
P0573 Cruise Control/Brake Switch A Circuit High
P0574 Cruise Control Related Malfunction
P0575 Cruise Control Related Malfunction
P0576 Cruise Control Related Malfunction
P0577 Cruise Control Related Malfunction
P0578 Cruise Control Related Malfunction
P0579 Cruise Control Related Malfunction
P0580 Cruise Control Related Malfunction
P0600 Serial Communication Link Malfunction
P0601 Internal Control Module Memory Check Sum Error
P0602 Control Module Programming Error
P0603 Internal Control Module Keep Alive Memory (KAM) Error
P0604 Internal Control Module Random Access Memory (RAM) Error
P0605 Internal Control Module Read Only Memory (ROM) Error
P0606 PCM Processor Fault
P0608 Control Module VSS Output "A" Malfunction
P0609 Control Module VSS Output "B" Malfunction
P0620 Generator Control Circuit Malfunction
P0621 Generator Lamp "L" Control Circuit Malfunction
P0622 Generator Field "F" Control Circuit Malfunction
P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
P0654 Engine RPM Output Circuit Malfunction
P0655 Engine Hot Lamp Output Control Circuit Malfucntion
P0656 Fuel Level Output Circuit Malfunction
P0700 Transmission Control System Malfunction
P0701 Transmission Control System Range/Performance
P0702 Transmission Control System Electrical
P0703 Torque Converter/Brake Switch B Circuit Malfunction
P0704 Clutch Switch Input Circuit Malfunction
P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)
P0706 Transmission Range Sensor Circuit Range/Performance
P0707 Transmission Range Sensor Circuit Low Input
P0708 Transmission Range Sensor Circuit High Input
P0709 Transmission Range Sensor Circuit Intermittent
P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712 Transmission Fluid Temperature Sensor Circuit Low Input
P0713 Transmission Fluid Temperature Sensor Circuit High Input
P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
P0715 Input/Turbine Speed Sensor Circuit Malfunction
P0716 Input/Turbine Speed Sensor Circuit Range/Performance
P0717 Input/Turbine Speed Sensor Circuit No Signal
P0718 Input/Turbine Speed Sensor Circuit Intermittent
P0719 Torque Converter/Brake Switch B Circuit Low
P0720 Output Speed Sensor Circuit Malfunction
P0721 Output Speed Sensor Range/Performance
P0722 Output Speed Sensor No Signal
P0723 Output Speed Sensor Intermittent
P0724 Torque Converter/Brake Switch B Circuit High
P0725 Engine Speed input Circuit Malfunction
P0726 Engine Speed Input Circuit Range/Performance
P0727 Engine Speed Input Circuit No Signal
P0728 Engine Speed Input Circuit Intermittent
P0730 Incorrect Gear Ratio
P0731 Gear 1 Incorrect ratio
P0732 Gear 2 Incorrect ratio
P0733 Gear 3 Incorrect ratio
P0734 Gear 4 Incorrect ratio
P0735 Gear 5 Incorrect ratio
P0736 Reverse incorrect gear ratio
P0740 Torque Converter Clutch Circuit Malfuction
P0741 Torque Converter Clutch Circuit Performance or Stuck Off
P0742 Torque Converter Clutch Circuit Stuck On
P0743 Torque Converter Clutch Circuit Electrical
P0744 Torque Converter Clutch Circuit Intermittent
P0745 Pressure Control Solenoid Malfunction
P0746 Pressure Control Solenoid Performance or Stuck Off
P0747 Pressure Control Solenoid Stuck On
P0748 Pressure Control Solenoid Electrical
P0749 Pressure Control Solenoid Intermittent
P0750 Shift Solenoid A Malfunction
P0751 Shift Solenoid A Performance or Stuck Off
P0752 Shift Solenoid A Stuck On
P0753 Shift Solenoid A Electrical
P0754 Shift Solenoid A Intermittent
P0755 Shift Solenoid B Malfunction
P0756 Shift Solenoid B Performance or Stuck Off
P0757 Shift Solenoid B Stuck On
P0758 Shift Solenoid B Electrical
P0759 Shift Solenoid B Intermittent
P0760 Shift Solenoid C Malfunction
P0761 Shift Solenoid C Performance or Stuck Off
P0762 Shift Solenoid C Stuck On
P0763 Shift Solenoid C Electrical
P0764 Shift Solenoid C Intermittent
P0765 Shift Solenoid D Malfunction
P0766 Shift Solenoid D Performance or Stuck Off
P0767 Shift Solenoid D Stuck On
P0768 Shift Solenoid D Electrical
P0769 Shift Solenoid D Intermittent
P0770 Shift Solenoid E Malfunction
P0771 Shift Solenoid E Performance or Stuck Off
P0772 Shift Solenoid E Stuck On
P0773 Shift Solenoid E Electrical
P0774 Shift Solenoid E Intermittent
P0780 Shift Malfunction
P0781 1-2 Shift Malfunction
P0782 2-3 Shift Malfunction
P0783 3-4 Shift Malfunction
P0784 4-5 Shift Malfunction
P0785 Shift/Timing Solenoid Malfunction
P0786 Shift/Timing Solenoid Range/Performance
P0787 Shift/Timing Solenoid Low
P0788 Shift/Timing Solenoid High
P0789 Shift/Timing Solenoid Intermittent
P0790 Normal/Performance Switch Circuit Malfunction
P0801 Reverse Inhibit Control Circuit Malfunction
P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
P1000 OBD II Monitor Testing not complete
P1001 Key On Engine Running (KOER) Self-Test not able to complete. KOER aborted
P1100 Mass Air Flow (MAF) sensor intermittent
P1101 Mass Air Flow (MAF) sensor out of Self-Test range
P1110 Switch over valve solenoid
P1112 Switch over valve 1
P1113 Switch over valve 2
P1116 Engine Coolant Temperature (ECT) sensor out of Self - Test range
P1117 Engine Coolant Temperature (ECT) sensor intermittent
P1120 Throttle Position (TP) sensor out of range low
P1121 Throttle Position (TP) sensor inconsistent with MAF Sensor
P1124 Throttle Position (TP) sensor out of Self -Test range
P1125 Throttle Position (TP) sensor circuit intermittent
P1127 Exhaust not warm enough, downstream Heated Oxygen Sensors (HO2Ss) not tested
P1128 Upstream Heated Oxygen Sensors (HO2Ss) swapped from bank to bank
P1129 Downstream Heated Oxygen Sensors (HO2Ss) swapped from bank to bank
P1130 Lack of upstream Heated Oxygen Sensor (HO2S 11) switch, adaptive fuel at limit (Bank # 1)
P1131 Lack of upstream Heated Oxygen Sensor (HO2S 11) switch, sensor indicates lean (Bank # 1))
P1132 Lack of upstream Heated Oxygen Sensor (HO2S 11) switch, sensor indicates rich (Bank # 1)
P1137 Lack of downstream Heated Oxygen Sensor (HO2S 12) switch, sensor indicates lean (Bank # 1)
P1138 Lack of downstream Heated Oxygen Sensor (HO2S 12) switch, sensor indicates rich (Bank # 1)
P1150 Lack of upstream Heated Oxygen Sensor (HO2S 21) switch, adaptive fuel at limit (Bank #2)
P1151 Lack of upstream Heated Oxygen Sensor (HO2S 21) switch, sensor indicates lean (Bank # 2)
P1152 Lack of upstream Heated Oxygen Sensor (HO2S 21) switch, sensor indicates rich (Bank # 2)
P1157 Lack of downstream Heated Oxygen Sensor (HO2S 22) switch, sensor indicates lean (Bank # 2)
P1158 Lack of downstream Heated Oxygen Sensor (HO2S 22) switch, sensor indicates rich (Bank # 2)
P1220 Series Throttle Control system malfunction
P1224 Throttle Position Sensor B (TP-B) out of Self - Test range
P1229 Power Supply Relay Primary Circuit Voltage High
P1230 Power Supply Relay Secondary Circuit Voltage Low
P1231 Fuel pump relay circuit low with high speed pump on
P1232 Low speed Fuel Pump primary circuit malfunction
P1233 Fuel Pump Driver Module disabled or offline
P1234 Fuel Pump Driver Module disabled or offline
P1235 Fuel Pump control out of Self - Test range
P1236 Fuel Pump control out of Self - Test range
P1237 Fuel Pump secondary circuit malfunction
P1238 Fuel Pump secondary circuit malfunction
P1260 THEFT detected - engine disabled
P1270 Engine RPM or vehicle speed limiter reached
P1285 Cylinder Head over temperature sensed
P1288 Cylinder Head Temperature (CHT) sensor out of Self - Test range
P1289 Cylinder Head Temperature (CHT) sensor circuit low input
P1290 Cylinder Head Temperature (CHT) sensor circuit high input
P1299 Engine over temperature condition
P1326 Knock Control Maximum Spark Limit Cylinder 1
P1327 Knock Control Maximum Spark Limit Cylinder 2
P1328 Knock Control Maximum Spark Limit Cylinder 3
P1329 Knock Control Maximum Spark Limit Cylinder 4
P1351 Ignition Diagnostic Monitor (IDM) circuit input malfunction
P1356 PIPS occurred while IDM pulse width indicates engine not turning
P1357 Ignition Diagnostic Monitor (IDM) pulse width not defined
P1358 Ignition Diagnostic Monitor (IDM) signal out of Self - Test range
P1359 Spark output circuit malfunction
P1390 Octane Adjust (OCT ADJ) out of Self - Test range
P1400 Differential Pressure Feedback EGR (DPFE) sensor circuit low voltage detected
P1401 Differential Pressure Feedback EGR (DPFE) sensor circuit high voltage detected
P1405 Differential Pressure Feedback EGR (DPFE) sensor upstream hose off or plugged
P1406 Differential Pressure Feedback EGR (DPFE) sensor downstream hose off or plugged
P1408 Exhaust Gas Recirculation (EGR) flow out of Self - Test range
P1409 Electronic Vacuum Regulator (EVR) control circuit malfunction
P1410 Secondary air pump relay
P1411 Secondary Air Injection system incorrect downstream flow detected
P1413 Secondary Air Injection system monitor circuit low voltage
P1414 Secondary Air Injection system monitor circuit high voltage
P1425 Цепь управления клапаном продувки адсорбера, замыкание на землю
P1426 Цепь управления клапаном продувки адсорбера, обрыв
P1442 Evaporative emission control system small leak detected
P1443 Evaporative emission control system - vacuum system, purge control solenoid or vapor management valve malfunction
P1444 Purge Flow (PF) Sensor circuit low input
P1445 Purge Flow (PF) Sensor circuit high input
P1449 Evaporative emission control system unable to hold vacuum (Probe)
P1450 Unable to bleed up fuel tank vacuum
P1452 Unable to bleed up fuel tank vacuum
P1455 Evaporative emission control system control leak detected (gross leak)
P1460 Wide Open Throttle Air Conditioning Cutoff (WAC) circuit malfunction
P1461 Air Conditioning Pressure (ACP) sensor circuit low input
P1462 Air Conditioning Pressure (ACP) sensor circuit high input
P1463 Air Conditioning Pressure (ACP) sensor insufficient pressure change
P1464 Air Condition (A/C) demand out of Self - Test range
P1469 Low air conditioning cycling period
P1473 Fan secondary high with fan(s) off
P1474 Low Fan Control primary circuit malfunction
P1479 High Fan Control primary circuit malfunction
P1480 Fan secondary low with low fan on
P1481 Fan secondary low with high fan on
P1483 Power to fan circuit over current
P1484 Open power ground to Variable Load Control Module (VLCM)
P1501 Immobiliser No or Wrong Coding
P1502 Immobiliser No Signal
P1503 Immobiliser Wrong Signal
P1504 Idle Air Control (IAC) circuit malfunction
P1505 Idle Air Control (IAC) system at adaptive clip
P1506 Idle Air Control (IAC) overspeed error
P1507 Idle Air Control (IAC) under speed error
P1509 Цепь управления регулятором холостого хода, перегрузка
P1512 Intake Manifold Runner Control (IMRC) malfunction (Bank # 1 stuck closed)
P1513 Intake Manifold Runner Control (IMRC) malfunction (Bank # 2 stuck closed)
P1516 Intake Manifold Runner Control (IMRC) input error (Bank # 1)
P1517 Intake Manifold Runner Control (IMRC) input error (Bank # 2)
P1518 Intake Manifold Runner Control (IMRC) malfunction (stuck open)
P1519 Intake Manifold Runner Control (IMRC) malfunction (stuck closed)
P1520 Intake Manifold Runner Control (IMRC) circuit malfunction
P1530 Air Condition (A / C) clutch circuit malfunction
P1537 Intake Manifold Runner Control (IMRC) malfunction (Bank # 1 stuck open)
P1538 Intake Manifold Runner Control (IMRC) malfunction (Bank # 2 stuck open)
P1539 Power to Air condition (A / C) clutch circuit overcurrent
P1541 Цепь управления реле бензонасоса, обрыв
P1550 Power steering Pressure (PSP) sensor out of Self - Test range
P1600 Reprogram or Replace Electronic Control Unit (ECM)
P1601 ECM Box Temperature High
P1602 Knock control module
P1603 Error EEPROM
P1604 Knock control unit
P1605 Knock control unit
P1606 Knock control unit
P1612 immobiliser signal error
P1625 B(+) supply to Variable Load Control Module (VCLM) fan circuit malfunction
P1626 B(+) supply to Variable Load Control Module (VCLM) Air Condition (A / C) circuit malfunction
P1640 Knock control unit or Quad drive module
P1650 Power Steering Pressure (PSP) switch out of Self - Test range
P1651 Power Steering Pressure (PSP) switch input malfunction
P1690 Check Engine fail (malfunction indicator lamp)
P1701 Reverse engagement error
P1703 Brake On/Off (BOO) switch out of Self - Test range
P1705 Transmission Range (TR) Sensor out of Self - Test range
P1709 Park or Neutral Position (PNP) switch is not indicating neutral during KOEO Self - Test
P1711 Transmission Fluid Temperature (TFT) sensor out of Self - Test range
P1728 Transmission slip fault
P1729 4x4 Low switch error
P1740 Torque Control unit
P1741 Torque Converter Clutch (TCC) control error
P1742 Torque Converter Clutch (TCC) solenoid failed on (turns on MIL)
P1743 Torque Converter Clutch (TCC) solenoid failed on (turns on TCIL)
P1744 Torque Converter Clutch (TCC) system mechanically stuck in off position
P1746 Electronic Pressure Control (EPC) solenoid open circuit (low input)
P1747 Electronic Pressure Control (EPC) solenoid short circuit (high input)
P1749 Electronic Pressure Control (EPC) solenoid failed low
P1751 Shift Solenoid # 1 (SS1) performance
P1754 Coast Clutch Solenoid (CCS) circuit malfunction
P1756 Shift Solenoid # 2 (SS2) performance
P1761 Shift Solenoid # 3 (SS3) performance
P1780 Transmission Control switch (TCS) circuit out of Self - Test range
P1781 4x4 Low switch out of Self - Test range
P1783 Transmission over temperature condition
P1788 3-2 Timing / Coast Clutch Solenoid (3-2 / CCS) circuit open
P1789 3-2 Timing / Coast Clutch Solenoid (3-2 / CCS) circuit shorted
U1021 SCP indicating the lack of Air Condition (A/C) clutch status response
U1039 SCP indicating the vehicle speed signal missing or incorrect
U1051 SCP indicating the brake switch signal missing or incorrect
U1073 SCP indicating the lack of engine coolant fan status response
U1131 SCP indicating the lack of Fuel Pump status response
U1135 SCP indicating the ignition switch signal missing or incorrect
U1256 SCP indicating a communications error
U1451 Lack of response from Passive Anti-Theft system (PATS) module - engine disabled
First position:
Second position:
Third position:
3 - ignition system
5 - idling
OBD II Error codes:
P1603 Error EEPROM
Naposledy upravil/-a buci_vectra v 06 Aug 2009, 18:42, upravené celkom 1 krát.
- bukelo
našiel som na webe pre vlastnú potrebu aj takéto chybové kódy, ktoré mi napríklad vyplula corsa B z 96teho (x12sz)
00012 Initiation of diagnosis
00013 Oxygen sensor 1 - open circuit
00014 Coolant temperature sensor - voltage low
00015 Coolant temperature sensor - voltage high
00016 Knock sensor 1 - no voltage change
00017 Knock sensor 2 - no voltage change
00018 Knock control unit - no signal, ECU fault
00019 RPM signal (crankshaft sensor) - incorrect signal
00021 Throttle position sensor - voltage high
00022 Throttle position sensor - voltage low
00023 Invalid code 1
00024 Vehicle speed sensor - no signal
00025 Injector valve 1 - voltage high
00026 Injector valve 2 - voltage high
00027 Injector valve 3 - voltage high
00028 Injector valve 4 - voltage high
00029 Injector valve 5 - voltage high
00031 Engine RPM signal (crankshaft sensor) - no signal
00032 Injector valve 6 - voltage high
00033 EGR valve - voltage too low
00034 EGR valve - voltage too high
00035 Invalid code 2
00036 Invalid code 3
00037 Invalid code 4
00038 Oxygen sensor 1 circuit - voltage low
00039 Oxygen sensor 1 circuit - voltage high
00040 Invalid code 5
00041 Invalid code 6
00042 Invalid code 7
00043 Invalid code 8
00044 Oxygen sensor 1 - Air/fuel mixture too lean
00045 Oxygen sensor 1 - Air/fuel mixture too rich
00046 Secondary air pump circuit - voltage high
00047 Secondary air pump circuit - voltage low
00048 Battery voltage low
00049 Battery voltage high
00051 Invalid code 9
00052 Engine check light; final stage diagnosis - voltage high
00053 Fuel pump relay - voltage low
00054 Fuel pump relay - voltage high
00055 ECU fault - replace ECU
00056 Idle speed control valve - voltage high
00057 Idle speed control valve - voltage low
00058 Invalid code 10
00059 Inlet manifold valve 1 - voltage low
00060 Invalid code 11
00061 Fuel tank vent valve - voltage low
00062 Fuel tank vent valve - voltage high
00063 Inlet manifold valve 1 - voltage high
00064 Invalid code 12
00065 Invalid code 13
00066 Invalid code 14
00067 Invalid code 15
00068 Invalid code 16
00069 Intake air temp sensor - voltage low
00070 Invalid code 17
00071 Intake air temp sensor - voltage high
00072 Invalid code 18
00073 Mass air flow sensor - voltage low
00074 Mass air flow sensor - voltage high
00075 Transmission switch, torque control - voltage low
00076 Auto transmission torque control - engaged too long, ignition retard too long
00077 Invalid code 19
00078 Invalid code 20
00079 Traction control unit - incorrect ign'n/injector cut off
00080 Invalid code 21
00081 Injector valve 1 - voltage low
00082 Injector valve 2 - voltage low
00083 Injector valve 3 - voltage low
00084 Injector valve 4 - voltage low
00085 Injector valve 5 - voltage low
00086 Injector valve 6 - voltage low
00087 Air conditioning cut off relay - voltage low
00088 Air conditioning cut off relay - voltage high
00089 Oxygen sensor 2 heater circuit - voltage low, open circuit
00090 Invalid code 22
00091 Oxygen sensor 2 heater circuit - voltage high
00092 Camshaft sensor failure - faulty
00093 Hall effect switch - voltage low
00094 Hall effect switch - voltage high
00095 Invalid code 23
00096 Invalid code 24
00097 Invalid code 25
00098 Oxygen sensor 2 circuit - voltage low
00099 Invalid code 26
00121 Oxygen sensor 2 - Air/fuel mixture too lean
00122 Oxygen sensor 2 - Air/fuel mixture too rich
00123 Inlet manifold valve 1 blocked
00124 Inlet manifold valve 2 blocked
00127 Camshaft control - voltage low
00128 Camshaft control - voltage high
00129 EGR valve feedback - voltage low
00131 EGR valve feedback - voltage high
00132 EGR valve feedback - incorrect signal
00133 Inlet manifold valve 2 - voltage high
00134 Inlet manifold valve 2 - voltage low
00135 'Check Engine' lamp - voltage low
00136 Unknown error in ECU
00137 ECU box - high temperature
00141 Secondary air pump - not enough air
00142 Secondary air pump - air without pump
00143 Immobiliser function in ECU - no or incorrect signal
00144 No immobiliser signal received - faulty unit or wiring break
00145 Incorrect immobiliser signal received
P0001-P0099 - Fuel and Air Metering and Auxiliary Emission Controls
* P0001 Fuel Volume Regulator Control Circuit/Open
* P0002 Fuel Volume Regulator Control Circuit Range/Performance
* P0003 Fuel Volume Regulator Control Circuit Low
* P0004 Fuel Volume Regulator Control Circuit High
* P0005 Fuel Shutoff Valve "A" Control Circuit/Open
* P0006 Fuel Shutoff Valve "A" Control Circuit Low
* P0007 Fuel Shutoff Valve "A" Control Circuit High
* P0008 Engine Positions System Performance Bank 1
* P0009 Engine Position System Performance Bank 2
* P0010 "A" Camshaft Position Actuator Circuit (Bank 1)
* P0011 "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
* P0012 "A" Camshaft Position - Timing Over-Retarded (Bank 1)
* P0013 "B" Camshaft Position - Actuator Circuit (Bank 1)
* P0014 "B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1) - See Trouble Code P0011
* P0015 "B" Camshaft Position -Timing Over-Retarded (Bank 1) - See Trouble Code P0012
* P0016 Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor A)
* P0017 Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor B)
* P0018 Crankshaft Position - Camshaft Position Correlation (Bank 2 Sensor A)
* P0019 Crankshaft Position - Camshaft Position Correlation (Bank 2 Sensor B)
* P0020 "A" Camshaft Position Actuator Circuit (Bank 2)
* P0021 "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
* P0022 "A" Camshaft Position - Timing Over-Retarded (Bank 2)
* P0023 "B" Camshaft Position - Actuator Circuit (Bank 2) - See Trouble Code P0020
* P0024 "B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 2) - See Trouble Code P0021
* P0025 "B" Camshaft Position - Timing Over-Retarded (Bank 2) - See Trouble Code P0022
* P0026 Intake Valve Control Solenoid Circuit Range/Performance Bank 1
* P0027 Exhaust Valve Control solenoid Circuit Range/Performance Bank 1
* P0028 Intake valve Control Solenoid Circuit Range/Performance Bank 2
* P0029 Exhaust Valve Control Solenoid Circuit Range/Performance Bank 2
* P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1)
* P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
* P0032 HO2S Heater Control Circuit High (Bank 1 Sensor 1)
* P0033 Turbo Charger Bypass Valve Control Circuit
* P0034 Turbo Charger Bypass Valve Control Circuit Low
* P0035 Turbo Charger Bypass Valve Control Circuit High
* P0036 HO2S Heater Control Circuit (Bank 1 Sensor 2)
* P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
* P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2)
* P0039 Turbo/Super Charger Bypass Valve Control Circuit Range/Performance
* P0040 Upstream Oxygen Sensors Swapped From Bank To Bank
* P0041 Downstream Oxygen Sensors Swapped From Bank To Bank
* P0042 HO2S Heater Control Circuit (Bank 1 Sensor 3)
* P0043 HO2S Heater Control Circuit Low (Bank 1 Sensor 3)
* P0044 HO2S Heater Control Circuit High (Bank 1 Sensor 3)
* P0050 HO2S Heater Control Circuit (Bank 2 Sensor 1)
* P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)
* P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1)
* P0053 HO2S Heater Resistance (Bank 1, Sensor 1)
* P0054 HO2S Heater Resistance (Bank 1, Sensor 2)
* P0055 HO2S Heater Resistance (Bank 1, Sensor 3)
* P0056 HO2S Heater Control Circuit (Bank 2 Sensor 2)
* P0057 HO2S Heater Control Circuit Low (Bank 2 Sensor 2)
* P0058 HO2S Heater Control Circuit High (Bank 2 Sensor 2)
* P0059 HO2S Heater Resistance (Bank 2, Sensor 1)
* P0060 HO2S Heater Resistance (Bank 2, Sensor 2)
* P0061 HO2S Heater Resistance (Bank 2, Sensor 3)
* P0062 HO2S Heater Control Circuit (Bank 2 Sensor 3)
* P0063 HO2S Heater Control Circuit Low (Bank 2 Sensor 3)
* P0064 HO2S Heater Control Circuit High (Bank 2 Sensor 3)
* P0065 Air Assisted Injector Control Range/Performance
* P0066 Air Assisted Injector Control Circuit or Circuit Low
* P0067 Air Assisted Injector Control Circuit High
* P0068 MAP/MAF - Throttle Position Correlation
* P0069 Manifold Absolute Pressure - Barometric Pressure Correlation
* P0070 Ambient Air Temperature Sensor Circuit
* P0071 Ambient Air Temperature Sensor Range/Performance
* P0072 Ambient Air Temperature Sensor Circuit Low Input
* P0073 Ambient Air Temperature Sensor Circuit High Input
* P0074 Ambient Air Temperature Sensor Circuit Intermittent
* P0075 Intake Valve Control Solenoid Circuit (Bank 1)
* P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)
* P0077 Intake Valve Control Solenoid Circuit High (Bank 1)
* P0078 Exhaust Valve Control Solenoid Circuit (Bank 1)
* P0079 Exhaust Valve Control Solenoid Circuit Low (Bank 1)
* P0080 Exhaust Valve Control Solenoid Circuit High (Bank 1)
* P0081 Intake valve Control Solenoid Circuit (Bank 2)
* P0082 Intake Valve Control Solenoid Circuit Low (Bank 2)
* P0083 Intake Valve Control Solenoid Circuit High (Bank 2)
* P0084 Exhaust Valve Control Solenoid Circuit (Bank 2)
* P0085 Exhaust Valve Control Solenoid Circuit Low (Bank 2)
* P0086 Exhaust Valve Control Solenoid Circuit High (Bank 2)
* P0087 Fuel Rail/System Pressure - Too Low
* P0088 Fuel Rail/System Pressure - Too High
* P0089 Fuel Pressure Regulator 1 Performance
* P0090 Fuel Pressure Regulator 1 Control Circuit
* P0091 Fuel Pressure Regulator 1 Control Circuit Low
* P0092 Fuel Pressure Regulator 1 Control Circuit High
* P0093 Fuel System Leak Detected - Large Leak
* P0094 Fuel System Leak Detected - Small Leak
* P0095 Intake Air Temperature Sensor 2 Circuit
* P0096 Intake Air Temperature Sensor 2 Circuit Range/Performance
* P0097 Intake Air Temperature Sensor 2 Circuit Low
* P0098 Intake Air Temperature Sensor 2 Circuit High
* P0099 Intake Air Temperature Sensor 2 Circuit Intermittent/Erratic
- buci_vectra
C - Generic OBD-II Chassis Codes
C0000 - Vehicle Speed Information Circuit Malfunction
C0035 - Left Front Wheel Speed Circuit Malfunction
C0040 - Right Front Wheel Speed Circuit Malfunction
C0041 - Right Front Wheel Speed Sensor Circuit Range/Performance (EBCM)
C0045 - Left Rear Wheel Speed Circuit Malfunction
C0046 - Left Rear Wheel Speed Sensor Circuit Range/Performance (EBCM)
C0050 - Right Rear Wheel Speed Circuit Malfunction
C0051 - LF Wheel Speed Sensor Circuit Range/Performance (EBCM)
C0060 - Left Front ABS Solenoid #1 Circuit Malfunction
C0065 - Left Front ABS Solenoid #2 Circuit Malfunction
C0070 - Right Front ABS Solenoid #1 Circuit Malfunction
C0075 - Right Front ABS Solenoid #2 Circuit Malfunction
C0080 - Left Rear ABS Solenoid #1 Circuit Malfunction
C0085 - Left Rear ABS Solenoid #2 Circuit Malfunction
C0090 - Right Rear ABS Solenoid #1 Circuit Malfunction
C0095 - Right Rear ABS Solenoid #2 Circuit Malfunction
C0110 - Pump Motor Circuit Malfunction
C0121 - Valve Relay Circuit Malfunction
C0128 - Low Brake Fluid Circuit Low
C0141 - Left TCS Solenoid #1 Circuit Malfunction
C0146 - Left TCS Solenoid #2 Circuit Malfunction
C0151 - Right TCS Solenoid #1 Circuit Malfunction
C0156 - Right TCS Solenoid #2 Circuit Malfunction
C0161 - ABS/TCS Brake Switch Circuit Malfunction
C0221 - Right Front Wheel Speed Sensor Circuit Open
C0222 - Right Front Wheel Speed Signal Missing
C0223 - Right Front Wheel Speed Signal Erratic
C0225 - Left Front Wheel Speed Sensor Circuit Open
C0226 - Left Front Wheel Speed Signal Missing
C0227 - Left Front Wheel Speed Signal Erratic
C0229 - Drop Out of Front Wheel Speed Signals
C0235 - Rear Wheel Speed Signal Circuit Open
C0236 - Rear Wheel Speed Signal Circuit Missing
C0237 - Rear Wheel Speed Signal Erratic
C0238 - Wheel Speed Mismatch
C0241 - EBCM Control Valve Circuit
C0245 - Wheel Speed Sensor Frequency Error
C0254 - EBCM Control Valve Circuit
C0265 - EBCM Relay Circuit
C0266 - EBCM Relay Circuit
C0267 - Pump Motor Circuit Open/Shorted
C0268 - Pump Motor Circuit Open/Shorted
C0269 - Excessive Dump/Isolation Time
C0271 - EBCM Malfunction
C0272 - EBCM Malfunction
C0273 - EBCM Malfunction
C0274 - Excessive Dump/Isolation Time
C0279 - Powertrain Configuration Not Valid
C0281 - Brake Switch Circuit
C0283 - Traction Switch Shorted to Ground
C0284 - EBCM Malfunction
C0286 - ABS Indicator Lamp Circuit Shorted to B+
C0287 - Delivered Torque Circuit
C0288 - Brake Warning Lamp Circuit Shorted to B+
C0290 - Lost Communications With PCM
C0292 - Lost Communications With PCM
C0291 - Lost Communications With BCM
C0297 - Powertrain Configuration Data Not Received
C0298 - Powertrain Indicated Traction Control Malfunction
C0300 - Rear Speed Sensor Malfunction
C0305 - Front Speed Sensor Malfunction
C0306 - Motor A or B Circuit
C0308 - Motor A/B Circuit Low
C0309 - Motor A/B Circuit High
C0310 - Motor A/B Circuit Open
C0315 - Motor Ground Circuit Open
C0321 - Transfer Case Lock Circuit
C0323 - T-Case Lock Circuit Low
C0324 - T-Case Lock Circuit High
C0327 - Encoder Circuit Malfunction
C0357 - Park Switch Circuit High
C0359 - Four Wheel Drive Low Range (4LO) Discrete Output Circuit
C0362 - 4LO Discrete Output Circuit High
C0367 - Front Axle Control Circuit High
C0374 - General System Malfunction
C0376 - Front/Rear Shaft Speed Mismatch
C0379 - Front Axle System
C0387 - Unable to Perform Shift
C0472 - Steering Handwheel Speed Sensor Signal V Low
C0473 - Steering Handwheel Speed Sensor Signal V High
C0495 - EVO Tracking Error
C0498 - Steering Assist Control Actuator Feed Circuit Low
C0499 - Steering Assist Control Solenoid Feed Circuit High
C0503 - Steering Assist Control Solenoid Return Circuit Low
C0504 - Steering Assist Control Solenoid Return Circuit High
C0550 - ECU Malfunction - internal write / checksum malfunction
C0559 - EEPROM Checksum Error
C0563 - Calibration ROM Checksum Error
C0577 - Left Front Solenoid Circuit Low
C0578 - Left Front Solenoid Circuit High
C0579 - Left Front Solenoid Circuit Open
C0582 - Right Front Solenoid Circuit Low
C0583 - Right Front Solenoid Circuit High
C0584 - Right Front Solenoid Circuit Open
C0587 - Left Rear Solenoid Circuit Low
C0588 - Left Rear Solenoid Circuit High
C0589 - Left Rear Solenoid Circuit Open
C0592 - Right Rear Solenoid Circuit Low
C0593 - Right Rear Solenoid Circuit High
C0594 - Right Rear Solenoid Circuit Open
C0611 - VIN Information Error
C0615 - Left Front Position Sensor Malfunction
C0620 - Right Front Position Sensor Malfunction
C0625 - Left Rear Position Sensor Malfunction
C0628 - Level Control Position Sensor Circuit High
C0630 - Right Rear Position Sensor Malfunction
C0635 - Left Front Normal Force Circuit Malfunction
C0638 - Left Front Normal Force Circuit High
C0640 - Right Front Normal Force Circuit Malfunction
C0643 - Right Front Normal Force Circuit High
C0655 - Level Control Compressor Relay Malfunction
C0657 - Level Control Compressor Circuit Low
C0658 - Level Control Compressor Circuit High
C0660 - Level Control Exhaust Valve Circuit Malfunction
C0662 - Level Control Exhaust Valve Circuit Low
C0663 - Level Control Exhaust Valve Circuit High
C0665 - Chassis Pitch Signal Circuit
C0690 - Damper Control Relay Circuit Malfunction
C0691 - Damper Control Relay Circuit Range
C0693 - Damper Control Relay Circuit High
C0695 - Position Sensor Overcurrent (8 volt supply)
C0696 - Position Sensor Overcurrent (5 volt supply)
C0710 - Steering Position Signal Malfunction
C0750 - Tire Pressure Monitor (TPM) system sensor not transmitting
C0755 - Tire Pressure Monitor (TPM) system sensor not transmitting
C0760 - Tire Pressure Monitor (TPM) system sensor not transmitting
C0765 - Tire Pressure Monitor (TPM) system sensor not transmitting
C0800 - Device Power #1 Circuit Malfunction
C0896 - Electronic Suspension Control (ESC) voltage is outside the normal range of 9 to 15.5 volts
- buci_vectra
NETWORK ERROR CODES
U0001 High Speed CAN Communication Bus
U0002 High Speed CAN Communication Bus Performance
U0003 High Speed CAN Communication Bus (+) Open
U0004 High Speed CAN Communication Bus (+) Low
U0005 High Speed CAN Communication Bus (+) High
U0006 High Speed CAN Communication Bus (-) Open
U0007 High Speed CAN Communication Bus (-) Low
U0008 High Speed CAN Communication Bus (-) High
U0009 High Speed CAN Communication Bus (-) shorted to Bus (+)
U0010 Medium Speed CAN Communication Bus
U0011 Medium Speed CAN Communication Bus Performance
U0012 Medium Speed CAN Communication Bus (+) Open
U0013 Medium Speed CAN Communication Bus (+) Low
U0014 Medium Speed CAN Communication Bus (+) High
U0015 Medium Speed CAN Communication Bus (-) Open
U0016 Medium Speed CAN Communication Bus (-) Low
U0017 Medium Speed CAN Communication Bus (-) High
U0018 Medium Speed CAN Communication Bus (-) shorted to Bus (+)
U0019 Low Speed CAN Communication Bus
U0020 Low Speed CAN Communication Bus Performance
U0021 Low Speed CAN Communication Bus (+) Open
U0022 Low Speed CAN Communication Bus (+) Low
U0023 Low Speed CAN Communication Bus (+) High Electrónica del automóvil On Board Diagnostic II
29
U0024 Low Speed CAN Communication Bus (-) Open
U0025 Low Speed CAN Communication Bus (-) Low
U0026 Low Speed CAN Communication Bus (-) High
U0027 Low Speed CAN Communication Bus (-) shorted to Bus (+)
U0028 Vehicle Communication Bus A
U0029 Vehicle Communication Bus A Performance
U0030 Vehicle Communication Bus A (+) Open
U0031 Vehicle Communication Bus A (+) Low
U0032 Vehicle Communication Bus A (+) High
U0033 Vehicle Communication Bus A (-) Open
U0034 Vehicle Communication Bus A (-) Low
U0035 Vehicle Communication Bus A (-) High
U0036 Vehicle Communication Bus A (-) shorted to Bus A (+)
U0037 Vehicle Communication Bus B
U0038 Vehicle Communication Bus B Performance
U0039 Vehicle Communication Bus B (+) Open
U0040 Vehicle Communication Bus B (+) Low
U0041 Vehicle Communication Bus B (+) High
U0042 Vehicle Communication Bus B (-) Open
U0043 Vehicle Communication Bus B (-) Low
U0044 Vehicle Communication Bus B (-) High
U0045 Vehicle Communication Bus B (-) shorted to Bus B (+)
U0046 Vehicle Communication Bus C
U0047 Vehicle Communication Bus C Performance
U0048 Vehicle Communication Bus C (+) Open
U0049 Vehicle Communication Bus C (+) Low
U0050 Vehicle Communication Bus C (+) High
U0051 Vehicle Communication Bus C (-) Open
U0052 Vehicle Communication Bus C (-) Low
U0053 Vehicle Communication Bus C (-) High
U0054 Vehicle Communication Bus C (-) shorted to Bus C (+)
U0055 Vehicle Communication Bus D
U0056 Vehicle Communication Bus D Performance
U0057 Vehicle Communication Bus D (+) Open
U0058 Vehicle Communication Bus D (+) Low
U0059 Vehicle Communication Bus D (+) High
U0060 Vehicle Communication Bus D (-) Open
U0061 Vehicle Communication Bus D (-) Low
U0062 Vehicle Communication Bus D (-) High
U0063 Vehicle Communication Bus D (-) shorted to Bus D (+)
U0064 Vehicle Communication Bus E
U0065 Vehicle Communication Bus E Performance
U0066 Vehicle Communication Bus E (+) Open
U0067 Vehicle Communication Bus E (+) Low
U0068 Vehicle Communication Bus E (+) High
U0069 Vehicle Communication Bus E (-) Open
U0070 Vehicle Communication Bus E (-) Low
U0071 Vehicle Communication Bus E (-) High
U0072 Vehicle Communication Bus E (-) shorted to Bus E (+)
U0073 Control Module Communication Bus Off
U0074 Reserved by Document
U0075 Reserved by Document
U0076 Reserved by Document
U0077 Reserved by Document
U0078 Reserved by Document
U0079 Reserved by Document
U0080 Reserved by Document
U0081 Reserved by Document
U0082 Reserved by Document
U0083 Reserved by Document Electrónica del automóvil On Board Diagnostic II
30
U0084 Reserved by Document
U0085 Reserved by Document
U0086 Reserved by Document
U0087 Reserved by Document
U0088 Reserved by Document
U0089 Reserved by Document
U0090 Reserved by Document
U0091 Reserved by Document
U0092 Reserved by Document
U0093 Reserved by Document
U0094 Reserved by Document
U0095 Reserved by Document
U0096 Reserved by Document
U0097 Reserved by Document
U0098 Reserved by Document
U0099 Reserved by Document
U0100 Lost Communication With ECM/PCM "A"
U0101 Lost Communication with TCM
U0102 Lost Communication with Transfer Case Control Module
U0103 Lost Communication With Gear Shift Module
U0104 Lost Communication With Cruise Control Module
U0105 Lost Communication With Fuel Injector Control Module
U0106 Lost Communication With Glow Plug Control Module
U0107 Lost Communication With Throttle Actuator Control Module
U0108 Lost Communication With Alternative Fuel Control Module
U0109 Lost Communication With Fuel Pump Control Module
U0110 Lost Communication With Drive Motor Control Module
U0111 Lost Communication With Battery Energy Control Module "A"
U0112 Lost Communication With Battery Energy Control Module "B"
U0113 Lost Communication With Emissions Critical Control Information
U0114 Lost Communication With Four-Wheel Drive Clutch Control Module
U0115 Lost Communication With ECM/PCM "B"
U0116 Reserved by Document
U0117 Reserved by Document
U0118 Reserved by Document
U0119 Reserved by Document
U0120 Reserved by Document
U0121 Lost Communication With Anti-Lock Brake System (ABS) Control Module
U0122 Lost Communication With Vehicle Dynamics Control Module
U0123 Lost Communication With Yaw Rate Sensor Module
U0124 Lost Communication With Lateral Acceleration Sensor Module
U0125 Lost Communication With Multi-axis Acceleration Sensor Module
U0126 Lost Communication With Steering Angle Sensor Module
U0127 Lost Communication With Tire Pressure Monitor Module
U0128 Lost Communication With Park Brake Control Module
U0129 Lost Communication With Brake System Control Module
U0130 Lost Communication With Steering Effort Control Module
U0131 Lost Communication With Power Steering Control Module
U0132 Lost Communication With Ride Level Control Module
U0133 Reserved by Document
U0134 Reserved by Document
U0135 Reserved by Document
U0136 Reserved by Document
U0137 Reserved by Document
U0138 Reserved by Document
U0139 Reserved by Document
U0140 Lost Communication With Body Control Module
U0141 Lost Communication With Body Control Module "A"
U0142 Lost Communication With Body Control Module "B"
U0143 Lost Communication With Body Control Module "C" Electrónica del automóvil On Board Diagnostic II
31
U0144 Lost Communication With Body Control Module "D"
U0145 Lost Communication With Body Control Module "E"
U0146 Lost Communication With Gateway "A"
U0147 Lost Communication With Gateway "B"
U0148 Lost Communication With Gateway "C"
U0149 Lost Communication With Gateway "D"
U0150 Lost Communication With Gateway "E"
U0151 Lost Communication With Restraints Control Module
U0152 Lost Communication With Side Restraints Control Module
U0153 Lost Communication With Side Restraints Control Module
U0154 Lost Communication With Restraints Occupant Sensing Control Module
U0155 Lost Communication With Instrument Panel Cluster (IPC) Control Module
U0156 Lost Communication With Information Center "A"
U0157 Lost Communication With Information Center "B"
U0158 Lost Communication With Head Up Display
U0159 Lost Communication With Parking Assist Control Module
U0160 Lost Communication With Audible Alert Control Module
U0161 Lost Communication With Compass Module
U0162 Lost Communication With Navigation Display Module
U0163 Lost Communication With Navigation Control Module
U0164 Lost Communication With HVAC Control Module
U0165 Lost Communication With HVAC Control Module
U0166 Lost Communication With Auxiliary Heater Control Module
U0167 Lost Communication With Vehicle Immobilizer Control Module
U0168 Lost Communication With Vehicle Security Control Module
U0169 Lost Communication With Sunroof Control Module
U0170 Lost Communication With "Restraints System Sensor A"
U0171 Lost Communication With "Restraints System Sensor B"
U0172 Lost Communication With "Restraints System Sensor C"
U0173 Lost Communication With "Restraints System Sensor D"
U0174 Lost Communication With "Restraints System Sensor E"
U0175 Lost Communication With "Restraints System Sensor F"
U0176 Lost Communication With "Restraints System Sensor G"
U0177 Lost Communication With "Restraints System Sensor H"
U0178 Lost Communication With "Restraints System Sensor I"
U0179 Lost Communication With "Restraints System Sensor J"
U0180 Lost Communication With Automatic Lighting Control Module
U0181 Lost Communication With Headlamp Leveling Control Module
U0182 Lost Communication With Lighting Control Module
U0183 Lost Communication With Lighting Control Module
U0184 Lost Communication With Radio
U0185 Lost Communication With Antenna Control Module
U0186 Lost Communication With Audio Amplifier
U0187 Lost Communication With Digital Disc Player/Changer Module "A"
U0188 Lost Communication With Digital Disc Player/Changer Module "B"
U0189 Lost Communication With Digital Disc Player/Changer Module "C"
U0190 Lost Communication With Digital Disc Player/Changer Module "D"
U0191 Lost Communication With Television
U0192 Lost Communication With Personal Computer
U0193 Lost Communication With "Digital Audio Control Module A"
U0194 Lost Communication With "Digital Audio Control Module B"
U0195 Lost Communication With Subscription Entertainment Receiver Module
U0196 Lost Communication With Rear Seat Entertainment Control Module
U0197 Lost Communication With Telephone Control Module
U0198 Lost Communication With Telematic Control Module
U0199 Lost Communication With "Door Control Module A"
U0200 Lost Communication With "Door Control Module B"
U0201 Lost Communication With "Door Control Module C"
U0202 Lost Communication With "Door Control Module D"
U0203 Lost Communication With "Door Control Module E" Electrónica del automóvil On Board Diagnostic II
32
U0204 Lost Communication With "Door Control Module F"
U0205 Lost Communication With "Door Control Module G"
U0206 Lost Communication With Folding Top Control Module
U0207 Lost Communication With Movable Roof Control Module
U0208 Lost Communication With "Seat Control Module A"
U0209 Lost Communication With "Seat Control Module B"
U0210 Lost Communication With "Seat Control Module C"
U0211 Lost Communication With "Seat Control Module D"
U0212 Lost Communication With Steering Column Control Module
U0213 Lost Communication With Mirror Control Module
U0214 Lost Communication With Remote Function Actuation
U0215 Lost Communication With "Door Switch A"
U0216 Lost Communication With "Door Switch B"
U0217 Lost Communication With "Door Switch C"
U0218 Lost Communication With "Door Switch D"
U0219 Lost Communication With "Door Switch E"
U0220 Lost Communication With "Door Switch F"
U0221 Lost Communication With "Door Switch G"
U0222 Lost Communication With "Door Window Motor A"
U0223 Lost Communication With "Door Window Motor B"
U0224 Lost Communication With "Door Window Motor C"
U0225 Lost Communication With "Door Window Motor D"
U0226 Lost Communication With "Door Window Motor E"
U0227 Lost Communication With "Door Window Motor F"
U0228 Lost Communication With "Door Window Motor G"
U0229 Lost Communication With Heated Steering Wheel Module
U0230 Lost Communication With Rear Gate Module
U0231 Lost Communication With Rain Sensing Module
U0232 Lost Communication With Side Obstacle Detection Control Module
U0233 Lost Communication With Side Obstacle Detection Control Module
U0234 Lost Communication With Convenience Recall Module
U0235 Lost Communication With Cruise Control Front Distance Range Sensor
U0300 Internal Control Module Software Incompatibility
U0301 Software Incompatibility with ECM/PCM
U0302 Software Incompatibility with Transmission Control Module
U0303 Software Incompatibility with Transfer Case Control Module
U0304 Software Incompatibility with Gear Shift Control Module
U0305 Software Incompatibility with Cruise Control Module
U0306 Software Incompatibility with Fuel Injector Control Module
U0307 Software Incompatibility with Glow Plug Control Module
U0308 Software Incompatibility with Throttle Actuator Control Module
U0309 Software Incompatibility with Alternative Fuel Control Module
U0310 Software Incompatibility with Fuel Pump Control Module
U0311 Software Incompatibility with Drive Motor Control Module
U0312 Software Incompatibility with Battery Energy Control Module A
U0313 Software Incompatibility with Battery Energy Control Module B
U0314 Software Incompatibility with Four-Wheel Drive Clutch Control Module
U0315 Software Incompatibility with Anti-Lock Brake System Control Module
U0316 Software Incompatibility with Vehicle Dynamics Control Module
U0317 Software Incompatibility with Park Brake Control Module
U0318 Software Incompatibility with Brake System Control Module
U0319 Software Incompatibility with Steering Effort Control Module
U0320 Software Incompatibility with Power Steering Control Module
U0321 Software Incompatibility with Ride Level Control Module
U0322 Software Incompatibility with Body Control Module
U0323 Software Incompatibility with Instrument Panel Control Module
U0324 Software Incompatibility with HVAC Control Module
U0325 Software Incompatibility with Auxiliary Heater Control Module
U0326 Software Incompatibility with Vehicle Immobilizer Control Module
U0327 Software Incompatibility with Vehicle Security Control Module Electrónica del automóvil On Board Diagnostic II
33
U0328 Software Incompatibility with Steering Angle Sensor Module
U0329 Software Incompatibility with Steering Column Control Module
U0330 Software Incompatibility with Tire Pressure Monitor Module
U0331 Software Incompatibility with Body Control Module "A"
U0400 Invalid Data Received
U0401 Invalid Data Received From ECM/PCM
U0402 Invalid Data Received From Transmission Control Module
U0403 Invalid Data Received From Transfer Case Control Module
U0404 Invalid Data Received From Gear Shift Control Module
U0405 Invalid Data Received From Cruise Control Module
U0406 Invalid Data Received From Fuel Injector Control Module
U0407 Invalid Data Received From Glow Plug Control Module
U0408 Invalid Data Received From Throttle Actuator Control Module
U0409 Invalid Data Received From Alternative Fuel Control Module
U0410 Invalid Data Received From Fuel Pump Control Module
U0411 Invalid Data Received From Drive Motor Control Module
U0412 Invalid Data Received From Battery Energy Control Module A
U0413 Invalid Data Received From Battery Energy Control Module B
U0414 Invalid Data Received From Four-Wheel Drive Clutch Control Module
U0415 Invalid Data Received From Anti-Lock Brake System Control Module
U0416 Invalid Data Received From Vehicle Dynamics Control Module
U0417 Invalid Data Received From Park Brake Control Module
U0418 Invalid Data Received From Brake System Control Module
U0419 Invalid Data Received From Steering Effort Control Module
U0420 Invalid Data Received From Power Steering Control Module
U0421 Invalid Data Received From Ride Level Control Module
U0422 Invalid Data Received From Body Control Module
U0423 Invalid Data Received From Instrument Panel Control Module
U0424 Invalid Data Received From HVAC Control Module
U0425 Invalid Data Received From Auxiliary Heater Control Module
U0426 Invalid Data Received From Vehicle Immobilizer Control Module
U0427 Invalid Data Received From Vehicle Security Control Module
U0428 Invalid Data Received From Steering Angle Sensor Module
U0429 Invalid Data Received From Steering Column Control Module
U0430 Invalid Data Received From Tire Pressure Monitor Module
U0431 Invalid Data Received From Body Control Module "A"
29
30
31
32
33
- franticek6
- Auto: Zafira A
Astra H Chybové kódy
Vozidiel kódy
Napätie batérie je nízka B0132 C-118
B0132 Napätie batérie vysokej C-118
B0158 snímač vonkajšej teploty obvod nízkeho napätia DIS (info displej) C-016
B0158 Mimo okruh teplotného senzora Otvoriť alebo vysoké napätie DIS (info displej) C-016
B0283 zadné okno Porucha vykurovacieho okruhu vykurovania, vetrania a klimatizácie Systém B-016
B1000 Vymeňte elektronickou riadiacou jednotkou (ECU) - zlyhanie hardvéru C-002
B1000 Vymeňte elektronickou riadiacou jednotkou (ECU) - EEPROM Chyba C-002
B1000 ECU Porucha C-002
B1000 Nahradiť Elektronická riadiaca jednotka (ECU) C-002
B1001 Programovanie Chyba hardvéru a softvéru B-003
B1001 Ľavá ruka disk / na pravej strane chyba konfigurácie C-002
B1001 Elektronická riadiaca jednotka (ECU) nie je naprogramovaný hardvéru a softvéru B-003
B1001 airbag Riadiaca jednotka nie je uzamknutá hardvéru a softvéru B-003
B1001 Elektronická riadiaca jednotka (ECU) nie je kalibrovaný hardvéru a softvéru B-003
B1001 variant konfigurácie nie je naprogramovaný hardvéru a softvéru B-004
B1001 variant kódovanie nie je naprogramovaný hardvéru a softvéru B-004
B1001 Identifikačné číslo vozidla nie je naprogramovaný hardvéru a softvéru B-005
B1001 Elektronická riadiaca jednotka nie je naprogramovaný (ECU), hardvéru a softvéru B-003
B1001 Program Elektronická riadiaca jednotka (ECU), hardvéru a softvéru B-003
B1006 Vymeňte elektronickou riadiacou jednotkou (ECU) C-002
B1009 Program Elektronická riadiaca jednotka (ECU), hardvéru a softvéru B-003
B1016 Identifikačné číslo vozidla nie je naprogramovaný hardvéru a softvéru B-005
B1019 Elektronická riadiaca jednotka (ECU) pri dodaní hardvéru a softvéru B-003
B1325 systém napätie vysokého napätia B-003
B1325 systémové napätie Low Voltage B-003
B1375 Switched systémové napätie (zapaľovanie ON) nie je vierohodná sa môže signalizovať B-005
B1385 Terminál 15A okruh Nefunkčné B-004
B1390 Comfort Záverečný okruh nízkeho napätia napájania Okno Lifter C-009
B1395 chod motora signálu nízkeho napätia EHPS ods Elektrohydraulický posilňovač riadenia) C-002
B1420 Napájací obvod pre nízke napätie C-119
B1420 Napájacie obvod vysokého napätia C-119
B1421 Napájanie Rozsah signálu / výkon C-119
B1428 Štartovací relé obvod Nefunkčné C-122
B1441 Spínané napätie systému (zapaľovania ON) obvod vysokého napätia C-120
B1441 Spínané napätie systému (zapaľovania ON) Obvod pre nízke napätie C-120
B1451 príslušenstvo relé obvodu vysokého napätia C-109
B1451 príslušenstvo relé obvodu vysokého napätia alebo otvorený obvod C-109
B1453 Spínané napätie systému (zapaľovania ON) Obvod pre nízke napätie C-120
B1453 Spínané napätie systému (zapaľovania ON) obvod vysokého napätia C-120
B2961 Poloha spínača zapaľovania kľúč Circuit Nefunkčné C-002
B3601 Kľúčové Snímanie relé obvod Nefunkčné AF 17-4 Elektronická 4-stupňová automatická prevodovka C-005
B3644 diaľkové ovládanie na volante Kanál hore prepínače Stuck humanitné univerzite (Zábava hlavná jednotka) C-012
B3644 diaľkové ovládanie na volante kanál odpor prepínače okruhu dosahu / výkon humanitné univerzite (vedúci oddelenia zábavy) C-012
B3645 volant Channel Down prepínače Stuck humanitné univerzite (Zábava hlavná jednotka) C-012
B3645 diaľkové ovládanie na volante Channel Down odporu prepínače okruhu dosahu / výkon humanitné univerzite (vedúci oddelenia zábavy) C-012
B3646 volant Scroll Wheel Právo Stuck humanitné univerzite (Zábava hlavná jednotka) C-012
B3646 volant Scroll Wheel Právo okruh otvorený humanitné univerzite (Zábava hlavná jednotka) C-012
B3646 volant Scroll Wheel Právo odpor obvodu Rozsah / výkon humanitné univerzite (Zábava hlavná jednotka) C-012
B3647 diaľkové ovládanie na volante Hlasové ovládanie prepínač Stuck humanitné univerzite (Zábava hlavná jednotka) C-012
B3647 diaľkové ovládanie na volante Hlasové ovládanie prepínač odpor obvodu Rozsah / výkon humanitné univerzite (Zábava hlavná jednotka) C-012
B3648 diaľkové ovládanie na volante telefón prepínač Stuck humanitné univerzite (Zábava hlavná jednotka) C-012
B3648 diaľkové ovládanie na volante telefón prepínač odpor obvodu Rozsah / výkon humanitné univerzite (Zábava hlavná jednotka) C-012
B3649 volant Scroll Wheel ľavým okruhom Otvoriť humanitné univerzite (Zábava hlavná jednotka) C-012
B3649 volant Rolovacie koliesko vľavo Stuck humanitné univerzite (Zábava hlavná jednotka) C-012
B3649 volant Rolovacie koliesko vľavo odpor obvodu Rozsah / výkon humanitné univerzite (Zábava hlavná jednotka) C-012
C0252 ECU pri dodaní alebo chybné ECU hardvéru a softvéru B-003
C0550 Elektronická riadiaca jednotka nie je naprogramovaný (ECU), hardvéru a softvéru B-003
C0550 Zlá variant konfigurácie Programová alebo chybný ECU hardvéru a softvéru B-003
C0550 Nahradiť Elektronická riadiaca jednotka (ECU) C-002
Variant C0551 konfigurácia nie je naprogramovaný hardvéru a softvéru B-004
C0551 Program Elektronická riadiaca jednotka (ECU), hardvéru a softvéru B-003
C0551 Zlá variant konfigurácie Pripravené hardvéru a softvéru B-004
C0551 variant kódovanie nie je naprogramovaný hardvéru a softvéru B-004
C0551 Identifikačné číslo vozidla nie je naprogramovaný hardvéru a softvéru B-005
C0569 Konfigurácia systému Zlá hardvéru a softvéru B-003
C0800 systémové napätie Low Voltage B-003
C0800 systém napätie vysokého napätia B-003
C0920 Elektronická riadiaca jednotka (ECU) nie je naprogramovaný hardvéru a softvéru B-003
C1523 systém napätie vysokého napätia C-108
C1523 systémové napätie nízke napätie C-108
C1550 Nahradiť Elektronická riadiaca jednotka (ECU) C-002
P0110 CAN-Bus žiadna komunikácia s ECM (Engine Control Module) na vozidlá diagnostický postup B-019
P0115 CAN-Bus žiadna komunikácia s ECM (Engine Control Module) na vozidlá diagnostický postup B-019
P0505 CAN-Bus žiadna komunikácia s ECM (Engine Control Module) na vozidlá diagnostický postup B-019
P0560 systém napätie vysokého napätia C-112
P0560 systémové napätie nízke napätie C-112
P0560 systém High Voltage Input C-113
P0560 systémové napätie mimo rozsah C-113
P0560 batérie Rozsah napätia / výkon C-112
P0560 Systém napätie je príliš vysoké C-113
P0560 systém Nefunkčné napätie C-113
P0560 systémové napätie Low Input C-113
P0601 Nahradiť Elektronická riadiaca jednotka (ECU) C-002
P0601 preprogramovať alebo nahradiť elektronickou riadiacou jednotkou (ECU), hardvéru a softvéru B-003
P0602 Riadiaca jednotka nie je naprogramovaný hardvéru a softvéru B-003
Variant P0602 konfigurácia nie je naprogramovaný hardvéru a softvéru B-004
P0602 Identifikačné číslo vozidla nie je naprogramovaný hardvéru a softvéru B-005
P0602 Riadiaca jednotka Programovanie Chyba hardvéru a softvéru B-003
P0602 pneumatík obvod nie je naprogramovaný hardvéru a softvéru B-003
P0602 Bezpečnostný kód nie je naprogramovaný hardvéru a softvéru B-003
P0602 Program Elektronická riadiaca jednotka (ECU), hardvéru a softvéru B-003
P0602 Injector množstvo nastavení nie je naprogramovaný hardvéru a softvéru B-015
P0603 ECU EEPROM chyby C-002
P0603 nahradiť elektronickou riadiacou jednotkou (ECU) C-002
P0604 Elektronická riadiaca jednotka (ECU) Porucha - Random Access Memory (RAM) C-002
P0604 Nahradiť Elektronická riadiaca jednotka (ECU) C-002
P0605 EPROM Ak C-002
P0605 nahradiť elektronickou riadiacou jednotkou (ECU) C-002
P0606 nahradiť elektronickou riadiacou jednotkou (ECU) C-002
P0606 Kondenzátor Napätie 1 nízkeho napätia C-004
P0606 kondenzátora napätie 1 vysokého napätia C-004
P0606 Elektronická riadiaca jednotka (ECU) - Porucha C-002
P0606 systém High Voltage Input C-113
P0606 riadiaca jednotka Re-Inicializácia C-004
P0610 Riadiaca jednotka Programovanie Chyba hardvéru a softvéru B-003
P0615 Štartovací relé obvod Nefunkčné C-122
P0615 Štartovací relé obvodu vysokého napätia C-122
P0615 Štartovací relé obvodu pre nízke napätie C-122
P0615 Štartovací relé obvod otvorený C-122
P0615 Štartovací relé Powerstage vysoké teploty C-122
P062F Riadiaca jednotka Programovanie Chyba hardvéru a softvéru B-003
Malé množstvo P062F Vstrekovacie učenia Nepodarilo hardvéru a softvéru B-003
P062F Elektronická riadiaca jednotka (ECU) - Porucha C-002
P0631 Identifikačné číslo vozidla nie je naprogramovaný hardvéru a softvéru B-005
P0650 CAN-Bus č Komunikácia s CIM (modul stĺpika riadenia) C-003
P0705 Nahradiť Elektronická riadiaca jednotka (ECU) C-002
P0725 CAN-Bus žiadna komunikácia s ECM (Engine Control Module) na vozidlá diagnostický postup B-019
P0815 diaľkové ovládanie na volante Shift Až Spínač Stuck C-002
P0815 diaľkové ovládanie na volante Shift odpor prepínače okruhu dosahu / výkon MTA (Easytronic) bodu F13-5MTA/F17-5MTA) B-030
P0816 diaľkové ovládanie na volante Shift Down tlačidlami Stuck C-002
P0816 diaľkové ovládanie na volante Shift dole odporu prepínače okruhu dosahu / výkon MTA (Easytronic) bodu F13-5MTA/F17-5MTA) B-030
P1120 CAN-Bus žiadna komunikácia s ECM (Engine Control Module) na vozidlá diagnostický postup B-019
P1560 Spínané napätie systému (zapaľovania ON) signál Porucha (CAN) C-112
P1561 systém napätie vysokého napätia C-112
P1561 systémové napätie nízke napätie C-112
P1562 Nahradiť Elektronická riadiaca jednotka (ECU) C-002
P1564 systémové napätie nízke napätie C-112
P1600 preprogramovať alebo nahradiť elektronickou riadiacou jednotkou (ECU), hardvéru a softvéru B-003
P1600 Nahradiť Elektronická riadiaca jednotka (ECU) C-002
P1602 preprogramovať alebo nahradiť elektronickou riadiacou jednotkou (ECU), hardvéru a softvéru B-003
P1602 Riadiaca jednotka Programovanie Chyba hardvéru a softvéru B-003
P1602 palivového čerpadla paliva Množstvo nastavení nenaučili hardvéru a softvéru B-003
P1602 Malé množstvo vstreku nenaučili hardvéru a softvéru B-003
Variant P1602 konfigurácia nie je naprogramovaný hardvéru a softvéru B-003
P1602 Najvyššia rýchlosť nie je naprogramovaný hardvéru a softvéru B-003
P1603 Nahradiť Elektronická riadiaca jednotka (ECU) C-002
P1604 Nahradiť Elektronická riadiaca jednotka (ECU) C-004
P1606 nahradiť elektronickou riadiacou jednotkou (ECU) C-002
P1622 Nahradiť Elektronická riadiaca jednotka (ECU) C-002
P165A nahradiť elektronickou riadiacou jednotkou (ECU) C-002
P1703 brzdové svetlo prepínač signálu CAN-Bus Nefunkčné C-003
P1711 ľavý predné kolesá Snímač rýchlosti signálu Porucha (CAN) C-003
P1712 Pravý predné kolesá Snímač rýchlosti signálu Porucha (CAN) C-003
P1739 Nahradiť Elektronická riadiaca jednotka (ECU) C-002
P1740 Nahradiť Elektronická riadiaca jednotka (ECU) C-002
P1895 CAN-Bus žiadna komunikácia s ECM (Engine Control Module) na vozidlá diagnostický postup B-019
P1896 CAN-Bus žiadna komunikácia s ECM (Engine Control Module) na vozidlá diagnostický postup B-019
P2638 Nahradiť Elektronická riadiaca jednotka (ECU) C-002
U0001 CAN-Bus Maximálna konfigurácia Zoznam nie je naprogramovaný hardvéru a softvéru B-003
U0009 CAN-Bus Uzol žiadna komunikácia C-005
U0101 CAN-Bus žiadna komunikácia s modulom Transmission Control C-003
U0121 CAN-Bus žiadna komunikácia s ABS / TC C-003
U0140 CAN-Bus č Komunikácia s CIM (modul stĺpika riadenia) C-003
U2100 CAN-Bus (stredná rýchlosť) Komunikácia Porucha C-005
U2100 žiadna komunikácia s CAN-Bus (stredná rýchlosť) C-005
U2100 CAN-Bus Nefunkčné C-005
U2100 CAN-Bus komunikácia Nefunkčné C-005
U2100 CAN Bus Chyba komunikácie C-005
U2100 žiadna komunikácia s CAN-Bus (High Speed) C-005
U2100 žiadna komunikácia s CAN-Bus (nízka rýchlosť) C-005
U2101 CAN-Bus Maximálna konfigurácia Zoznam nie je naprogramovaný hardvéru a softvéru B-003
U2101 CAN-Bus (stredná rýchlosť) Maximálna konfigurácia Zoznam nie je naprogramovaný hardvéru a softvéru B-003
U2101 CAN-Bus (High Speed) Maximálna konfigurácia Zoznam nie je naprogramovaný hardvéru a softvéru B-003
U2101 CAN-Bus (nízka rýchlosť) Maximálna konfigurácia Zoznam nie je naprogramovaný hardvéru a softvéru B-003
U2102 CAN-Bus (stredná rýchlosť) Maximálna konfigurácia Zoznam nie je kompletný hardvéru a softvéru B-003
U2103 CAN-Bus Reset Prekročenie C-005
U2103 žiadna komunikácia s CAN-Bus (High Speed) C-005
U2103 CAN-Bus Circuit Nefunkčné C-005
U2103 CAN-Bus Uzol žiadna komunikácia C-005
U2103 žiadna komunikácia s CAN-Bus (nízka rýchlosť) C-005
U2104 CAN-Bus (High Speed) Reset prekročení C-005
U2104 CAN-Bus Reset prekročení C-005
U2104 CAN-Bus Reset Prekročenie C-005
U2104 CAN-Bus (stredná rýchlosť) Reset pretečeniu C-005
U2105 CAN-Bus žiadna komunikácia s ECM (Engine Control Module) na vozidlá diagnostický postup B-019
U2106 CAN-Bus žiadna komunikácia s modulom Transmission Control C-003
U2106 CAN-Bus č Komunikácia s TCM (Transmission Control Module) C-003
U2107 CAN-Bus č Komunikácia s IPC (nástroj) C-003
U2108 CAN-Bus žiadna komunikácia s ABS / TC C-003
U2108 CAN-Bus č Komunikácia s ABS (Anti-Lock Brake System) C-003
U2108 preprogramovať alebo nahradiť elektronickou riadiacou jednotkou (ECU), hardvéru a softvéru B-003
U2110 CAN-Bus žiadna komunikácia s ABS / ESP C-003
U2111 CAN-Bus č Komunikácia s EPS (elektrický posilňovač riadenia) C-003
U2112 CAN-Bus č Komunikácia s JCD a čiastočne Aktívny systém tlmenia) C-003
U2112 CAN-Bus č Komunikácia s CDC (Continuous Damping Control) C-003
U2113 CAN-Bus č Komunikácia s SDM (prieskum a diagnostiku modul, airbag) C-003
U2113 CAN-Bus č Komunikácia s SDM (airbag) C-003
U2116 CAN-Bus č Komunikácia s IPC (nástroj) C-003
U2116 CAN-BUS žiadna komunikácia s IPC (nástroj) C-003
U2117 CAN-Bus žiadna komunikácia s Info-Display C-121
U2117 CAN-Bus č Komunikácia s DIS (Display) C-121
U2120 CAN-Bus žiadna komunikácia s AHL (svetlometov Vyrovnávacia zariadenia) C-003
U2127 CAN-Bus č Komunikácia s ECC (Electronic Climate Control) C-003
U2139 CAN-Bus č Komunikácia s CIM (modul stĺpika riadenia) C-003
U2140 CAN-Bus č Komunikácia s CIM (modul stĺpika riadenia) C-003
U2140 CAN-Bus č Komunikácia s UEC ods underhood elektrické centrum) C-003
U2141 CAN-Bus č Komunikácia s REC (zadné elektrické centrum) C-003
U2143 CAN-Bus č Komunikácia s SAS (riadiaci uhol Sensor) C-003
U2144 CAN-BUS žiadna komunikácia s ACC (Adaptive Cruise Control) C-003
U2145 CAN-Bus č Komunikácia s PAS (Park Pilot) C-003
U2146 CAN-Bus č Komunikácia s SLM (Radenie Module) C-003
U2147 CAN-Bus č Komunikácia s AHS (Pridať na ohrievač) C-003
U2149 CAN-Bus č Komunikácia s TPMS ods Systém monitorovania tlaku v pneumatikách), C-003
U2173 CAN-Bus č Komunikácia s ETSO (Open & Start) C-003
U2174 CAN-Bus č Komunikácia s EHS (elektrický ohrievač System) C-003
U2174 CAN-Bus č Komunikácia s AHS (Pridať na ohrievač) C-003
U2181 CAN-Bus č Komunikácia s elektrohydraulickým Hardtop C-003
U2201 CAN-Bus č Komunikácia s humanitné univerzite (Zábava hlavná jednotka) C-003
U2202 CAN-Bus č Komunikácia s CDC (CD-menič) C-003
U2206 CAN-Bus č Komunikácia s DIS (Display) C-003
U2207 CAN-Bus č Komunikácia s UHP (Portál pre mobilný telefón) C-003
U2208 CAN-Bus č Komunikácia s ECC (Electronic Climate Control) C-003
U2213 CAN-Bus žiadna komunikácia s DAB (Digital Audio Broadcast) C-003
U2215 nahradiť elektronické ovládanie
Vozidiel kódy
Opel Zafira y20dth
MB E 320 CDI W 211
MB S 320 CDI W 221 AMG
Opel Sintra x22dth - ex
Skoda 105 L -ex
nie som na fejsbúku
MB E 320 CDI W 211
Skoda 105 L -ex
nie som na fejsbúku
- franticek6
- Auto: Zafira A
Tu som našiel komplet
http://www.astra-g-anleitungen.de/Allge ... liste.html
Opel Zafira y20dth
MB E 320 CDI W 211
Skoda 105 L -ex
nie som na fejsbúku
MB E 320 CDI W 211
Skoda 105 L -ex
nie som na fejsbúku
- franticek6
- Auto: Zafira A
Re: ODBII Error codes
P0005 Fuel Shutoff Valve C ontrol Circuit/Open
P0006 Fuel Shutoff Valve C ontrol Circuit Low
P0007 Fuel Shutoff Valve C ontrol Circuit H igh
P0008 Engine Position System Performance (Bank1)
P0009 Engine Position System Performance (Bank2)
P0010 A Camshaft Position Actuator Circuit (Bank1)
P0011 A Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
P0012 A Camshaft Position - Timing O ver-Retarded (Bank 1)
P0013 B Camshaft Position - Actuator Circuit (Bank1)
P0014 B Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
P0015 B Camshaft Position - Timing O ver-Retarded (Bank 1)
P0016 Crankshaft Position Camshaft Position Correlation (Bank 1 Sensor A)
P0017 Crankshaft Position Camshaft Position Correlation (Bank 1 Sensor B)
P0018 Crankshaft Position Camshaft Position Correlation (Bank 2 Sensor A)
P0019 Crankshaft Position Camshaft Position Correlation (Bank 2 Sensor B)
P0020 A Camshaft Position Actuator Circuit (Bank 2)
P0021 A Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
P0022 A Camshaft Position - Timing O ver-Retarded (Bank 2)
P0023 B Camshaft Position - Actuator Circuit (Bank 2)
P0024 B Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
P0025 B Camshaft Position - Timing O ver-Retarded (Bank 2)
P0026 Intake Valve Control Solenoid Circuit Range/Performance (Bank 1)
P0027 Exhaust Valve Control Solenoid Circuit Range/Performance (Bank 1)
P0028 Intake Valve Control Solenoid Circuit Range/Performance (Bank 2)
P0029 Exhaust Valve Control Solenoid Circuit Range/Performance (Bank 2)
P0036 HO2S Heater Control C ircuit (Bank 1 Sensor 2)
P0040 O2 Sensor Signals Swapped Bank 1 Sensor 1/ Bank 2 Sensor 1
P0041 O2 Sensor Signals Swapped Bank 1 Sensor 2/ Bank 2 Sensor 2
P0045 Turbo/Super Charger Boost Control Solenoid Circuit/Open
P0046 Turbo/Super Charger Boost Control Solenoid Circuit Range/Performance
P0047 Turbo/Super Charger Boost Control Solenoid Circuit Low
P0048 Turbo/Super Charger Boost Control Solenoid Circuit High
P0049 Turbo/Super Charger Turbine Overspeed
P0053 HO2S Heater Resistance (Bank 1 Sensor 1)
P0054 HO2S Heater Resistance (Bank 1 Sensor 2)
P0055 HO2S Heater Resistance (Bank 1 Sensor 3)
P0059 HO2S Heater Resistance (Bank 2 Sensor 1)
P0060 HO2S Heater Resistance (Bank 2 Sensor 2)
P0061 HO2S Heater Resistance (Bank 2 Sensor 3)
P0062 HO2S Heater Control C ircuit (Bank 2 Sensor 3)
P0068 MAP/MAF Throttle Position Correlation
P0069 Manifold Absolute Pressure Barometric Pressure Correlation
P0072 Ambient Air Temperature Sensor C ircuit Low
P0080 Exhaust Valve C ontrol Solenoid C ircuit High (Bank 1)
P0081 Intake Valve Control Solenoid Circuit (Bank 2)
P0086 Exhaust Valve C ontrol Solenoid C ircuit High (Bank 2)
P0090 Fuel Pressure Regulator 1 C ontrol Circuit
P0091 Fuel Pressure Regulator 1 C ontrol Circuit Low
P0092 Fuel Pressure Regulator 1 C ontrol Circuit High
P0093 Fuel System Leak Detected Large Leak
P0094 Fuel System Leak Detected Small Leak
P0095 Intake Air Temperature Sensor 2 C ircuit
P0096 Intake Air Temperature Sensor 2 C ircuit Range/Performance
P0097 Intake Air Temperature Sensor 2 C ircuit Low
P0099 Intake Air Temperature Sensor 2 C ircuit Intermittent/Erratic
P0100 Mass or Volume Air Flow Circuit Malfunction
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0102 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0104 Mass or Volume Air Flow Circuit Intermittent
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0110 Intake Air Temperature Circuit Malfunction
P0111 Intake Air Temperature Circuit Range/Performance Problem
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0114 Intake Air Temperature Circuit Intermittent
P0115 Engine Coolant Temperature Circuit Malfunction
P0116 Engine Coolant Temperature Circuit Range/Performance Problem
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0119 Engine Coolant Temperature Circuit Intermittent
P0120 Throttle Position Sensor/Switch A Circuit Malfunction
P0121 Throttle Position Sensor/Switch A Circuit Range/Performance Problem
P0122 Throttle Position Sensor/Switch A Circuit Low Input
P0123 Throttle Position Sensor/Switch A Circuit High Input
P0124 Throttle Position Sensor/Switch A Circuit Intermittent
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control; ECT Excessive Time to Closed Loop Fuel Control
P0126 Insufficient Coolant Temperature for Stable Operation
P0128 Coolant Thermostat Malfunction
P0129 Barometric Pressure Too Low
P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
P0131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0142 O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
P0143 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)
P0144 O2 Sensor Circuit High Voltage (Bank 1 Sensor 3)
P0145 O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)
P0146 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
P0147 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
P0150 O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
P0151 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0156 O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0157 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158 O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0162 O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164 O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165 O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
P0167 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
P0170 Fuel Trim Malfunction (Bank 1)
P0171 Fuel Trim too Lean (Bank 1)
P0172 Fuel Trim too Rich (Bank 1)
P0173 Fuel Trim Malfunction (Bank 2)
P0174 Fuel Trim too Lean (Bank 2)
P0175 Fuel Trim too Rich (Bank 2)
P0176 Fuel Composition Sensor Circuit Malfunction
P0177 Fuel Composition Sensor Circuit Range/Performance
P0178 Fuel Composition Sensor Circuit Low Input
P0179 Fuel Composition Sensor Circuit High Input
P0180 Fuel Temperature Sensor A Circuit Malfunction
P0181 Fuel Temperature Sensor A Circuit Range/Performance
P0182 Fuel Temperature Sensor A Circuit Low Input
P0183 Fuel Temperature Sensor A Circuit High Input
P0184 Fuel Temperature Sensor A Circuit Intermittent
P0185 Fuel Temperature Sensor B Circuit Malfunction
P0186 Fuel Temperature Sensor B Circuit Range/Performance
P0187 Fuel Temperature Sensor B Circuit Low Input
P0188 Fuel Temperature Sensor B Circuit High Input
P0189 Fuel Temperature Sensor B Circuit Intermittent
P0190 Fuel Rail Pressure Sensor Circuit Malfunction
P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
P0192 Fuel Rail Pressure Sensor Circuit Low Input
P0193 Fuel Rail Pressure Sensor Circuit High Input
P0194 Fuel Rail Pressure Sensor Circuit Intermittent
P0195 Engine Oil Temperature Sensor Malfunction
P0196 Engine Oil Temperature Sensor Range/Performance
P0197 Engine Oil Temperature Sensor Low
P0198 Engine Oil Temperature Sensor High
P0199 Engine Oil Temperature Sensor Intermittent
P0200 Injector Circuit Malfunction
P0201 Injector Circuit Malfunction - Cylinder 1
P0202 Injector Circuit Malfunction - Cylinder 2
P0203 Injector Circuit Malfunction - Cylinder 3
P0204 Injector Circuit Malfunction - Cylinder 4
P0205 Injector Circuit Malfunction - Cylinder 5
P0206 Injector Circuit Malfunction - Cylinder 6
P0207 Injector Circuit Malfunction - Cylinder 7
P0208 Injector Circuit Malfunction - Cylinder 8
P0209 Injector Circuit Malfunction - Cylinder 9
P0210 Injector Circuit Malfunction - Cylinder 10
P0211 Injector Circuit Malfunction - Cylinder 11
P0212 Injector Circuit Malfunction - Cylinder 12
P0213 Cold Start Injector 1 Malfunction
P0214 Cold Start Injector 2 Malfunction
P0215 Engine Shutoff Solenoid Malfunction
P0216 Injection Timing Control Circuit Malfunction
P0217 Engine Overtemp Condition
P0218 Transmission Over Temperature Condition
P0219 Engine Overspeed Condition
P0220 Throttle/Petal Position Sensor/Switch B Circuit Malfunction
P0221 Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem
P0222 Throttle/Petal Position Sensor/Switch B Circuit Low Input
P0223 Throttle/Petal Position Sensor/Switch B Circuit High Input
P0224 Throttle/Petal Position Sensor/Switch B Circuit Intermittent
P0225 Throttle/Petal Position Sensor/Switch C Circuit Malfunction
P0226 Throttle/Petal Position Sensor/Switch C Circuit Range/Performance Problem
P0227 Throttle/Petal Position Sensor/Switch C Circuit Low Input
P0228 Throttle/Petal Position Sensor/Switch C Circuit High Input
P0229 Throttle/Petal Position Sensor/Switch C Circuit Intermittent
P0230 Fuel Pump Primary Circuit Malfunction
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0233 Fuel Pump Secondary Circuit Intermittent
P0234 Engine Overboost Condition
P0235 Turbocharger Boost Sensor A Circuit Malfunction
P0236 Turbocharger Boost Sensor A Circuit Range/Performance
P0237 Turbocharger Boost Sensor A Circuit Low
P0238 Turbocharger Boost Sensor A Circuit High
P0239 Turbocharger Boost Sensor B Malfunction
P0240 Turbocharger Boost Sensor B Circuit Range/Performance
P0241 Turbocharger Boost Sensor B Circuit Low
P0242 Turbocharger Boost Sensor B Circuit High
P0243 Turbocharger Wastegate Solenoid A Malfunction
P0244 Turbocharger Wastegate Solenoid A Range/Performance
P0245 Turbocharger Wastegate Solenoid A Low
P0246 Turbocharger Wastegate Solenoid A High
P0247 Turbocharger Wastegate Solenoid B Malfunction
P0248 Turbocharger Wastegate Solenoid B Range/Performance
P0249 Turbocharger Wastegate Solenoid B Low
P0250 Turbocharger Wastegate Solenoid B High
P0251 Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
P0256 Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
P0257 Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)
P0258 Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
P0259 Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)
P0260 Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
P0261 Cylinder 1 Injector Circuit Low
P0262 Cylinder 1 Injector Circuit High
P0263 Cylinder 1 Contribution/Balance Fault
P0264 Cylinder 2 Injector Circuit Low
P0265 Cylinder 2 Injector Circuit High
P0266 Cylinder 2 Contribution/Balance Fault
P0267 Cylinder 3 Injector Circuit Low
P0268 Cylinder 3 Injector Circuit High
P0269 Cylinder 3 Contribution/Balance Fault
P0270 Cylinder 4 Injector Circuit Low
P0271 Cylinder 4 Injector Circuit High
P0272 Cylinder 4 Contribution/Balance Fault
P0273 Cylinder 5 Injector Circuit Low
P0274 Cylinder 5 Injector Circuit High
P0275 Cylinder 5 Contribution/Balance Fault
P0276 Cylinder 6 Injector Circuit Low
P0277 Cylinder 6 Injector Circuit High
P0278 Cylinder 6 Contribution/Balance Fault
P0279 Cylinder 7 Injector Circuit Low
P0280 Cylinder 7 Injector Circuit High
P0281 Cylinder 7 Contribution/Balance Fault
P0282 Cylinder 8 Injector Circuit Low
P0283 Cylinder 8 Injector Circuit High
P0284 Cylinder 8 Contribution/Balance Fault
P0285 Cylinder 9 Injector Circuit Low
P0286 Cylinder 9 Injector Circuit High
P0287 Cylinder 9 Contribution/Balance Fault
P0288 Cylinder 10 Injector Circuit Low
P0289 Cylinder 10 Injector Circuit High
P0290 Cylinder 10 Contribution/Balance Fault
P0291 Cylinder 11 Injector Circuit Low
P0292 Cylinder 11 Injector Circuit High
P0293 Cylinder 11 Contribution/Balance Fault
P0294 Cylinder 12 Injector Circuit Low
P0295 Cylinder 12 Injector Circuit High
P0296 Cylinder 12 Contribution/Range Fault
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0305 Cylinder 5 Misfire Detected
P0306 Cylinder 6 Misfire Detected
P0307 Cylinder 7 Misfire Detected
P0308 Cylinder 8 Misfire Detected
P0309 Cylinder 9 Misfire Detected
P0310 Cylinder 10 Misfire Detected
P0311 Cylinder 11 Misfire Detected
P0312 Cylinder 12 Misfire Detected
P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
P0325 Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)
P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
P0333 Knock Sensor 2 Circuit High Input (Bank 2)
P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
P0335 Crankshaft Position Sensor A Circuit Malfunction
P0336 Crankshaft Position Sensor A Circuit Range/Performance
P0337 Crankshaft Position Sensor A Circuit Low Input
P0338 Crankshaft Position Sensor A Circuit High Input
P0339 Crankshaft Position Sensor A Circuit Intermittent
P0340 Camshaft Position Sensor Circuit Malfunction
P0341 Camshaft Position Sensor Circuit Range/Performance
P0342 Camshaft Position Sensor Circuit Low Input
P0343 Camshaft Position Sensor Circuit High Input
P0344 Camshaft Position Sensor Circuit Intermittent
P0350 Ignition Coil Primary/Secondary Circuit Malfunction
P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
P0353 Ignition Coil C Primary/Secondary Circuit Malfunction
P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
P0355 Ignition Coil E Primary/Secondary Circuit Malfunction
P0356 Ignition Coil F Primary/Secondary Circuit Malfunction
P0357 Ignition Coil G Primary/Secondary Circuit Malfunction
P0358 Ignition Coil H Primary/Secondary Circuit Malfunction
P0359 Ignition Coil I Primary/Secondary Circuit Malfunction
P0360 Ignition Coil J Primary/Secondary Circuit Malfunction
P0361 Ignition Coil K Primary/Secondary Circuit Malfunction
P0362 Ignition Coil L Primary/Secondary Circuit Malfunction
P0370 Timing Reference High Resolution Signal A Malfunction
P0371 Timing Reference High Resolution Signal A Too Many Pulses
P0372 Timing Reference High Resolution Signal A Too Few Pulses
P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
P0374 Timing Reference High Resolution Signal A No Pulses
P0375 Timing Reference High Resolution Signal B Malfunction
P0376 Timing Reference High Resolution Signal B Too Many Pulses
P0377 Timing Reference High Resolution Signal B Too Few Pulses
P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
P0379 Timing Reference High Resolution Signal B No Pulses
P0380 Glow Plug/Heater Circuit "A" Malfunction
P0381 Glow Plug/Heater Indicator Circuit Malfunction
P0382 Exhaust Gas Recirculation Flow Malfunction
P0385 Crankshaft Position Sensor B Circuit Malfunction
P0386 Crankshaft Position Sensor B Circuit Range/Performance
P0387 Crankshaft Position Sensor B Circuit Low Input
P0388 Crankshaft Position Sensor B Circuit High Input
P0389 Crankshaft Position Sensor B Circuit Intermittent
P0400 Exhaust Gas Recirculation Flow Malfunction
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0403 Exhaust Gas Recirculation Circuit Malfunction
P0404 Exhaust Gas Recirculation Circuit Range/Performance
P0405 Exhaust Gas Recirculation Sensor A Circuit Low
P0406 Exhaust Gas Recirculation Sensor A Circuit High
P0407 Exhaust Gas Recirculation Sensor B Circuit Low
P0408 Exhaust Gas Recirculation Sensor B Circuit High
P0410 Secondary Air Injection System Malfunction
P0411 Secondary Air Injection System Incorrect Flow Detected
P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
P0413 Secondary Air Injection System Switching Valve A Circuit Open
P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction
P0416 Secondary Air Injection System Switching Valve B Circuit Open
P0417 Secondary Air Injection System Switching Valve B Circuit Shorted
P0418 Secondary Air Injection System Relay "A" Circuit Malfunction
P0419 Secondary Air Injection System Relay "B" Circuit Malfunction
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
P0426 Catalyst Temperature Sensor Range/Performance (Bank 1)
P0427 Catalyst Temperature Sensor Low Input (Bank 1)
P0428 Catalyst Temperature Sensor High Input (Bank 1)
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
P0436 Catalyst Temperature Sensor Range/Performance (Bank 2)
P0437 Catalyst Temperature Sensor Low Input (Bank 2)
P0438 Catalyst Temperature Sensor High Input (Bank 2)
P0440 Evaporative Emission Control System Malfunction
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0442 Evaporative Emission Control System Leak Detected (small leak)
P0443 Evaporative Emission Control System Purge Control Valve Circuit Malfunction
P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
P0447 Evaporative Emission Control System Vent Control Circuit Open
P0448 Evaporative Emission Control System Vent Control Circuit Shorted
P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
P0450 Evaporative Emission Control System Pressure Sensor Malfunction
P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
P0452 Evaporative Emission Control System Pressure Sensor Low Input
P0453 Evaporative Emission Control System Pressure Sensor High Input
P0454 Evaporative Emission Control System Pressure Sensor Intermittent
P0455 Evaporative Emission Control System Leak Detected (gross leak)
P0460 Fuel Level Sensor Circuit Malfunction
P0461 Fuel Level Sensor Circuit Range/Performance
P0462 Fuel Level Sensor Circuit Low Input
P0463 Fuel Level Sensor Circuit High Input
P0464 Fuel Level Sensor Circuit Intermittent
P0465 Purge Flow Sensor Circuit Malfunction
P0466 Purge Flow Sensor Circuit Range/Performance
P0467 Purge Flow Sensor Circuit Low Input
P0468 Purge Flow Sensor Circuit High Input
P0469 Purge Flow Sensor Circuit Intermittent
P0470 Exhaust Pressure Sensor Malfunction
P0471 Exhaust Pressure Sensor Range/Performance
P0472 Exhaust Pressure Sensor Low
P0473 Exhaust Pressure Sensor High
P0474 Exhaust Pressure Sensor Intermittent
P0475 Exhaust Pressure Control Valve Malfunction
P0476 Exhaust Pressure Control Valve Range/Performance
P0477 Exhaust Pressure Control Valve Low
P0478 Exhaust Pressure Control Valve High
P0479 Exhaust Pressure Control Valve Intermittent
P0480 Cooling Fan 1 Control Circuit Malfunction
P0481 Cooling Fan 2 Control Circuit Malfunction
P0482 Cooling Fan 3 Control Circuit Malfunction
P0483 Cooling Fan Rationality Check Malfunction
P0484 Cooling Fan Circuit Over Current
P0485 Cooling Fan Power/Ground Circuit Malfunction
P0500 Vehicle Speed Sensor Malfunction
P0501 Vehicle Speed Sensor Range/Performance
P0502 Vehicle Speed Sensor Low Input
P0503 Vehicle Speed Sensor Intermittent/Erratic/High
P0505 Idle Control System Malfunction
P0506 Idle Control System RPM Lower Than Expected
P0507 Idle Control System RPM Higher Than Expected
P0510 Closed Throttle Position Switch Malfunction
P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage
P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
P0533 A/C Refrigerant Pressure Sensor Circuit High Input
P0534 Air Conditioner Refrigerant Charge Loss
P0550 Power Steering Pressure Sensor Circuit Malfunction
P0551 Power Steering Pressure Sensor Circuit Range/Performance
P0552 Power Steering Pressure Sensor Circuit Low Input
P0553 Power Steering Pressure Sensor Circuit High Input
P0554 Power Steering Pressure Sensor Circuit Intermittent
P0560 System Voltage Malfunction
P0561 System Voltage Unstable
P0562 System Voltage Low
P0562 A/C pressure sensor low voltage(Chrysler)
P0563 System Voltage High
P0565 Cruise Control On Signal Malfunction
P0566 Cruise Control Off Signal Malfunction
P0567 Cruise Control Resume Signal Malfunction
P0568 Cruise Control Set Signal Malfunction
P0569 Cruise Control Coast Signal Malfunction
P0570 Cruise Control Accel Signal Malfunction
P0571 Cruise Control/Brake Switch A Circuit Malfunction
P0572 Cruise Control/Brake Switch A Circuit Low
P0573 Cruise Control/Brake Switch A Circuit High
P0574 Cruise Control Related Malfunction
P0575 Cruise Control Related Malfunction
P0576 Cruise Control Related Malfunction
P0578 Cruise Control Related Malfunction
P0579 Cruise Control Related Malfunction
P0580 Cruise Control Related Malfunction
P0600 Serial Communication Link Malfunction
P0601 Control Module Read Only Memory(ROM)
P0602 Control Module Programming Error
P0603 Internal Control Module Keep Alive Memory (KAM) Error
P0604 Internal Control Module Random Access Memory (RAM) Error
P0605 Internal Control Module Read Only Memory (ROM) Error
P0606 PCM Processor Fault
P0608 Control Module VSS Output "A" Malfunction
P0609 Control Module VSS Output "B" Malfunction
P0620 Generator Control Circuit Malfunction
P0621 Generator Lamp "L" Control Circuit Malfunction
P0622 Generator Field "F" Control Circuit Malfunction
P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
P0654 Engine RPM Output Circuit Malfunction
P0655 Engine Hot Lamp Output Control Circuit Malfucntion
P0656 Fuel Level Output Circuit Malfunction
P0700 Transmission Control System Malfunction
P0701 Transmission Control System Range/Performance
P0702 Transmission Control System Electrical
P0703 Torque Converter/Brake Switch B Circuit Malfunction
P0704 Clutch Switch Input Circuit Malfunction
P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)
P0706 Transmission Range Sensor Circuit Range/Performance
P0707 Transmission Range Sensor Circuit Low Input
P0708 Transmission Range Sensor Circuit High Input
P0709 Transmission Range Sensor Circuit Intermittent
P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712 Transmission Fluid Temperature Sensor Circuit Low Input
P0713 Transmission Fluid Temperature Sensor Circuit High Input
P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
P0715 Input/Turbine Speed Sensor Circuit Malfunction
P0716 Input/Turbine Speed Sensor Circuit Range/Performance
P0717 Input/Turbine Speed Sensor Circuit No Signal
P0718 Input/Turbine Speed Sensor Circuit Intermittent
P0719 Torque Converter/Brake Switch B Circuit Low
P0720 Output Speed Sensor Circuit Malfunction
P0721 Output Speed Sensor Range/Performance
P0722 Output Speed Sensor No Signal
P0723 Output Speed Sensor Intermittent
P0724 Torque Converter/Brake Switch B Circuit High
P0725 Engine Speed input Circuit Malfunction
P0726 Engine Speed Input Circuit Range/Performance
P0727 Engine Speed Input Circuit No Signal
P0728 Engine Speed Input Circuit Intermittent
P0730 Incorrect Gear Ratio
P0731 Gear 1 Incorrect ratio
P0732 Gear 2 Incorrect ratio
P0733 Gear 3 Incorrect ratio
P0734 Gear 4 Incorrect ratio
P0735 Gear 5 Incorrect ratio
P0736 Reverse incorrect gear ratio
P0740 Torque Converter Clutch Circuit Malfuction
P0741 Torque Converter Clutch Circuit Performance or Stuck Off
P0742 Torque Converter Clutch Circuit Stuck On
P0743 Torque Converter Clutch Circuit Electrical
P0744 Torque Converter Clutch Circuit Intermittent
P0745 Pressure Control Solenoid Malfunction
P0746 Pressure Control Solenoid Performance or Stuck Off
P0747 Pressure Control Solenoid Stuck On
P0748 Pressure Control Solenoid Electrical
P0749 Pressure Control Solenoid Intermittent
P0750 Shift Solenoid A Malfunction
P0751 Shift Solenoid A Performance or Stuck Off/1-2 Shift Solenoid Valve Performance
P0752 Shift Solenoid A Stuck On
P0753 Shift Solenoid A Electrical/1-2 Shift Solenoid Circuit Electrical
P0754 Shift Solenoid A Intermittent
P0755 Shift Solenoid B Malfunction
P0756 Shift Solenoid B Performance or Stuck Off/2-3 Shift Solenoid Valve Performance
P0757 Shift Solenoid B Stuck On
P0758 Shift Solenoid B Electrical/2-3 Shift Solenoid Circuit Electrical
P0759 Shift Solenoid B Intermittent
P0760 Shift Solenoid C Malfunction
P0761 Shift Solenoid C Performance or Stuck Off
P0762 Shift Solenoid C Stuck On
P0763 Shift Solenoid C Electrical
P0764 Shift Solenoid C Intermittent
P0765 Shift Solenoid D Malfunction
P0766 Shift Solenoid D Performance or Stuck Off
P0767 Shift Solenoid D Stuck On
P0768 Shift Solenoid D Electrical
P0769 Shift Solenoid D Intermittent
P0770 Shift Solenoid E Malfunction
P0771 Shift Solenoid E Performance or Stuck Off
P0772 Shift Solenoid E Stuck On
P0773 Shift Solenoid E Electrical
P0774 Shift Solenoid E Intermittent
P0775 Pressure Control Solenoid B Malfunction
P0776 Pressure Control Solenoid B Performance
P0777 Pressure Control Solenoid B Stuck On
P0778 Pressure Control Solenoid B Electrical
P0779 Pressure Control Solenoid B Intermittent
P0780 Shift Malfunction
P0781 1-2 Shift Malfunction
P0782 2-3 Shift Malfunction
P0783 3-4 Shift Malfunction
P0784 4-5 Shift Malfunction
P0785 Shift/Timing Solenoid Malfunction/ 3-2 Shift Solenoid Circuit Electrical
P0786 Shift/Timing Solenoid Range/Performance
P0787 Shift/Timing Solenoid Low
P0788 Shift/Timing Solenoid High
P0789 Shift/Timing Solenoid Intermittent
P0790 Normal/Performance Switch Circuit Malfunction
P0801 Reverse Inhibit Control Circuit Malfunction
P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
P1100 MAF Sensor Intermittent/ Check of all OBDII Systems Not Complete
P1101 MAF Sensor Out Of Self Test Range./KOER Not Able To Complete KOER Aborted
P1102 MAF Sensor In Range But Lower Than Expected
P1103 MAF Sensor In Range But Higher Than Expected
P1104 MAF Ground Malfunction
P1105 Dual Alternator Upper Fault
P1106 Dual Alternator Lower Fault/ Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
P1107 Dual Alternator Lower Circuit Malfunction/ Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage
P1108 Dual Alternator Battery Lamp Circuit Malfunction
P1109 IAT - B Sensor Intermittent
P1110 IAT Sensor (D/C) Open/Short
P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
P1113 IAT Sensor Open/Short
P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage/IAT - B Circuit Low Input
P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage/IAT - B Circuit High Input
P1116 Engine Coolant sensor out of range/ECT Sensor Out Of Self Test Range
P1117 Engine Coolant Sensor intermittent/ECT Sensor Intermittent
P1118 Manifold Absolute Temperature Circuit Low Input
P1119 Manifold Absolute Temperature Circuit High Input
P1120 Throttle position sensor out of range
P1121 Throttle Position (TP) Sensor Circuit Intermittent High Voltage
P1122 Throttle Position (TP) Sensor Circuit Intermittent Low Voltage
P1123 Throttle Position Sensor In Range But Higher Than Expected
P1124 Throttle Position Sensor Out Of Self Test Range
P1125 Throttle position sensor intermittent
P1126 Throttle Position (Narrow Range) Sensor Circuit Malfunction
P1127 Exhaust Not Warm, Downstream O2 Sensor
P1128 Upstream Heated O2 Sensors Swapped
P1129 Downstream Heated O2 Sensors Swapped
P1130 Lack Of HO2S Switch - Adaptive Fuel At Limit
P1131 Lack Of HO2S Switch - Sensor Indicates Lean
P1132 Lack Of HO2S Switch - Sensor Indicates Rich
P1133 HO2S Insufficient Switching Sensor 1
P1134 HO2S Transition Time Ratio Sensor 1
P1135 Pedal Position Sensor A Circuit Intermittent
P1136 Fan Control Circuit Malfunction
P1137 Lack Of HO2S Switch - Sensor Indicates Lean
P1138 Lack Of HO2S12 Switch - Sensor Indicates Rich
P1139 Water In Fuel Indicator Circuit Malfunction
P1140 Water In Fuel Condition
P1141 Fuel Restriction Indicator Circuit Malfunction
P1142 Fuel Restriction Condition
P1143 Air Assist Control Valve Range/Performance
P1144 Air Assist Control Valve Circuit Malfunction
P1150 Lack Of HO2S21 Switch - Adaptive Fuel At Limit
P1151 Lack Of HO2S21 Switch - Sensor Indicates Lean
P1152 Lack Of HO2S21 Switch - Sensor Indicates Rich
P1153 Bank 2 Fuel Control Shifted Lean
P1154 Bank 2 Fuel Control Shifted Rich
P1155 Alternative Fuel Controller
P1156 Fuel Select Switch Malfunction
P1157 Lack Of HO2S22 Switch - Sensor Indicates Lean
P1158 Lack Of HO2S22 Switch - Sensor Indicates Rich
P1159 Fuel Stepper Motor Malfunction
P1167 Invalid Test,throttle not depressed
P1168 Fuel Rail Sensor In-Range Low Failure
P1169 Fuel Rail Sensor In-Range High Failure
P1170 ESO - Engine Shut Off Solenoid Fault
P1171 Rotor Sensor Fault
P1172 Rotor Control Fault
P1173 Rotor Calibration Fault
P1174 Cam Sensor Fault
P1175 Cam Control Fault
P1176 Cam Calibration Fault
P1177 Synchronization Fault
P1178 ( open )
P1180 Fuel Delivery System Malfunction - Low
P1181 Fuel Delivery System Malfunction - High
P1182 Fuel Shut Off Solenoid Malfunction
P1183 Engine Oil Temperature Circuit Malfunction
P1184 Engine Oil Temperature Out Of Self Test Range
P1185 FTS High - Fuel Pump Temperature Sensor High
P1186 FTS Low - Fuel Pump Temperature Sensor Low
P1187 Variant Selection
P1188 Calibration Memory Fault
P1189 Pump Speed Signal Fault
P1190 Calibration Resistor Out Of Range
P1191 Key Line Voltage
P1192 Voltage External
P1193 EGR Drive Overcurrent
P1194 ECU A/D Converter
P1195 SCP HBCC Failed To Initialize
P1196 Key Off Voltage High
P1197 Key Off Voltage Low
P1198 Pump Rotor Control Underfueling
P1199 Fuel Level Input Circuit Low
P1200 Injector Control Circuit
P1201 Injector Circuit Open / Shorted - Cylinder #1
P1202 Injector Circuit Open / Shorted - Cylinder #2
P1203 Injector Circuit Open / Shorted - Cylinder #3
P1204 Injector Circuit Open / Shorted - Cylinder #4
P1205 Injector Circuit Open / Shorted - Cylinder #5
P1206 Injector Circuit Open / Shorted - Cylinder #6
P1209 Injector Control Pressure System Fault
P1210 Injector Control Pressure Above Expected Level
P1211 Injector Control Pressure Sensor Above / Below Desired
P1212 Injector Control Pressure Not Detected During Crank
P1213 Start Injector Circuit Malfunction
P1214 Pedal Position Sensor B Circuit Intermittent
P1215 Pedal Position Sensor C Circuit Low Input
P1216 Pedal Position Sensor C Circuit High Input
P1217 Pedal Position Sensor C Circuit Intermittent
P1218 CID High
P1219 CID Low
P1220 Series Throttle Control System Malfunction
P1221 Traction Control System Malfunction
P1222 Traction Control Output Circuit Malfunction
P1223 Pedal Demand Sensor B Circuit High Input
P1224 Throttle Position Sensor B Out Of Self Test Range
P1225 Needle Lift Sensor Malfunction
P1226 Control Sleeve Sensor Malfunction
P1227 Wastegate Failed Closed (Over Pressure)
P1228 Wastegate Failed Open (Under Pressure)
P1229 Intercooler Pump Driver Fault
P1230 Fuel Pump Low Speed Malfunction
P1231 Fuel Pump Secondary Circuit Low, High Speed
P1232 Fuel Pump Speed Primary Circuit Malfunction
P1233 Fuel Pump Driver Module Off Line
P1234 Fuel Pump Driver Module Off Line
P1235 Fuel Pump Control Out Of Range
P1236 Fuel Pump Control Out Of Range
P1237 Fuel Pump Secondary Circuit Malfunction
P1238 Fuel Pump Secondary Circuit Malfunction
P1239 Speed Fuel Pump Positive Feed Fault
P1240 Sensor Power Supply Malfunction
P1241 Sensor Power Supply Low Input
P1242 Sensor Power Supply High Input
P1243 Second Fuel Pump Faulty or Ground Fault
P1244 Alternator Load Input Failed High
P1245 Alternator Load Input Failed Low
P1246 Alternator Load Input Failed
P1247 Turbo Boost Pressure Low
P1248 Turbo Boost Pressure Not Detected
P1249 Wastegate Control Valve Performance
P1250 PRC Solenoid Circuit Malfunction
P1251 Air Mixture Solenoid Circuit Malfunction
P1252 Pedal Correlation PDS1 and LPDS High
P1253 Pedal Correlation PDS1 and LPDS Low
P1254 Pedal Correlation PDS2 and LPDS High
P1255 Pedal Correlation PDS2 and LPDS Low
P1256 Pedal Correlation PDS1 and HPDS
P1257 Pedal Correlation PDS2 and HPDS
P1258 Pedal Correlation PDS1 and PDS2
P1259 Immobilizer to PCM Signal Error
P1260 THEFT Detected, Vehicle Immobilzed
P1261 Cylinder #1 High To Low Side Short
P1262 Cylinder #2 High To Low Side Short
P1263 Cylinder #3 High To Low Side Short
P1264 Cylinder #4 High To Low Side Short
P1265 Cylinder #5 High To Low Side Short
P1266 Cylinder #6 High To Low Side Short
P1267 Cylinder #7 High To Low Side Short
P1268 Cylinder #8 High To Low Side Short
P1269 Immobilizer Code Not Programmed
P1270 Engine RPM Or Speed Limiter Reached
P1271 Cylinder #1 High To Low Side Open
P1272 Cylinder #2 High To Low Side Open
P1273 Cylinder #3 High To Low Side Open
P1274 Cylinder #4 High To Low Side Open
P1275 Cylinder #5 High To Low Side Open
P1276 Cylinder #6 High To Low Side Open
P1277 Cylinder #7 High To Low Side Open
P1278 Cylinder #8 High To Low Side Open
P1280 Injection Control Pressure Out Of Range Low
P1281 Injection Control Pressure Out Of Range High
P1282 Excessive Injection Control Pressure
P1283 IPR Circuit Failure
P1284 Aborted KOER - ICP Failure
P1285 Cylinder head over temp sensed
P1286 Fuel Pulse In Range But Lower Than Expected
P1287 Fuel Pulse In Range But Higher Than Expected
P1288 Cylinder Head Temp Sensor Out Of Self Test Range
P1289 Cylinder Head Temp Sensor High Input
P1290 Cylinder Head Temp Sensor Low Input
P1291 Injector High Side Short To GND Or VBATT - Bank 1
P1292 Injector High Side Short To GND Or VBATT - Bank 2
P1293 Injector High Side Open - Bank 1
P1294 Injector High Side Open - Bank 2/Target idle not reached
P1295 Multi-faults - Bank 1 - With Low Side Shorts
P1296 Multi-faults - Bank 2 - With Low Side Shorts
P1297 Injector High Sides Shorted Together
P1298 IDM Failure
P1299 Cylinder Head Overtemperature Protection Active
P1300 Boost Calibration Fault
P1301 Boost Calibration High
P1302 Boost Calibration Low
P1303 EGR Calibration Fault
P1304 EGR Calibration High
P1305 EGR Calibration Low
P1306 Kickdown Relay Pull - In Circuit Fault
P1307 Kickdown Relay Hold Circuit Fault
P1308 A/C Clutch Circuit Fault
P1309 Misfire Monitor AICE Chip Fault
P1313 Misfire Rate Catalyst Damage Fault - Bank 1
P1314 Misfire Rate Catalyst Damage Fault - Bank 2
P1315 Persistent Misfire
P1316 Injector Circuit / IDM Codes Detected
P1317 Injector Circuit / IDM Codes Not Updated
P1336 Crank / Cam Sensor Range / Performance
P1340 Camshaft Position Sensor B Circuit Malfunction
P1341 Camshaft Position Sensor B Range / Performance
P1345 SGC (Cam Position) Sensor Circuit Malfunction/ Crankshaft Position - Camshaft Position Correlation
P1346 Fuel Level Sensor B Circuit Malfunction
P1347 Fuel Level Sensor B Range / Performance
P1348 Fuel Level Sensor B Circuit Low
P1349 Fuel Level Sensor B Circuit High
P1350 Fuel Level Sensor B Intermittent/Bypass Line Monitor
P1351 IDM Input Circuit Malfunction/ Ignition Coil Control Circuit High Voltage
P1352 Ignition Coil A Primary Circuit Malfunction
P1353 Ignition Coil B Primary Circuit Malfunction
P1354 Ignition Coil C Primary Circuit Malfunction
P1355 Ignition Coil D Primary Circuit Malfunction
P1360 Ignition Coil A Secondary Circuit Malfunction
P1361 Ignition Control (IC) Circuit Low Voltage
P1362 Ignition Coil C Secondary Circuit Malfunction
P1363 Ignition Coil D Secondary Circuit Malfunction
P1364 Ignition Coil Primary Circuit Failure
P1365 Ignition Coil Secondary Circuit Failure
P1366 Ignition Spare
P1367 Ignition Spare
P1368 Ignition Spare
P1369 Engine Temperature Light Monitor Failure
P1370 Insufficient RMP Increase During Spark Test
P1371 Ignition Coil - Cylinder 1 - Early Activation Fault
P1372 Ignition Coil - Cylinder 2 - Early Activation Fault
P1373 Ignition Coil - Cylinder 3 - Early Activation Fault
P1374 Crankshaft Position (CKP)/Ignition Coil - Cylinder 4 - Early Activation Fault
P1375 Ignition Coil - Cylinder 5 - Early Activation Fault
P1376 Ignition Coil - Cylinder 6 - Early Activation Fault
P1380 Misfire Detected - Rough Road Data Not Available
P1381 Variable Cam Timing Overadvanced (Bank #1 )/ Misfire Detected - No Communication with BCM
P1382 Variable Cam Timing Solenoid #1 Circuit Malfunction
P1383 Variable Cam Timing Overretarded (Bank #1 )
P1384 VVT Solenoid A Malfunction
P1385 Variable Cam Timing Solenoid B Malfunction
P1386 Variable Cam Timing Overadvanced (Bank #2 )
P1387 Variable Cam Timing Solenoid #2 Circuit Malfunction
P1388 Variable Cam Timing Overretarded (Bank #2 )
P1389 Glow Plug Circuit High Side Low Input
P1390 Octane Adjust Pin Out Of Self Test Range
P1391 Glow Plug Circuit Low Input (Bank #1 )
P1392 Glow Plug Circuit High Input (Bank #1 )
P1393 Glow Plug Circuit Low Input (Bank #2 )
P1394 Glow Plug Circuit High Input (Bank #2 )
P1395 Glow Plug Monitor Fault (Bank #1 )
P1396 Glow Plug Monitor Fault (Bank #2 )
P1397 System Voltage Out Of Self Test Range
P1398 VVT Solenoid B Circuit High Input
P1399 Glow Plug Circuit High Side, High Input
P1400 DPFE Circuit Low Input
P1401 DPFE Circuit High Input
P1402 EGR Metering Orifice Restricted
P1403 DPFE Sensor Hoses Reversed
P1404 IAT - B Circuit Malfunction/ Exhaust Gas Recirculation Closed Position Performance
P1405 Exhaust Gas Recirculation Sensor Circuit High
P1406 Exhaust Gas Recirculation (EGR) Position Sensor Performance
P1407 EGR No Flow Detected
P1408 EGR Flow Out Of Self Test Range
P1409 EVR Control Circuit Malfunction
P1411 SAI System Incorrect Downstream Flow Detected
P1413 SAI System Monitor Circuit Low Input
P1414 SAI System Monitor Circuit High Input
P1415 Air Pump Circuit Malfunction/ (AIR) System Bank 1
P1416 Port Air Circuit Malfunction/ (AIR) System Bank 2
P1417 Port Air Relief Circuit Malfunction
P1418 Split Air #1 Circuit Malfunction
P1419 Split Air #2 Circuit Malfunction
P1420 Catalyst Temperature Sensor Failure
P1421 Catalyst Damage
P1422 EGI Temperature Sensor Failure
P1423 EGI Functionality Test Failed
P1424 EGI Glow Plug Primary Failure
P1425 EGI Glow Plug Secondary Failure
P1426 EGI Mini - MAF Failed Out Of Range
P1427 EGI Mini - MAF Failed Short Circuit
P1428 EGI Mini - MAF Failed Open Circuit
P1429 Electric Air Pump Primary Failure
P1430 Electric Air Pump Secondary Failure
P1433 A/C Refrigerant Temperature Circuit Low
P1434 A/C Refrigerant Temperature Circuit High
P1435 A/C Refrigerant Temperature Circuit Range/Performance
P1436 A/C Evaporator Air Temperature Circuit Low
P1437 A/C Evaporator Air Temperature Circuit High
P1438 A/C Evaporator Air Temperature Circuit Range/Performance
P1439 Floor Temperature Switch Circuit Malfunction
P1440 Purge Valve Stuck Open
P1441 Evaporative Emission (EVAP) System Flow During Non-Purge Chevrolet Only
P1441 Evaporative Emission (EVAP) System Flow During Non-Purge Oldsmobile Only
P1442 Evaporative Emission Control System Leak Detected
P1443 Evaporative Emission Control System Control Valve
P1444 Purge Flow Sensor Circuit Low Input
P1445 Purge Flow Sensor Circuit High Input
P1446 Evaporative Vac Solenoid Circuit Malfunction
P1447 ELC System Closure Valve Flow Fault
P1448 ELC System 2 Fault
P1449 Evaporative Check Solenoid Circuit Malfunction
P1450 Unable To Bleed Up Fuel Tank Vacuum
P1451 Evap Emission Control Sys Vent Control Valve Circuit
P1452 Unable To Bleed - Up Vacuum in Tank
P1453 Fuel Tank Pressure Relief Valve Malfunction
P1454 Evaporative System Vacuum Test Malfunction
P1455 Evap Emission Control Sys Leak Detected (Gross Leak/No Flow)
P1456 Fuel Tank Temperature Sensor Circuit Malfunction
P1457 Unable To Pull Vacuum In Tank
P1460 Wide open throttle A/C cutoff relay circuit
P1461 A/C pressure sensor circuit voltage low
P1462 A/C pressure sensor circuit voltage high
P1463 A/C Pressure Sensor Insufficient Pressure Change
P1464 A/C Demand Out of Self Test Range
P1465 A/C Relay Circuit Malfunction
P1466 A/C Refrigerant Temperature Sensor/Circuit Malfunction
P1467 A/C Compressor Temperature Sensor Malfunction
P1468 SSPOD Open Circuit or Closed Circuit Fault
P1469 Low A/C Cycling Period
P1470 A/C Cycling Period Too Short
P1471 Electrodrive Fan 1 Operational Failure (Driver Side)
P1472 Electrodrive Fan 2 Operational Failure (Passenger Side)
P1473 Fan Secondary High With Fan(s) Off
P1474 Low Fan Control Primary Circuit Malfunction
P1475 Fan Relay (Low) Circuit Malfunction
P1476 Fan Relay (High) Circuit Malfunction
P1477 Additional Fan Relay Circuit Malfunction
P1478 Cooling Fan Driver Fault
P1479 High Fan Control Primary Circuit Malfunction
P1480 Fan Secondary Low with Low Fan On
P1481 Fan Secondary Low With High Fan On
P1482 SCP
P1483 Power To Fan Circuit Overcurrent
P1484 Open Power To Ground VCRM
P1485 EGRV Circuit Malfunction
P1486 EGRA Circuit Malfunction
P1487 EGRCHK Solenoid Circuit Malfunction
P1490 Secondary Air Relief Solenoid Circuit Malfunction
P1491 Secondary Switch Solenoid Circuit Malfunction
P1492 APLSOL Solenoid Circuit Malfunction
P1493 RCNT Solenoid Circuit Malfunction
P1494 SPCUT Solenoid Circuit Malfunction
P1495 TCSPL Solenoid Circuit Malfunction
P1500 Vehicle Speed Sensor Intermittent
P1501 Vehicle Speed Sensor Out Of Self Test Range
P1502 Vehicle Speed Sensor Intermittent Malfunction
P1503 Auxillary Speed Sensor Fault
P1504 Idle Air Control Circuit Malfunction
P1505 Idle Air Control System At Adaptive Clip
P1506 Idle Air Control Overspeed Error
P1507 Idle Air Control Underspeed Error
P1508 Idle Control System Circuit Open
P1509 Idle Control System Circuit Shorted
P1510 Idle Signal Circuit Malfunction
P1511 Idle Switch (Electric Control Throttle) Circuit Malfunction
P1512 Intake Manifold Runner Control (Bank 1) Stuck Closed
P1513 Intake Manifold Runner Control (Bank 2) Stuck Closed
P1514 High Load Neutral/Drive Fault
P1515 Electric Current Circuit Malfunction
P1516 IMRC Input Error (Bank 1)
P1517 IMRC Input Error (Bank 2)
P1518 Intake Manifold Runner Control (Stuck Open)
P1519 Intake Manifold Runner Control (Stuck Closed)
P1520 Intake Manifold Runner Control Circuit Malfunction
P1521 Variable Intake Solenoid #1 Circuit Malfunction
P1522 Variable Intake Solenoid #2 Circuit Malfunction
P1523 IVC Solenoid Circuit Malfunction
P1524 Variable Intake Solenoid System
P1525 Air Bypass Valve System
P1526 Air Bypass System
P1527 Accelerate Warmup Solenoid Circuit Malfunction
P1528 Subsidiary Throttle Valve Solenoid Circuit Malfunction
P1529 SCAIR Solenoid Circuit Malfunction
P1530 A/C Clutch Circuit Malfunction
P1531 Invalid Test - Accelerator Pedal Movement
P1532 IMCC Circuit Malfunction, Bank B
P1533 AAI Circuit Malfunction
P1534 Inertia Switch Activated
P1535 Blower Fan Speed Circuit Range/Performance
P1536 Parking Brake Switch Circuit Failure
P1537 Intake Manifold Runner Control (Bank 1) Stuck Open
P1538 Intake Manifold Runner Control (Bank 2) Stuck Open
P1539 Power To A/C Clutch Circuit Overcurrent
P1540 Air Bypass Valve Circuit Malfunction
P1549 IMCC Circuit Malfunction, Bank B
P1550 PSPS Out Of Self Test Range
P1565 Speed Control Command Switch Out of Range High
P1566 Speed Control Command Switch Out of Range Low
P1567 Speed Control Output Circuit Continuity
P1568 Speed Control Unable to Hold Speed
P1571 Brake Switch Malfunction
P1572 Brake Pedal Switch Circuit Malfunction
P1573 Throttle Position Not Available
P1574 Throttle Position Sensor Disagreement btwn Sensors
P1575 Pedal Position Out of Self Test Range
P1576 Pedal Position Not Available
P1577 Pedal Position Sensor Disagreement btwn Sensors
P1578 ETC Power Less Than Demand
P1579 ETC In Power Limiting Mode
P1580 Electronic Throttle Monitor PCM Override
P1581 Electronic Throttle Monitor Malfunction
P1582 Electronic Throttle Monitor Data Available
P1583 Electronic Throttle Monitor Cruise Disable
P1584 TCU Detected IPE Circuit Malfunction
P1585 Throttle Control Unit Malfunction
P1586 Throttle Control Unit Throttle Position Malfunction
P1587 Throttle Control Unit Modulated Command Malfunction
P1588 Throttle Control Unit Detected Loss of Return Spring
P1589 TCU Unable To Control Desired Throttle Angle
P1600 Loss of KAM Power; Open Circuit
P1601 ECM/TCM Serial Communication Error
P1602 Immobilizer/ECM Communication Error
P1603 EEPROM Malfunction
P1604 Code Word Unregestered
P1605 Keep Alive Memory Test Failure
P1606 ECM Control Relay O/P Circuit Malfunction
P1607 MIL O/P Circuit Malfunction
P1608 Internal ECM Malfunction
P1609 Diagnostic Lamp Driver Fault
P1610 SBDS Interactive Codes
P1611 SBDS Interactive Codes
P1612 SBDS Interactive Codes
P1613 SBDS Interactive Codes
P1614 SBDS Interactive Codes
P1615 SBDS Interactive Codes
P1616 SBDS Interactive Codes
P1617 SBDS Interactive Codes
P1618 SBDS Interactive Codes
P1619 SBDS Interactive Codes
P1620 SBDS Interactive Codes
P1621 Control Module Long Term Memory Performance/ Immobilizer Code Words Do Not Match
P1622 Immobilizer ID Does Not Match
P1623 Immobilizer Code Word/ID Number Write Failure
P1624 Anti Theft System
P1625 B+ Supply To VCRM Fan Circuit Malfunction
P1626 Theft Deterrent Fuel Enable Signal Not Received/ B+ Supply To VCRM A/C Circuit Malfunction
P1627 Module Supply Voltage Out Of Range
P1628 Module Ignition Supply Input Malfunction
P1629 Internal Voltage Regulator Malfunction
P1630 Internal Vref Malfunction
P1631 Theft Deterrent Start Enable Signal Not Correct/ Main Relay Malfunction (Power Hold)
P1632 Smart Alternator Faults Sensor/Circuit Malfunction
P1633 KAM Voltage Too Low
P1634 Data Output Link Circuit Failure
P1635 Tire / Axle Ratio Out of Acceptable Range
P1636 Inductive Signature Chip Communication Error
P1637 Can Link ECM/ABSCM Circuit / Network Malfunction
P1638 Can Link ECM/INSTM Circuit / Network Malfunction
P1639 Vehicle ID Block Corrupted or Not Programmed
P1640 Powertrain DTCs Available in Another Module
P1641 Fuel Pump Primary Circuit Failure
P1642 Fuel Pump Monitor Circuit High Input
P1643 Fuel Pump Monitor Circuit Low Input
P1644 Fuel Pump Speed Control Circuit Malfunction
P1645 Fuel Pump Resistor Switch Circuit Malfunction
P1650 PSP Switch Out of Self Test Range
P1651 PSP Switch Input Malfunction
P1652 IAC Monitor Disabled by PSP Switch Failed On
P1653 Power Steering Output Circuit Malfunction
P1654 Recirculation Override Circuit Malfunction
P1655 Starter Disable Circuit Malfunction
P1660 Output Circuit Check Signal High
P1661 Output Circuit Check Signal Low
P1662 IDM_EN Circuit Failure
P1663 Fuel Demand Command Signal Circuit Malfunction
P1667 CI Circuit Malfunction
P1668 PCM - IDM Communications Error
P1670 Electronic Feedback Signal Not Detected
P1680 Metering Oil Pump Malfunction
P1681 Metering Oil Pump Malfunction
P1682 Metering Oil Pump Malfunction
P1683 Metering Oil Pump Temperature Sensor Circuit Malfunction
P1684 Metering Oil Pump Position Sensor Circuit Malfunction
P1685 Metering Oil Pump Stepping Motor Circuit Malfunction
P1686 Metering Oil Pump Stepping Motor Circuit Malfunction
P1687 Metering Oil Pump Stepping Motor Circuit Malfunction
P1688 Metering Oil Pump Stepping Motor Circuit Malfunction
P1689 Oil Pressure Control Solenoid Circuit Malfunction
P1690 Wastegate Solenoid Circuit Malfunction
P1691 Turbo Pressure Control Solenoid Circuit Malfunction
P1692 Turbo Control Solenoid Circuit Malfunction
P1693 Turbo Charge Control Circuit Malfunction
P1694 Turbo Charge Relief Circuit Malfunction
P1700 Transmission Indeterminate Failure (Failed to Neutral)
P1701 Reverse Engagement Error
P1702 TRS Circuit Intermittent Malfunction
P1703 Brake Switch Out Of Self Test Range
P1704 Digital TRS Failed to Transition States in KOEO / KOER
P1705 Not in P or N During KOEO / KOER
P1706 High Vehicle Speed Observed in Park
P1707 Transfer Case Neutral Indicator Hard Fault Present
P1708 Clutch Switch Circuit Malfunction
P1709 PNP Switch Out Of Self Test Range
P1711 TFT Sensor Out Of Self Test Range
P1712 Trans Torque Reduction Request Signal Malfunction
P1713 TFT Sensor In Range Failure Low Value
P1714 SSA Inductive Signature Malfunction
P1715 SSB Inductive Signature Malfunction
P1716 SSC Inductive Signature Malfunction
P1717 SSD Inductive Signature Malfunction
P1718 TFT Sensor In Range Failure High
P1720 Vehicle Speed (Meter) Circuit Malfunction
P1721 Gear 1 Incorrect Ratio
P1722 Gear 2 Incorrect Ratio
P1723 Gear 3 incorrect Ratio
P1724 Gear 4 Incorrect Ratio
P1725 Insufficient Engine Speed Increase During Self Test
P1726 Insufficient Engine Speed Decrease During Self Test
P1727 Coast Clutch Solenoid Inductive Signature Malfunction
P1728 Transmission Slip Error
P1729 4x4 Low Switch Error
P1730 Gear Control Malfunction 2,3,5
P1731 1-2 Shift Malfunction
P1732 2-3 Shift Malfunction
P1733 3-4 Shift Malfunction
P1734 Gear Control Malfunction
P1735 First Gear Switch Circuit Malfunction
P1736 Second Gear Switch Circuit Malfunction
P1737 Lockup Solenoid System
P1738 Shift Time Error
P1739 Slip Solenoid System
P1740 Torque Converter Clutch Inductive Signature Malfunction
P1741 Torque Converter Clutch Control Error
P1742 Torque Converter Clutch Solenoid Failed On
P1743 Torque Converter Clutch Solenoid Failied On
P1744 Torque Converter Clutch System Performance
P1745 Line Pressure Solenoid System
P1746 Pressure Control Solenoid "A" Open Circuit
P1747 Pressure Control Solenoid "A" Short Circuit
P1748 EPC Malfunction
P1749 Pressure Control Solenoid Failed Low
P1751 Shift Solenoid A Performance
P1754 Coast Clutch Solenoid Circuit Malfunction
P1755 Intermediate Speed Sensor (ISS) Malfunction
P1756 Shift Solenoid B Performance
P1760 Pressure Control Solenoid "A" Short Circuit
P1761 Shift Solenoid C Performance
P1762 Overdrive Band Failed Off
P1765 Timing Solenoid Circuit Malfunction
P1767 Torque Converter Clutch Circuit Malfunction
P1768 Performance / Normal / Winter Mode Input Malfunction
P1769 AG4 Transmission Torque Modulation Fault
P1770 Clutch Solenoid Circuit Malfunction
P1775 Transmission System MIL Fault
P1776 Ignition Retard Request Duration Fault
P1777 Ignition Retard Request Circuit Fault
P1778 Transmission Reverse I/P Circuit Malfunction
P1779 TCIL Circuit Malfunction
P1780 Trans Control Switch (O/D Cancel) Out of Self Test Range
P1781 4X4 Switch Out of Self Test Range
P1782 P/ES Circuit Out Of Self Test Range
P1783 Transmission Overtemperature Condition
P1784 Transmission Mechanical Failure - First And Reverse
P1785 Transmission Mechanical Failure - First And Second
P1786 3-2 Downshift Error
P1787 2-1 Downshift Error
P1788 Pressure Control Solenoid "B" Open Circuit
P1789 Pressure Control Solenoid "B" Short Circuit
P1790 TP (Mechanical) Circuit Malfunction
P1791 TP (Electric) Circuit Malfunction
P1792 Barometer Pressure Circuit Malfunction
P1793 Intake Air Volume Circuit Malfunction
P1794 Battery Voltage Circuit Malfunction
P1795 Idle Switch Circuit Malfunction
P1796 Kick Down Switch Circuit Malfunction
P1797 Neutral Switch Circuit Malfunction
P1798 Coolant Temperature Circuit Malfunction
P1799 Hold Switch Circuit Malfunction
P1800 Transmission Clutch Interlock Safety Switch Circuit Failure
P1801 Transmission Clutch Interlock Safety Switch Open Circuit
P1802 Transmission Clutch Interlock Safety Switch Short Circuit To Battery
P1803 Transmission Clutch Interlock Safety Switch Short Circuit To Ground
P1804 Transmission 4-Wheel Drive High Indicator Circuit Failure
P1805 Transmission 4-Wheel Drive High Indicator Open Circuit
P1806 Transmission 4-Wheel Drive High Indicator Short Circuit To Battery
P1807 Transmission 4-Wheel Drive High Indicator Short Circuit To Ground
P1808 Transmission 4-Wheel Drive Low Indicator Circuit Failure
P1809 Transmission 4-Wheel Drive Low Indicator Open Circuit
P1810 TFP Valve Position Switch Circuit/ Transmission 4-Wheel Drive Low Indicator Short Circuit To Battery
P1811 Transmission 4-Wheel Drive Low Indicator Short Circuit To Ground
P1812 Transmission 4-Wheel Drive Mode Select Circuit Failure
P1813 Transmission 4-Wheel Drive Mode Select Open Circuit
P1814 Transmission 4-Wheel Drive Mode Select Short Circuit To Battery
P1815 Transmission 4-Wheel Drive Mode Select Short Circuit To Ground
P1816 Transmission Neutral Safety Switch Circuit Failure
P1817 Transmission Neutral Safety Switch Open Circuit
P1818 Transmission Neutral Safety Switch Short Circuit To Battery
P1819 Transmission Neutral Safety Switch Short Circuit To Ground
P1820 Transmission Transfer Case Clockwise Shift Relay Coil Circuit Failure
P1821 Transmission Transfer Case Clockwise Shift Relay Coil Open Circuit
P1822 Transmission Transfer Case Clockwise Shift Relay Coil Short Circuit To Battery
P1823 Transmission Transfer Case Clockwise Shift Relay Coil Short Circuit To Ground
P1824 Transmission 4-Wheel Drive Clutch Relay Circuit Failure
P1825 Transmission 4-Wheel Drive Clutch Relay Open Circuit
P1826 Transmission 4-Wheel Drive Low Clutch Relay Circuit To Battery
P1827 Transmission 4-Wheel Drive Low Clutch Relay Circuit To Ground
P1828 Transmission Transfer Case Counter Clockwise Shift Relay Coil Circuit Failure
P1829 Transmission Transfer Case Counter Clockwise Shift Relay Coil Open Circuit
P1830 Transmission Transfer Case Counter Clockwise Shift Relay Coil Short Circuit To Battery
P1831 Transmission Transfer Case Counter Clockwise Shift Relay Coil Short Circuit To Ground
P1832 Transmission Transfer Case Differential Lock-Up Solenoid Circuit Failure
P1833 Transmission Transfer Case Differential Lock-Up Solenoid Open Circuit
P1834 Transmission Transfer Case Differential Lock-Up Solenoid Short Circuit To Battery
P1835 Transmission Transfer Case Differential Lock-Up Solenoid Short Circuit To Ground
P1836 Transmission Transfer Case Front Shaft Speed Sensor Circuit Failure
P1837 Transmission Transfer Case Rear Shaft Speed Sensor Circuit Failure
P1838 Transmission Transfer Case Shift Motor Circuit Failure
P1839 Transmission Transfer Case Shift Motor Open Circuit
P1840 Transmission Transfer Case Shift Motor Short Circuit To Battery
P1841 Transmission Transfer Case Shift Motor Short Circuit To Ground
P1842 Transmission Transfer Case Differential Lock-Up Feedback Switch Circuit Failure
P1843 Transmission Transfer Case Differential Lock-Up Feedback Switch Open Circuit
P1844 Transmission Transfer Case Differential Lock-Up Feedback Switch Short Circuit To Battery
P0002 Fuel Volume Regulator Control Circuit Range/Performance
P0003 Fuel Volume Regulator Control Circuit Low
P0004 Fuel Volume Regulator Control Circuit High
P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1)
P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
P0032 HO2S Heater Control Circuit High (Bank 1 Sensor 1)
P0033 Turbo Charger Bypass Valve Control Circuit
P0034 Turbo Charger Bypass Valve Control Circuit Low
P0035 Turbo Charger Bypass Valve Control Circuit High
P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2)
P0039 Turbo/Super Charger Bypass Valve Control Circuit Range/Performance
P0042 HO2S Heater Control Circuit (Bank 1 Sensor 3)
P0043 HO2S Heater Control Circuit Low (Bank 1 Sensor 3)
P0044 HO2S Heater Control Circuit High (Bank 1 Sensor 3)
P0050 HO2S Heater Control Circuit (Bank 2 Sensor 1)
P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)
P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1)
P0056 HO2S Heater Control Circuit (Bank 2 Sensor 2)
P0057 HO2S Heater Control Circuit Low (Bank 2 Sensor 2)
P0058 HO2S Heater Control Circuit High (Bank 2 Sensor 2)
P0063 HO2S Heater Control Circuit Low (Bank 2 Sensor 3)
P0064 HO2S Heater Control Circuit High (Bank 2 Sensor 3)
P0065 Air Assisted Injector Control Range/Performance
P0066 Air Assisted Injector Control Circuit or Circuit Low
P0067 Air Assisted Injector Control Circuit High
P0070 Ambient Air Temperature Sensor Circuit
P0071 Ambient Air Temperature Sensor Range/Performance
P0073 Ambient Air Temperature Sensor Circuit High
P0074 Ambient Air Temperature Sensor Circuit Intermittent
P0075 Intake Valve Control Solenoid Circuit (Bank 1)
P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)
P0077 Intake Valve Control Solenoid Circuit High (Bank 1)
P0078 Exhaust Valve Control Solenoid Circuit (Bank 1)
P0079 Exhaust Valve Control Solenoid Circuit Low (Bank 1)
P0082 Intake Valve Control Solenoid Circuit Low (Bank 2)
P0083 Intake Valve Control Solenoid Circuit High (Bank 2)
P0084 Exhaust Valve Control Solenoid Circuit (Bank 2)
P0085 Exhaust Valve Control Solenoid Circuit Low (Bank 2)
P0087 Fuel Rail/System Pressure - Too Low
P0088 Fuel Rail/System Pressure - Too High
P0089 Fuel Pressure Regulator 1 Performance
P0098 Intake Air Temperature Sensor 2 Circuit High
P1178 ( open )
P1218 CID High
P1219 CID Low
P1298 IDM Failure
P1482 SCP
Opel Zafira y20dth
MB E 320 CDI W 211
Skoda 105 L -ex
nie som na fejsbúku
MB E 320 CDI W 211
Skoda 105 L -ex
nie som na fejsbúku
- franticek6
- Auto: Zafira A
Celková informace : Převzato a schválené použití materiálu od Sergeje z http://www.astra-h.ru" onclick="window.open(this.href);return false;
Dopřeloženo
Pokud se na panelu přístrojů zobrazí autíčko s klíčem – tak to znamená, že v chodu automobilu vznikla chyba a je třeba stanovit poruchu.Takřka, v běžných poměrech potřebujeme dealerský scaner Tech 2 . A jestliže jej nemáme po ruce nebo nechceme jen tak jet k dealerovi a utrácet všechny naše peníze a strácet čas,tak si můžeme pomoci tímto návodem!
Pro MKPP nebo Easytronic :
• Současně zmáčknu pedal plynu a brzdy a držíme je.
• Potom zasazuji klíč do spínače zapalování
• otáčím zapalování ( ale nestartujeme auto !!! )
• Držím pár sekund, stále držím pedály,než se ukáže okno
Pro AKPP :
• Zasazujeme klíč do spínače zapalování.
• Otáčím zapalování ( motor nestartujeme! )
• Nohy na brzdový pedál a držím
• Řadičku AKPP v poloze "D" (Drive)
• Otočím zpět zapalování a povolím brzdy.
• Nohy nyní dám už spolu na plynový pedál, brzdový pedál a držím je.
Jestliže jsme udělaly vše dobře, tak na místě kilometrů bude zobrazeno oznámení "ECN" (error code number) a kódy chyb.
• Při šlapání na pedály nemusíme silně tlačit,
• První 4 čísla ukazují klíč chyby , následující dvě její význam .
• Pokud se ukazuje jen nula, tak se mluví o nedostatku chyb ,
• Důležitě !!! Pokud je číslic 5, například, 70405 , tak to před ně doplňte 0, abychom obdržely číslo 070405 . Dále - jako obvykle.
Například:
ECN
161450 : problém se spojením mezi imobilizérem a klíčkem
(P1614 Wrong transponder key error (the chip is still in the key?) )
Veškeré chyby od GM (anglicky) :arrow: http://www.edgeproducts.com/product_ima" onclick="window.open(this.href);return false; ... pdf-40.pdf
Některé přeložené kodové chyby
070458 Nesprávná funkce vstupního obvodu spínače spojky
B0132 voltáž baterie vysoké C - 123
B0132 voltáž slabé baterie C - 123
B0158 vně voltáže snímače teplot je příliš malá DIS ( informace displej) C - 015
B0158 vně obvodu snímače teplot voltáž deset otevřené nebo velké DIS ( informace displej) C - 015
B0283 vyhřívání zadního skla vozu špatná funkce teplo, větrání a klimatizace B - 015
B1000 vymění řídicí jednotku - EEPROM chyby C - 002
B1000 vymění řídicí jednotku - hardware chyby C - 002
B1000 regulátor k tomu, aby vyměnil C - 002
B1000 regulátor špatná funkce C - 002
B1001 airbag řídicí jednotka je zamčený hardware a softwarový B - 003
B1001 vozidlové identifikační číslo je naprogramovaný hardware a softwarový B - 005
B1001 chyba programovací hardware a softwarový B - 003
B1001 Linkslenker - /Rechtslenker projektové chyby C - 002
B1001 regulátor je kalibrovaný hardware a softwarový B - 003
B1001 regulátor je naprogramovaný hardware a softwarový B - 003
B1001 regulátor programovací hardware a softwarový B - 003
B1001 varianty kódují je naprogramovaný hardware a softwarový B - 004
B1001 konfigurace varianty je naprogramovaný hardware a softwarový B - 003
B1006 regulátor k tomu, aby vyměnil C - 002
B1009 regulátor programovací hardware a softwarový B - 003
B1016 vozidlové identifikační číslo je naprogramovaný hardware a softwarový B - 005
B1019 regulátor ve vydání stojí C - 002
B1325 síťové napětí síla příliš velký B - 003
B1325 síťové napětí síla příliš malý B - 003
B1375 Geschaltete síťové napětí (A zapalování) není hodnověrný s CAN signalizovat B - 005
B1385 terminálová 15A dysfunkce B - 004
B1390 komfortní obvod uzavření voltáž síla příliš malá okna C - 009
B1395 motor běží příliš malou signální voltáž EHPS (elektrolyticky pokovovat hydraulické pomocné mechanické řízení volantu) C - 003
B1420 napájecí napětí je příliš velký C - 124
B1420 napájecí napětí příliš malý C - 124
B1421 napájecí napětí signál není v prostoru cílech C - 124
B1428 vystřídá startéry dysfunkce C - 127
B1441 Geschaltete síťové napětí (zapalování A) síla příliš velký C - 125
B1441 Geschaltete síťové napětí (zapalování ON) voltáž příliš malý C - 125
B1451 směnové vybavení voltáže příliš velký nebo otevřený obvod C - 106
B1451 doplňky vystřídají voltáž obvodu je příliš velký C - 106
B1453 Geschaltete síťové napětí (zapalování A) síla příliš velký C - 125
B1453 Geschaltete síťové napětí (zapalování ON) voltáž příliš malý C - 125
B2961 poziční zapalování spínač s klíčem obvod špatná funkce C - 002
B3601 držící magnetický klíč vystřídá obvod špatnou funkci AF 17 - 4 automat 4 - rychlostní převodovka C - 005
B3644 přepínací kanálové vysoké kolo vzdálená přilepená RQ (zábavní hlavní jednotka) C - 012
B3644 přepínací kanálové vysoké kolo obvod dálkového ovládání odpor ne v prostoru cílech RQ (zábavní hlavní jednotka) C - 012
B3645 kanál dolů knoflíkové kolo dálkového ovládání přilepilo RQ (zábavní hlavní jednotku) C - 012
B3645 přepínací kanál dolů volant obvod dálkového ovládání odpor ne v prostoru cílech RQ (zábavní hlavní jednotka) C - 012
Rolování pravé B3646 kolo přilepilo RQ (zábavní hlavní jednotku) C - 012
Rolování pravý B3646 obvod kola otevřená RQ (zábavní hlavní jednotka) C - 012
Rolování pravý B3646 obvod kola odpor ne v prostoru cílech RQ (zábavní hlavní jednotka) C - 012
B3647 přepínací hlasové kolo dálkového ovládání přilepilo RQ (zábavní hlavní jednotku) C - 012
B3647 přepínací řízení hlasem kolo vzdálený odpor ne v prostoru cílech RQ (zábavní hlavní jednotka) C - 012
B3648 přepínací telefonní kolo vzdálená přilepená RQ (zábavní hlavní jednotka) C - 012
B3648 přepínací telefonní kolo vzdálený odpor ne v prostoru cílech RQ (zábavní hlavní jednotka) C - 012
B3649 Scrolling levé kolo přilepilo RQ (zábavní hlavní jednotku) C - 012
B3649 kolo Scrolling levý otevřený obvod RQ (zábavní hlavní jednotka) C - 012
B3649 Scrolling levé kolo obvod odpor ne v prostoru cílech RQ (zábavní hlavní jednotka) C - 012
C0252 regulátor ve vydání podmínka nebo defekt hardware a softwarový B - 003
Špatná C0550 konfigurační střídání naprogramované řídicí jednotky nebo vadný hardware a softwarový B - 003
C0550 regulátor k tomu, aby vyměnil C - 002
C0550 regulátor je naprogramovaný hardware a softwarový B - 003
C0551 vozidlové identifikační číslo je naprogramovaný hardware a softwarový B - 005
Špatná C0551 konfigurace varianty naprogramovaného hardwaru a softwarový B - 004
C0551 regulátor programovací hardware a softwarový B - 003
C0551 varianty kódují je naprogramovaný hardware a softwarový B - 004
C0551 konfigurace varianty je naprogramovaný hardware a softwarový B - 004
Falešná C0569 systémová konfigurace technických prostředků a softwarový B - 003
C0800 síťové napětí síla příliš velký B - 003
C0800 síťové napětí síla příliš malý B - 003
C0920 regulátor je naprogramovaný hardware a softwarový B - 003
C1523 síťové napětí síla příliš velký C - 105
C1523 síťové napětí síla příliš malý C - 105
C1550 regulátor k tomu, aby vyměnil C - 002
P0070 senzor okolní vzdušná teplotní dysfunkce B - 024
P0100 vzdušná hmotnost / hlasitost dysfunkce nože C - 007
P0100 vzdušná hmotnost / hlasitost signál nože příliš velký C - 007
P0100 množství vzdušné hmotnosti příliš malý nůž signalizuje C - 007
P0100 metr vzdušné hmotnosti chyba
P0105 mnohonásobný snímač tlaku vtoku napěťové chyby
P0110 vtok senzor signál je příliš velký C - 008
P0110 vtok senzor signál malý C - 008
P0110 Ansauglufttemperaturf?hler chyba
P0110 datové sběrnice CAN, ne komunikace s ECM (motorovou řídicí jednotkou) Fahrzeugbezogene Pr?fanleitung B - 019
P0115 datové sběrnice CAN, ne komunikace s ECM (motorovou řídicí jednotkou) Fahrzeugbezogene Pr?fanleitung B - 019
P0115 snímač teploty chladiva chyby
P0115 motorový snímač teploty chladiva není v prostoru cílech chlazených motorový C - 002
P0115 teplota chladiva kapaliny motoru signál je příliš velké chladicí motorový C - 002
P0115 teplota chladiva kapaliny motoru signál je příliš malé chlazení motoru C - 002
P0120 škrticí klapky / nožní výhodné místo dárce "A" není prostor cíle C - 005
P0120 škrticí klapky / nožní výhodné místo dárce "A" signál je příliš velký C - 005
P0120 škrticí klapky / nožní výhodné místo dárce "A" signál malý C - 005
Ne P0130 pravděpodobnost mezi O2 senzorem 1 banka 1 a O2 senzor 2 banka 1 B - 020
P0130 lambda - sonda dysfunkce (banka 1 senzor 1) B - 020
P0130 lambda - snímač obvod ne v prostoru cílech (banka 1 senzor 1) B - 025
P0130 O2 senzor voltáž obvodu vysoká (banka 1 senzor 1) C - 019
P0130 O2 senzor voltáž obvodu nízká (banka 1 senzor 1) C - 019
P0135 lambda - sonda ohřívací dysfunkce (banka 1 senzor 1) B - 012
P0135 lambda - sonda teplo otevře (banku 1 senzor 1) B - 028
P0135 lambda - sonda žhavicí napětí je příliš velká (banka 1 senzor 1) B - 012
P0135 lambda - sonda žhavicí napětí je příliš malá (banka 1 senzor 1) B - 012
Ne P0136 pravděpodobnost mezi O2 senzorem 1 banka 1 a O2 senzor 2 banka 1 B - 027
P0136 lambda - sonda dysfunkce (banka 1 senzor 2) B - 027
P0136 lambda - snímač obvod ne v prostoru cílech (banka 1 senzor 2) B - 026
P0136 O2 senzor voltáž obvodu vysoká (banka 1 senzor 2) C - 023
P0136 O2 senzor voltáž obvodu nízká (banka 1 senzor 2) C - 023
P0141 lambda - sonda ohřívací dysfunkce (banka 1 senzor 2) B - 013
P0141 lambda - sonda teplo otevře (banku 1 senzor 2) B - 029
P0141 lambda - sonda žhavicí napětí je příliš velká (banka 1 senzor 2) B - 013
P0141 lambda - sonda žhavicí napětí je příliš malá (banka 1 senzor 2) B - 013
P0170 palivová dysfunkce korekce (banka 1) B - 016
P0180 palivové spojení nakrátko snímače teplot/ přerušení
P0190 Mechanical chyba v palivové poruše systému
P0195 ?ltemperaturf?hler chyba (v Y17DT a Y17DTL ne VERBAUT!)
P0201 válec 1 vstřikovač signalizuje příliš velký B - 011
P0201 válec 1 vstřikovač dává znamení malé B - 011
P0201 válec 1 obvod vstřikovače otevře B - 011
P0202 válec 2 vstřikovač signalizuje příliš velký B - 011
P0202 válec 2 vstřikovač dává znamení malé B - 011
P0202 válec 2 obvod vstřikovače otevře B - 011
P0203 válec 3 vstřikovač signalizuje příliš velký B - 011
P0203 válec 3 vstřikovač dává znamení malé B - 011
P0203 válec 3 obvod vstřikovače otevře B - 011
P0204 válec 4 vstřikovač signalizuje příliš velký B - 011
P0204 válec 4 vstřikovač dává znamení malé B - 011
P0204 válec 4 obvod vstřikovače otevře B - 011
P0216 Einspritzbeginn chyba
P0219 otáčení motoru je příliš velký C - 025
P0220 škrticí klapky / nožní výhodné místo dárce "B" není v prostoru cílech C - 005
P0220 škrticí klapky / nožní výhodné místo dárce "B" signál je příliš velký C - 005
P0220 škrticí klapky / nožní výhodné místo dárce "B" signál malý C - 005
P0230 primární obvod palivového čerpadla signál je příliš velký B - 010
P0230 primární obvod palivového čerpadla signál malý B - 010
P0234 záporná odchylka v regulačním obvodu plnícího tlaku
P0235 signál plnicího tlaku dárce velkým C - 031
P0235 dárce plnicího tlaku signál příliš malý C - 031
P0243 ventil plnicího tlaku voltáž příliš velký C - 032
P0243 ventil plnicího tlaku voltáž je příliš nízký C - 032
P0243 ventil plnicího tlaku otevřeného obvodu C - 032
P0251 přepadový ventil / čerpadlo řídicí jednotka dysfunkce (99% čerpadlo řídicí jednotka zemřela)
Několik P0300 válce selže objevený B - 021
P0301 válec selže objevený 1 B - 021
P0302 válec selže objevený 2 B - 021
P0303 válec 3 selže objevený B - 021
P0304 válec selže objevený 4 B - 021
P0313 selže v nízkých hladinách palivech objevila B - 021
P0325 Klopfsensor 1 signalizuje příliš velkou (banku nebo jednotlivý senzor 1) B - 022
P0325 Klopfsensor 1 signalizuje příliš malou (banku nebo jednotlivý senzor 1) B - 022
P0335 snímač postavení klikového hřídele špatný signální C - 002
P0335 snímač postavení klikového hřídele žádný signál
P0335 snímač postavení klikového hřídele signál není v prostoru cílech C - 002
P0340 motorová odchylka rychlosti '
P0340 vačková hřídel poziční dysfunkce dárce C - 009
P0340 vačková hřídel poziční signál kodéru velký C - 009
P0340 vačková hřídel poziční signál kodéru malý C - 009
P0340 vačková hřídel poziční obvod kodéru otevře C - 009
P0340 snímač vačkového hřídele signál není v prostoru cílech C - 009
P0370 čerpadla výhodné místo signál neplatný
P0380 Vorgl?hanlage spojení nakrátko/přerušení
P0381 Gl?hzeitkontrolleuchte spojení nakrátko/přerušení
P0400 EGR chyby ventilu
P0420 efektivita katalyzátoru pod limitem (banka 1) B - 017
P0441 otvor tanku systémový špatný otvor tanku River B - 014
P0443 větrací ventil palivové nádrže otevřou okresní B - 014
P0443 větrací ventil palivové nádrže voltáž vysoký B - 014
P0443 větrací ventil palivové nádrže voltáž nízký B - 014
P0460 palivový snímač hladiny signál není v prostoru cílech IPC (nástroj) B - 012
P0480 fanoušek chladiče (malé) spojení nakrátko/ přerušení
P0481 fanoušek chladiče (velké) spojení nakrátko/ přerušení
P0500 vozidlový rychlostní signál není v zadané hodnotě rozsahové B - 023
P0500 dálková četnost (zaměstnavatel) chyba (přichází z ABS jednotky)
P0501 vozidlový rychlostní signál není v zadané hodnotě rozsahové B - 023
P0505 datové sběrnice CAN, ne komunikace s ECM (motorovou řídicí jednotkou) Fahrzeugbezogene Pr?fanleitung B - 019
P0505 zahálející spojení nakrátko regulátoru/ přerušení
P0520 motorový tlakový olejový spínač / senzor není v prostoru cílech IPC (nástroj) C - 018
P0530 klimatizační zařízení tisková chyba
P0530 vzdušné kondicionér signál snímače tlaku je příliš velké teplo, větrání a klimatizace C - 009
P0530 vzdušné kondicionér signál snímače tlaku je příliš malé teplo, větrání a klimatizace C - 009
P0560 napěťová chyba baterie (přes nebo pod napětím)
P0560 síťové napětí dysfunkce C - 110
P0560 síťové napětí vně Area C - 110
P0560 síťové napětí síla příliš velký C - 109
P0560 výkonové síťové napětí příliš malý C - 109
P0560 síťové napětí příliš vysoký C - 110
P0560 síťové napětí je příliš nízký C - 110
P0560 napájecí napětí příliš vysoký C - 110
P0571 Bremslichtschalter spojení nakrátko/přerušení
P0571 přepne brzdí špatnou funkci osvětlení venkovní / blikadla Appendix B - 014
P050074 Nepohyblivé pevné klapky a tím i neúplné spalování
P0601 regulátor k tomu, aby vyměnil C - 002
P0602 vozidlové identifikační číslo je naprogramovaný hardware a softwarový B - 005
P0602 hlasitost vstřikovače úprava je naprogramovaný hardware a softwarový B - 015
P0602 unavuje rozsah nenaprogramovaný hardware a softwarový B - 003
P0602 bezpečnostní kód je naprogramovaný hardware a softwarový B - 003
P0602 řídicí jednotka C - 002 program
P0602 regulátor programovací hardware a softwarový B - 003
P0602 ECUs chyby v programu (nedostatek mimo -- kóduje programování nebo indexovat)
P0602 konfigurace varianty je naprogramovaný hardware a softwarový B - 004
P0603 ECU EEPROM chyby C - 002
P0603 regulátor k tomu, aby vyměnil C - 002
P0604 chyba kontroleru - RAM C - 002
P0605 EPROM chyby C - 002
P0605 regulátor k tomu, aby vyměnil C - 002
P0606 kontroler vymění chybu (nejhorší případ - celkové poškození řídicí jednotka)
P0606 regulátor špatná funkce C - 002
P0606 kontroler znovu - inicializace C - 004
P0606 síťové napětí příliš vysoký C - 110
P0607 Klopfsensor obvod špatná funkce B - 022
P0607 Klopfsignal jednotka; regulátor k tomu, aby vyměnil B - 022
P0607 kontroler vymění chybu (podívejte se na nad)
P0610 regulátor programovací hardware a softwarový B - 003
P0615 startér vystřídá obvod otevřený C - 127
P0615 Amplifier startér vystřídá teplotu příliš velký C - 127
P0615 startéři napěťoví relé příliš velký C - 127
P0615 vystřídá startéry voltáž příliš malý C - 127
P0621 kontrolní lampa generátoru uspořádání dysfunkce IPC ( nástroj) C - 021
P0650 CAN jet autobusem ne komunikaci s CIM ( jednotkou hřídele volantu) C - 003
P0650 chybový displej kontrola světlá (MI) dysfunkce IPC (nástroj) B - 008
P0703 Bremslichtschalter chyba
P0704 přepínací chyba hnízda
P0704 přepínací dysfunkce hnízda CRC (elektronická regulace otáček) B - 010
P0725 datové sběrnice CAN, ne komunikace s ECM (motorovou řídicí jednotkou) Fahrzeugbezogene Pr?fanleitung B - 019
P0725 motorová odchylka rychlosti '
P0815 přepíná High Turn volant vzdálený přilepený C - 002
P0815 přepíná vysoké kolo vzdálený spínací obvod odpor ne v prostoru cílech C - 002
P0816 přepíná Runterschalten kolo vzdálené přilepený C - 002
P0816 přepíná Runterschalten kolo obvod dálkového ovládání odpor ne v prostoru cílech C - 002
P1100 kritická chyba systému chyba
P1105 Barometrischer spojení nakrátko snímače tlaku/ přerušení
P1105 snímač tlaku signální Barometrischer příliš velký C - 030
P1105 snímač tlaku signální Barometrischer příliš malý C - 030
P1106 dárce plnicího tlaku signál není v prostoru cílech C - 031
P1110 elektronka přepínací ventil chyby
P1120 datové sběrnice CAN, ne komunikace s ECM (motorovou řídicí jednotkou) Fahrzeugbezogene Pr?fanleitung B - 019
P1120 chodidlový senzor 1 spojení nakrátko/přerušení
P1120 chodidlový senzor 1 dává znamení vysoké C - 004
P1120 chodidlový senzor 1 signalizuje příliš nízký C - 004
P1120 chodidlový poziční senzor 1 a 2 chybný signál procento C - 004
P1122 chodidlový senzor 2 spojení nakrátko/přerušení
P1122 chodidlový senzor 2 dává znamení vysoké C - 004
P1122 chodidlový senzor signál je příliš nízký 2 C - 004
P1125 solenoid ventil plnicího tlaku chyby
P1173 Einspritzmengenbegrenzung protože Oeltemperatur chyba
P1180 palivové chyby snímače teplot
P1195 ?ldruckschalter spojení nakrátko/přerušení
P1220 Einspritzdauer monitorovací chyba
P1230 hlavní směnová dysfunkce napájení a komunikační C - 013
P1243 turbodmychadlo na výfukové plyny bypassová solenoid voltáž ventilu příliš velký C - 033
P1243 turbodmychadlo na výfukové plyny bypassová solenoid voltáž ventilu příliš malý C - 033
P1243 turbodmychadlo na výfukové plyny bypassový solenoid otevřený obvod ventilu C - 033
P1243 turbodmychadlo na výfukové plyny obtokový ventil ne v prostoru cílech C - 033
P1335 rychlost motoru signální chyba
P1345 šachta vačky odchylka rychlosti
P1481 fanoušek regulační obvod otevře 1 chlazení motoru B - 004
1 rozdmýchá P1481 voltáž regulačního obvodu chlazení motoru příliš velký B - 004
1 rozdmýchá P1481 voltáž regulačního obvodu příliš malé chlazení motoru B - 004
P1482 fanoušek regulační obvod otevře 2 chlazení motoru B - 004
P1482 fanoušek voltáž regulačního obvodu 2 příliš velké chlazení motoru B - 004
P1482 fanoušek voltáž regulačního obvodu 2 příliš malé chlazení motoru B - 004
P1483 fanoušek regulační obvod otevře 3 chlazení motoru B - 004
3 rozdmýchá P1483 voltáž regulačního obvodu chlazení motoru příliš velký B - 004
3 rozdmýchá P1483 voltáž regulačního obvodu příliš malé chlazení motoru B - 004
P1490 dodatečné čerpadlo chladiva obvod otevře B - 015
P1490 dodatečné čerpadlo chladiva obvod voltáž je příliš velký B - 015
P1490 dodatečné čerpadlo chladiva obvod voltáž příliš malý B - 015
P1500 elektronická autorská dysfunkce průdušnice C - 006
P1501 imobilizace kódovací chyby
P1502 imobilizace chyba
P1503 imobilizace signální chyba
P1515 chodidlová poziční chyba dárce
P1523 autor průdušnice není v prostoru cílech C - 006
P1526 autor průdušnice sníží pozici nenaučenou C - 006
P1530 vysoké napětí směnové klima teplo, větrání a klimatizace B - 016
P1530 nízké napětí směnové klima teplo, větrání a klimatizace B - 016
P1530 klimatizace chyba požadavku
P1530 klimatizace vystřídá obvod otevřené teplo, větrání a klimatizace B - 016
P1540 Climate tlakové signální spojení nakrátko/přerušení
P1560 napěťová chyba baterie
P1560 Geschaltete síťové napětí (zapalování A) signální dysfunkce (CAN) C - 109
P1565 regulace otáček rozhraní dysfunkce CRC (elektronická regulace otáček) B - 006
P1600 točivý moment motoru není hodnověrný B - 030
P1600 regulátor k tomu, aby vyměnil C - 002
P1600 chyba kontroleru
P1601 teplotní chyba kontroleru
P1602 nejvyšší rychlost je naprogramovaný hardware a softwarový B - 003
P1602 programátoři / vymění řídicí jednotku (SG) hardware a softwarový B - 003
P1602 regulátor programovací hardware a softwarový B - 003
P1602 konfigurace varianty je naprogramovaný hardware a softwarový B - 003
P1603 regulátor k tomu, aby vyměnil C - 002
P1604 programátoři / vymění regulátor
P1604 regulátor k tomu, aby vyměnil C - 004
P1606 točivý moment motoru není hodnověrný B - 030
P1606 regulátor k tomu, aby vyměnil C - 002
P1610 imobilizér proti funkce krádeže je naprogramovaný B - 009
P1610 imobilizace dysfunkce Immobilizer B - 009
P1610 imobilizér funkční chyba v programu
P1611 Wrong bezpečnostní kódová chyba
P1611 Wrong bezpečnostní kódová imobilizace B - 015
P1612 imobilizace signální chyba
P1613 imobilizace žádný signální nebo špatný signální Immobilizer B - 008
P1613 imobilizace signální chyba
P1614 Wrong zprostředkovačova klíčová chyba ( čip ještě je v klíči?)
P1614 Wrong zprostředkovačova imobilizace klíčový B - 006
P1614 imobilizér proti krádež špatný signální B - 008
P1615 ECM (řídicí jednotka motoru) identifikace selhala imobilizér B - 006
P1616 CIM ( jednotka hřídele volantu) špatné prostředí indikátorový Immobilizer B - 006
Vyměňte P1620 chybu kontroleru
P1625 směnová porucha napájení
P1630 Kraftstoffeinspritzmenge chyba
P1631 chybové vstřikovací čerpadlo kontroleru
P1635 Vorgl?hanlage chyba
P1650 CAN chyba
P1651 CAN chyba
P1660 palivová Abschaltventil chyba
P1680 výstup teploty chladivy spojení nakrátko/ přerušení
P1690 kontrolní napěťová chyba lampy
P1694 kontrolní voltáž lampy chybové Gl?hzeit
P1811 motorová kroutivá síla signální špatná funkce ABS / TC / ESP (vozidlové otevřené systémy) C - 011
P1814 Invalid signál ECC (elektronické klimatizace) ECC / SAC (elektronické řízení klimatizace) B - 028
P1895 datové sběrnice CAN, ne komunikace s ECM (motorovou řídicí jednotkou) Fahrzeugbezogene Pr?fanleitung B - 019
P1896 datové sběrnice CAN, ne komunikace s ECM (motorovou řídicí jednotkou) Fahrzeugbezogene Pr?fanleitung B - 019
P2638 regulátor k tomu, aby vyměnil C - 002
U0001 CAN autobusový maximální konfigurační seznam je naprogramovaný hardware a softwarový B - 003
U0009 CAN autobusové komunikační uzly ne C - 005
U0101 datové sběrnice CAN, ne komunikace s řídicí jednotkou převodovky C - 003
U0121 CAN jet autobusem ne komunikaci s ABS / TC C - 003
U0140 CAN jet autobusem ne komunikaci s CIM ( jednotkou hřídele volantu) C - 003
U2100 CAN autobusová dysfunkce C - 005
U2100 CAN autobusová komunikační dysfunkce C - 005
U2100 CAN autobusové komunikační chyby C - 005
U2100 No komunikace s CAN- autobusem (velká rychlost) C - 005
U2100 No komunikace s CAN- autobusem (nízká rychlost) C - 005
U2100 No komunikace s CAN- autobusem (střední rychlost) C - 005
U2101 CAN autobus (velká rychlost) maximální konfigurační seznam je naprogramovaný hardware a softwarový B - 003
U2101 CAN autobus (nízká rychlost) maximálního konfiguračního seznamu je naprogramovaný hardware a softwarový B - 003
U2101 CAN autobus (střední rychlost) maximálního konfiguračního seznamu je naprogramovaný hardware a softwarový B - 003
U2101 CAN autobusový maximální konfigurační seznam je naprogramovaný hardware a softwarový B - 003
U2102 CAN autobus (střední rychlost) maximálního konfiguračního seznamu není kompletní hardware a softwarový B - 003
U2103 CAN autobusové komunikační uzly ne C - 005
U2103 CAN autobusový R?cksetzz?hler přetéká C - 005
U2103 CAN- autobusový obvod špatná funkce C - 005
U2103 No komunikace s CAN- autobusem (velká rychlost) C - 005
U2103 No komunikace s CAN- autobusem (nízká rychlost) C - 005
U2104 CAN autobus (velká rychlost) R?cksetzz?hler přetéká C - 005
U2104 CAN autobus (střední rychlost) R?cksetzz?hler přetéká C - 005
U2104 CAN autobusový R?cksetzz?hler přetéká C - 005
U2105 datové sběrnice CAN, ne komunikace s motorovou řídicí jednotkou Fahrzeugbezogene Pr?fanleitung B - 019
U2105 datové sběrnice CAN, ne komunikace s ECM (motorovou řídicí jednotkou) Fahrzeugbezogene Pr?fanleitung B - 019
U2106 datové sběrnice CAN, ne komunikace s řídicí jednotkou převodovky C - 003
U2106 datové sběrnice CAN, ne komunikace s TCM (automatickou řídicí jednotkou převodovkami) C - 003
U2107 CAN jet autobusem ne komunikaci s CIM ( jednotkou hřídele volantu) C - 003
U2107 CAN jet autobusem ne komunikaci s IPC (nástrojem) C - 003
U2108 datové sběrnice CAN, ne komunikace s ABS (proti ) C - 003
U2108 CAN jet autobusem ne komunikaci s ABS / TC C - 003
U2108 programátoři / vymění řídicí jednotku (SG) hardware a softwarový B - 003
U2110 CAN jet autobusem ne komunikaci s ABS / ESP C - 003
U2111 CAN jet autobusem ne komunikaci s EPS (elektronickou výkonový řídicí) C - 003
U2112 datové sběrnice CAN, ne komunikace s CDC "> CDC"> SADS (částí aktivní tlumicí systém) C - 003
U2112 datové sběrnice CAN No komunikace s CDC (elektronickou vlhčejší kontrolou) C - 003
U2113 CAN autobus ne komunikuje se SDM (airbag) C - 003
U2113 CAN autobus ne komunikuje se SDM (snímaným a diagnostickým modulem, airbag) C - 003
U2116 CAN jet autobusem ne komunikaci s IPC (nástrojem) C - 003
U2117 datové sběrnice CAN, ne komunikace s DIS (reklamou) C - 126
U2117 datové sběrnice CAN, ne komunikace s Info - Display C - 126
U2120 datové sběrnice CAN, ne komunikace s AHL (přepínačem dálkových a tlumených světel) C - 003
U2127 datové sběrnice CAN, ne komunikace s ECC (elektronickým klimatem) C - 003
U2139 CAN jet autobusem ne komunikaci s CIM ( jednotkou hřídele volantu) C - 003
U2140 CAN jet autobusem ne komunikaci s CIM ( jednotkou hřídele volantu) C - 003
U2140 datové sběrnice CAN, ne komunikace s UEC (strojovnou elektronika centrální jednotka) C - 003
U2141 datové sběrnice CAN, ne komunikace s REC (zadní elektronikou centrální jednotka) C - 003
U2143 datové sběrnice CAN, ne komunikace se SAS (snímačem úhlu natočením volantu) C - 003
U2144 datové sběrnice CAN, ne komunikace s ACC (přizpůsobivou regulací rychlostmi jízdami) C - 003
U2145 datové sběrnice CAN, ne komunikace se PAS (parkový pilot) C - 003
U2146 datové sběrnice CAN, ne komunikace se SLM (předzesilovačem / Fahrprogrammw?hlhebel) C - 003
U2147 datové sběrnice CAN, ne komunikace s AHS (Zuheizer) C - 003
U2149 datové sběrnice CAN, ne komunikace s TPMS ( monitorovací systémemhuštění pneumatik) C - 003
U2173 datové sběrnice CAN, ne komunikace s PEPS (otevřený & začátek) C - 003
U2174 datové sběrnice CAN, ne komunikace s AHS (Zuheizer) C - 003
U2174 datové sběrnice CAN, ne komunikace s EHS (teplo) C - 003
U2181 datové sběrnice CAN, ne komunikace s elektrohydraulischem automobilem s pevnou střechou C - 003
U2201 datové sběrnice CAN, ne komunikace s RQ (zábavní hlavní jednotkou) C - 003
U2202 datové sběrnice CAN, ne komunikace s CDC (CD přelétavcem) C - 003
U2206 datové sběrnice CAN, ne komunikace s DIS (reklamou) C - 003
U2207 datové sběrnice CAN, ne komunikace s UHP (univerzitou handsfree) C - 003
U2208 datové sběrnice CAN, ne komunikace s ECC (elektronickým klimatem) C - 003
U2213 datové sběrnice CAN, ne komunikace s DAB (digitální zvuk Broadcast) C - 003
U2215 regulátor k tomu, aby vyměnil C - 002
Nepřeložené Anglické kodové chyby
B0132 battery voltage high C- 123
B0132 low battery voltage C- 123
B0158 outside temperature sensor voltage is too small DIS (Information Display) C- 015
B0158 outside temperature sensor circuit voltage ten open or big DIS (Information Display) C- 015
B0283 rear window heater malfunction heating, ventilation and air conditioning B- 015
B1000 replace the control unit - EEPROM errors C- 002
B1000 replace the control unit - hardware errors C- 002
B1000 control device to replace C- 002
B1000 control device malfunction C- 002
B1001 airbag control unit is not locked hardware and software B- 003
B1001 vehicle identification number is not programmed hardware and software B- 005
B1001 error programming hardware and software B- 003
B1001 Linkslenker- /Rechtslenker configuration errors C- 002
B1001 control device is not calibrated hardware and software B- 003
B1001 control device is not programmed hardware and software B- 003
B1001 control device programming hardware and software B- 003
B1001 variants code is not programmed hardware and software B- 004
B1001 variant configuration is not programmed hardware and software B- 003
B1006 control device to replace C- 002
B1009 control device programming hardware and software B- 003
B1016 vehicle identification number is not programmed hardware and software B- 005
B1019 control device in the extradition state C- 002
B1325 system voltage power too large B- 003
B1325 system voltage power too small B- 003
B1375 Geschaltete system voltage (A ignition) is not plausible with CAN signal B- 005
B1385 terminal 15A dysfunction B- 004
B1390 comfort closure circuit voltage power too small windows C- 009
B1395 engine runs too small signal voltage EHPS (electro hydraulic auxiliary power steering) C- 003
B1420 power supply voltage is too large C- 124
B1420 power supply voltage too small C- 124
B1421 supply voltage signal is not in the target area C- 124
B1428 relay starters dysfunction C- 127
B1441 Geschaltete system voltage (Ignition A) Power too big C- 125
B1441 Geschaltete system voltage (ignition ON) voltage too small C- 125
B1451 voltage relay equipment too large or open circuit C- 106
B1451 accessories relay circuit voltage is too large C- 106
B1453 Geschaltete system voltage (Ignition A) Power too big C- 125
B1453 Geschaltete system voltage (ignition ON) voltage too small C- 125
B2961 position ignition key switch circuit malfunction C- 002
B3601 holding magnetic key relay circuit malfunction AF 17- 4 Automatic 4- speed gearbox C- 005
B3644 switch channel high wheel remote stuck RQ (Entertainment Head Unit) C- 012
B3644 switch channel high wheel remote control circuit resistance not in the target area RQ (Entertainment Head Unit) C- 012
B3645 channel down button remote control wheel stuck RQ (Entertainment Head Unit) C- 012
B3645 switch channel down steering wheel remote control circuit resistance not in the target area RQ (Entertainment Head Unit) C- 012
Scrolling right B3646 wheel stuck RQ (Entertainment Head Unit) C- 012
Scrolling right B3646 wheel circuit open RQ (Entertainment Head Unit) C- 012
Scrolling right B3646 wheel circuit resistance not in the target area RQ (Entertainment Head Unit) C- 012
B3647 switch voice remote control wheel stuck RQ (Entertainment Head Unit) C- 012
B3647 switch Voice Control wheel remote resistance not in the target area RQ (Entertainment Head Unit) C- 012
B3648 switch telephone wheel remote stuck RQ (Entertainment Head Unit) C- 012
B3648 switch telephone wheel remote resistance not in the target area RQ (Entertainment Head Unit) C- 012
B3649 Scrolling left wheel stuck RQ (Entertainment Head Unit) C- 012
B3649 wheel Scrolling left open circuit RQ (Entertainment Head Unit) C- 012
B3649 Scrolling left wheel circuit resistance not in the target area RQ (Entertainment Head Unit) C- 012
C0252 control device in the extradition condition or defect hardware and software B- 003
Wrong C0550 configuration variations programmed control unit or defective hardware and software B- 003
C0550 control device to replace C- 002
C0550 control device is not programmed hardware and software B- 003
C0551 vehicle identification number is not programmed hardware and software B- 005
Wrong C0551 variant configuration programmed hardware and software B- 004
C0551 control device programming hardware and software B- 003
C0551 variants code is not programmed hardware and software B- 004
C0551 variant configuration is not programmed hardware and software B- 004
False C0569 system hardware configuration and software B- 003
C0800 system voltage power too large B- 003
C0800 system voltage power too small B- 003
C0920 control device is not programmed hardware and software B- 003
C1523 system voltage power too large C- 105
C1523 system voltage power too small C- 105
C1550 control device to replace C- 002
P0070 sensor ambient air temperature dysfunction B- 024
P0100 air mass / volume knife dysfunction C- 007
P0100 air mass / volume knife signal too large C- 007
P0100 air mass quantities too small knife signal C- 007
P0100 air mass meter error
P0105 intake manifold pressure sensor voltage error
P0110 intake sensor signal is too large C- 008
P0110 intake sensor signal to small C- 008
P0110 Ansauglufttemperaturf?hler error
P0110 CAN bus, no communication with ECM (engine control unit) Fahrzeugbezogene Pr?fanleitung B- 019
P0115 CAN bus, no communication with ECM (engine control unit) Fahrzeugbezogene Pr?fanleitung B- 019
P0115 coolant temperature sensor errors
P0115 engine coolant temperature sensor is not in the target area cooled engine C- 002
P0115 engine coolant temperature signal is too large cooling engine C- 002
P0115 engine coolant temperature signal is too small engine cooling C- 002
P0120 throttle valves / pedal position donor "A" is not a target area C- 005
P0120 throttle valves / pedal position donor "A" signal is too large C- 005
P0120 throttle valves / pedal position donor "A" signal to small C- 005
No P0130 plausibility between O2 sensor 1 Bank 1 and O2 sensor 2 bank 1 B- 020
P0130 lambda probe dysfunction (Bank 1 Sensor 1) B- 020
P0130 lambda sensor circuit not in the target area (Bank 1 Sensor 1) B- 025
P0130 O2 sensor circuit voltage high (Bank 1 Sensor 1) C- 019
P0130 O2 sensor circuit voltage low (Bank 1 Sensor 1) C- 019
P0135 lambda probe heating dysfunction (Bank 1 Sensor 1) B- 012
P0135 lambda probe heating open (Bank 1 Sensor 1) B- 028
P0135 lambda probe heating voltage is too big (Bank 1 Sensor 1) B- 012
P0135 lambda probe heating voltage is too small (Bank 1 Sensor 1) B- 012
No P0136 plausibility between O2 sensor 1 Bank 1 and O2 sensor 2 bank 1 B- 027
P0136 lambda probe dysfunction (Bank 1 Sensor 2) B- 027
P0136 lambda sensor circuit not in the target area (Bank 1 Sensor 2) B- 026
P0136 O2 sensor circuit voltage high (Bank 1 Sensor 2) C- 023
P0136 O2 sensor circuit voltage low (Bank 1 Sensor 2) C- 023
P0141 lambda probe heating dysfunction (Bank 1 Sensor 2) B- 013
P0141 lambda probe heating open (Bank 1 Sensor 2) B- 029
P0141 lambda probe heating voltage is too big (Bank 1 Sensor 2) B- 013
P0141 lambda probe heating voltage is too small (Bank 1 Sensor 2) B- 013
P0170 fuel correction dysfunction (Bank 1) B- 016
P0180 fuel temperature sensor short- circuit/interruption
P0190 Mechanical fault in the fuel system failure
P0195 ?ltemperaturf?hler error (at Y17DT and Y17DTL not VERBAUT!)
P0201 cylinder 1 injector signal too large B- 011
P0201 cylinder 1 injector signal to small B- 011
P0201 cylinder 1 injector circuit open B- 011
P0202 cylinder 2 injector signal too large B- 011
P0202 cylinder 2 injector signal to small B- 011
P0202 cylinder 2 injector circuit open B- 011
P0203 cylinder 3 injector signal too large B- 011
P0203 cylinder 3 injector signal to small B- 011
P0203 cylinder 3 injector circuit open B- 011
P0204 cylinder 4 injector signal too large B- 011
P0204 cylinder 4 injector signal to small B- 011
P0204 cylinder 4 injector circuit open B- 011
P0216 Einspritzbeginn error
P0219 engine speed is too large C- 025
P0220 throttle valves / pedal position donor "B" is not in the target area C- 005
P0220 throttle valves / pedal position donor "B" signal is too large C- 005
P0220 throttle valves / pedal position donor "B" signal to small C- 005
P0230 fuel pump primary circuit signal is too large B- 010
P0230 fuel pump primary circuit signal to small B- 010
P0235 boost pressure signal to donors large C- 031
P0235 boost pressure donor signal too small C- 031
P0243 boost pressure valve voltage too large C- 032
P0243 boost pressure valve voltage is too low C- 032
P0243 boost pressure valve open circuit C- 032
P0251 overflow valve / pump control unit dysfunction (99% pump control unit died)
Several P0300 cylinder misfire detected B- 021
P0301 cylinder misfire detected 1 B- 021
P0302 cylinder misfire detected 2 B- 021
P0303 cylinder 3 misfire detected B- 021
P0304 cylinder misfire detected 4 B- 021
P0313 misfire at low fuel levels detected B- 021
P0325 Klopfsensor 1 signal too big (bank or individual sensor 1) B- 022
P0325 Klopfsensor 1 signal too small (bank or individual sensor 1) B- 022
P0335 crankshaft sensor wrong signal C- 002
P0335 crankshaft sensor no signal
P0335 crankshaft sensor signal is not in the target area C- 002
P0340 engine speed error '
P0340 camshaft position donor dysfunction C- 009
P0340 camshaft position encoder signal to big C- 009
P0340 camshaft position encoder signal to small C- 009
P0340 camshaft position encoder circuit open C- 009
P0340 camshaft sensor signal is not in the target area C- 009
P0370 pumps position signal void
P0380 Vorgl?hanlage short- circuit/interruption
P0381 Gl?hzeitkontrolleuchte short- circuit/interruption
P0400 EGR valve errors
P0420 catalyst efficiency under limit (Bank 1) B- 017
P0441 tank vent system wrong tank vent River B- 014
P0443 fuel tank vent valve open District B- 014
P0443 fuel tank vent valve voltage high B- 014
P0443 fuel tank vent valve voltage low B- 014
P0460 fuel level sensor signal is not in the target area IPC (instrument) B- 012
P0480 cooler fan (small) short- circuit/interruption
P0481 cooler fan (big) short- circuit/interruption
P0500 vehicle speed signal is not in setpoint range B- 023
P0500 distance frequency (employer) error (comes from ABS unit)
P0501 vehicle speed signal is not in setpoint range B- 023
P0505 CAN bus, no communication with ECM (engine control unit) Fahrzeugbezogene Pr?fanleitung B- 019
P0505 idling regulator short- circuit/interruption
P0520 engine oil pressure switch / sensor is not in the target area IPC (instrument) C- 018
P0530 air conditioners misprint
P0530 air conditioners pressure sensor signal is too large heating, ventilation and air conditioning C- 009
P0530 air conditioners pressure sensor signal is too small heating, ventilation and air conditioning C- 009
P0560 battery voltage error (over or under voltage)
P0560 system voltage dysfunction C- 110
P0560 system voltage outside Area C- 110
P0560 system voltage power too large C- 109
P0560 power system voltage too small C- 109
P0560 system voltage too high C- 110
P0560 system voltage is too low C- 110
P0560 supply voltage too high C- 110
P0571 Bremslichtschalter short- circuit/interruption
P0571 switches brake malfunction exterior lighting / flasher Appendix B- 014
P0601 control device to replace C- 002
P0602 vehicle identification number is not programmed hardware and software B- 005
P0602 injector volume adjustment is not programmed hardware and software B- 015
P0602 tires extent not programmed hardware and software B- 003
P0602 Security code is not programmed hardware and software B- 003
P0602 Control Unit C- 002 program
P0602 control device programming hardware and software B- 003
P0602 ECUs programming errors (lack of out- of- code programming or index)
P0602 variant configuration is not programmed hardware and software B- 004
P0603 ECU EEPROM errors C- 002
P0603 control device to replace C- 002
P0604 controller error - RAM C- 002
P0605 EPROM errors C- 002
P0605 control device to replace C- 002
P0606 controller replace error (Worst Case - Total damage control unit)
P0606 control device malfunction C- 002
P0606 controller re- initialization C- 004
P0606 system voltage too high C- 110
P0607 Klopfsensor circuit malfunction B- 022
P0607 Klopfsignal module; control device to replace B- 022
P0607 controller replace error (see above)
P0610 control device programming hardware and software B- 003
P0615 starter relay circuit open C- 127
P0615 Amplifier starter relay temperature too large C- 127
P0615 starters voltage relay too large C- 127
P0615 relay starters voltage too small C- 127
P0621 generator control lamp arrangement dysfunction IPC (instrument) C- 021
P0650 CAN bus no communication with CIM (Steering Column module) C- 003
P0650 error display control light (MI) dysfunction IPC (instrument) B- 008
P0703 Bremslichtschalter error
P0704 clutch switch error
P0704 clutch switch dysfunction CRC (electronic speed control) B- 010
P0725 CAN bus, no communication with ECM (engine control unit) Fahrzeugbezogene Pr?fanleitung B- 019
P0725 engine speed error '
P0815 switches High Turn the steering wheel remote stuck C- 002
P0815 switches high wheel remote switching circuit resistance not in the target area C- 002
P0816 switches Runterschalten wheel remote stuck C- 002
P0816 switches Runterschalten wheel remote control circuit resistance not in the target area C- 002
P1100 Critical System Error Error
P1105 Barometrischer pressure sensor short- circuit/interruption
P1105 pressure sensor signal Barometrischer too large C- 030
P1105 pressure sensor signal Barometrischer too small C- 030
P1106 boost pressure donor signal is not in the target area C- 031
P1110 vacuum tube switching valve errors
P1120 CAN bus, no communication with ECM (engine control unit) Fahrzeugbezogene Pr?fanleitung B- 019
P1120 pedal sensor 1 short- circuit/interruption
P1120 pedal sensor 1 signal to high C- 004
P1120 pedal sensor 1 signal too low C- 004
P1120 pedal position sensor 1 and 2 false signal ratio C- 004
P1122 pedal sensor 2 short- circuit/interruption
P1122 pedal sensor 2 signal to high C- 004
P1122 pedal sensor signal is too low 2 C- 004
P1125 boost pressure solenoid valve errors
P1173 Einspritzmengenbegrenzung because Oeltemperatur error
P1180 fuel temperature sensor errors
P1195 ?ldruckschalter short- circuit/interruption
P1220 Einspritzdauer monitoring error
P1230 main relay dysfunction power supply and communication C- 013
P1243 turbocharger bypass solenoid valve voltage too large C- 033
P1243 turbocharger bypass solenoid valve voltage too small C- 033
P1243 turbocharger bypass solenoid valve open circuit C- 033
P1243 turbocharger bypass valve not in the target area C- 033
P1335 engine speed signal error
P1345 cam shaft speed error
P1481 fan control circuit open 1 engine cooling B- 004
1 fan P1481 control circuit voltage engine cooling too large B- 004
1 fan P1481 control circuit voltage too small engine cooling B- 004
P1482 fan control circuit open 2 engine cooling B- 004
P1482 fan control circuit voltage 2 too big engine cooling B- 004
P1482 fan control circuit voltage 2 too small engine cooling B- 004
P1483 fan control circuit open 3 engine cooling B- 004
3 fan P1483 control circuit voltage engine cooling too large B- 004
3 fan P1483 control circuit voltage too small engine cooling B- 004
P1490 additional coolant pump circuit open B- 015
P1490 additional coolant pump circuit voltage is too large B- 015
P1490 additional coolant pump circuit voltage too small B- 015
P1500 electronic throttle author dysfunction C- 006
P1501 immobiliser coding errors
P1502 immobiliser error
P1503 immobiliser signal error
P1515 donor pedal position error
P1523 throttle author is not in the target area C- 006
P1526 throttle author lower position not learned C- 006
P1530 high voltage relay climate heating, ventilation and air conditioning B- 016
P1530 low voltage relay climate heating, ventilation and air conditioning B- 016
P1530 air conditioning requirement error
P1530 air conditioning relay circuit open heating, ventilation and air conditioning B- 016
P1540 Climate pressure signal short- circuit/interruption
P1560 battery voltage error
P1560 Geschaltete system voltage (Ignition A) signal dysfunction (CAN) C- 109
P1565 interface speed control dysfunction CRC (electronic speed control) B- 006
P1600 engine torque is not plausible B- 030
P1600 control device to replace C- 002
P1600 controller error
P1601 temperature controller error
P1602 Maximum speed is not programmed hardware and software B- 003
P1602 programmers / Replace control unit (SG) hardware and software B- 003
P1602 control device programming hardware and software B- 003
P1602 variant configuration is not programmed hardware and software B- 003
P1603 control device to replace C- 002
P1604 programmers / Replace control device
P1604 control device to replace C- 004
P1606 engine torque is not plausible B- 030
P1606 control device to replace C- 002
P1610 immobilizer anti- theft function is not programmed B- 009
P1610 immobiliser dysfunction Immobilizer B- 009
P1610 immobilizer function programming error
P1611 Wrong security code error
P1611 Wrong security code immobiliser B- 015
P1612 immobiliser signal error
P1613 immobiliser no signal or wrong signal Immobilizer B- 008
P1613 immobiliser signal error
P1614 Wrong transponder immobiliser key B- 006
P1614 immobilizer anti- theft wrong signal B- 008
P1615 ECM (engine control unit) Identification failed Immobilizer B- 006
P1616 CIM (Steering Column module) wrong environment indicator Immobilizer B- 006
Replace P1620 controller error
P1625 relay power supply fault
P1630 Kraftstoffeinspritzmenge error
P1631 controller error injection pump
P1635 Vorgl?hanlage error
P1650 CAN error
P1651 CAN error
P1660 fuel Abschaltventil error
P1680 coolant temperature output short- circuit/interruption
P1690 control lamp voltage error
P1694 control lamp voltage error Gl?hzeit
P1811 engine torque signal malfunction ABS / TC / ESP (vehicle dynamics system) C- 011
P1814 Invalid signal of ECC (Electronic air conditioning) ECC / SAC (Electronic climate control) B- 028
P1895 CAN bus, no communication with ECM (engine control unit) Fahrzeugbezogene Pr?fanleitung B- 019
P1896 CAN bus, no communication with ECM (engine control unit) Fahrzeugbezogene Pr?fanleitung B- 019
P2638 control device to replace C- 002
U0001 CAN bus maximum configuration list is not programmed hardware and software B- 003
U0009 CAN bus communication nodes no C- 005
U0101 CAN bus, no communication with gearbox control unit C- 003
U0121 CAN bus no communication with ABS / TC C- 003
U0140 CAN bus no communication with CIM (Steering Column module) C- 003
U2100 CAN bus dysfunction C- 005
U2100 CAN bus communication dysfunction C- 005
U2100 CAN bus communication errors C- 005
U2100 No communication with CAN- bus (High Speed) C- 005
U2100 No communication with CAN- bus (Low Speed) C- 005
U2100 No communication with CAN- bus (Mid Speed) C- 005
U2101 CAN bus (High Speed) maximum configuration list is not programmed hardware and software B- 003
U2101 CAN bus (Low Speed) maximum configuration list is not programmed hardware and software B- 003
U2101 CAN bus (Mid Speed) maximum configuration list is not programmed hardware and software B- 003
U2101 CAN bus maximum configuration list is not programmed hardware and software B- 003
U2102 CAN bus (Mid Speed) maximum configuration list is not complete hardware and software B- 003
U2103 CAN bus communication nodes no C- 005
U2103 CAN bus R?cksetzz?hler overflow C- 005
U2103 CAN- bus circuit malfunction C- 005
U2103 No communication with CAN- bus (High Speed) C- 005
U2103 No communication with CAN- bus (Low Speed) C- 005
U2104 CAN bus (High Speed) R?cksetzz?hler overflow C- 005
U2104 CAN bus (Mid Speed) R?cksetzz?hler overflow C- 005
U2104 CAN bus R?cksetzz?hler overflow C- 005
U2105 CAN bus, no communication with the engine control unit Fahrzeugbezogene Pr?fanleitung B- 019
U2105 CAN bus, no communication with ECM (engine control unit) Fahrzeugbezogene Pr?fanleitung B- 019
U2106 CAN bus, no communication with gearbox control unit C- 003
U2106 CAN bus, no communication with TCM (automatic transmission control unit) C- 003
U2107 CAN bus no communication with CIM (Steering Column module) C- 003
U2107 CAN bus no communication with IPC (instrument) C- 003
U2108 CAN bus, no communication with ABS (anti- ) C- 003
U2108 CAN bus no communication with ABS / TC C- 003
U2108 programmers / Replace control unit (SG) hardware and software B- 003
U2110 CAN bus no communication with ABS / ESP C- 003
U2111 CAN bus no communication with EPS (Electronic Power Steering) C- 003
U2112 CAN bus, no communication with CDC "> CDC"> SADS (Part Active damping system) C- 003
U2112 CAN bus No communication with CDC (electronic damper control) C- 003
U2113 CAN bus not communicate with SDM (airbag) C- 003
U2113 CAN bus not communicate with SDM (Sensing and Diagnostic Module, airbag) C- 003
U2116 CAN bus no communication with IPC (instrument) C- 003
U2117 CAN bus, no communication with DIS (advertisement) C- 126
U2117 CAN bus, no communication with Info- Display C- 126
U2120 CAN bus, no communication with AHL (headlamp control) C- 003
U2127 CAN bus, no communication with ECC (Electronic Climate) C- 003
U2139 CAN bus no communication with CIM (Steering Column module) C- 003
U2140 CAN bus no communication with CIM (Steering Column module) C- 003
U2140 CAN bus, no communication with UEC (engine room electronics central module) C- 003
U2141 CAN bus, no communication with REC (Rear electronics central module) C- 003
U2143 CAN bus, no communication with SAS (steering wheel angle sensor) C- 003
U2144 CAN bus, no communication with ACC (adaptive cruise control) C- 003
U2145 CAN bus, no communication with PAS (Park Pilot) C- 003
U2146 CAN bus, no communication with SLM (driving stage / Fahrprogrammw?hlhebel) C- 003
U2147 CAN bus, no communication with AHS (Zuheizer) C- 003
U2149 CAN bus, no communication with TPMS (tire pressure monitoring system) C- 003
U2173 CAN bus, no communication with PEPS (Open & Start) C- 003
U2174 CAN bus, no communication with AHS (Zuheizer) C- 003
U2174 CAN bus, no communication with EHS (heating) C- 003
U2181 CAN bus, no communication with elektrohydraulischem hardtop C- 003
U2201 CAN bus, no communication with RQ (Entertainment Head Unit) C- 003
U2202 CAN bus, no communication with CDC (CD changer) C- 003
U2206 CAN bus, no communication with DIS (advertisement) C- 003
U2207 CAN bus, no communication with UHP (Univ. handsfree) C- 003
U2208 CAN bus, no communication with ECC (Electronic Climate) C- 003
U2213 CAN bus, no communication with DAB (Digital Audio Broadcast) C- 003
U2215 control device to replace C- 002
Dopřeloženo
Pro AKPP :
Například:
ECN
P1650 CAN chyba
P1651 CAN chyba
P1650 CAN error
P1651 CAN error
Opel Zafira y20dth
MB E 320 CDI W 211
MB S 320 CDI W 221 AMG
Opel Sintra x22dth - ex
Skoda 105 L -ex
nie som na fejsbúku
MB E 320 CDI W 211
Skoda 105 L -ex
nie som na fejsbúku
- franticek6
- Auto: Zafira A
Re: ODBII Error codes
http://obdii.pro/en/code" onclick="window.open(this.href);return false;
Opel Zafira y20dth
MB E 320 CDI W 211
Skoda 105 L -ex
nie som na fejsbúku
MB E 320 CDI W 211
Skoda 105 L -ex
nie som na fejsbúku
