DIAGNOSTIC REPORT:
OP-COM 100219a
hkj
**********************ECU ID STARTS**********************
Source Address: CIM
Source Address: 0x00000245
Identifier: 0x0015
VIN: W0L0ZCF6951040768
Part Number:13162134
Software version number: 12244872_
System description: DELPH0400
Hardware key number: *60FK3L
Alpha code:
Manufacturing date: 041008
Code Index and version: 008 02
Number of stored fault codes: 2
B1020 - SRS Steering Angle Sensor Signal Circuit Range/Performance
(0F) - Not present
U2160 - Steering Angle Sensor Communication Circuit Malfunction
(00) - Not present
**********************ECU ID ENDS**********************
Source Address: ECM
Source Address: 0x000007E0
Identifier: 0x0410
System name: Y20DTH
Hardware number:1401
Part Number:55352865
Software version number: VJAMS020_S
Hardware manufacturer number: 0470504223
System description: 1469946205C263_VB1
System description: BOSCH0100
Type approval number: B02008
Hardware key number: ˙˙˙˙˙˙˙˙˙˙
Programming Date: FFFFFFFF
System description: 0x00004019
Alpha code:
ECU variant coding: 0x0000F902
Number of stored fault codes: 1
P0070 - Ambient Air Temperature Sensor Malfunction
(71) - Not present
Source Address: ABS/TC/ESP
Source Address: 0x00000243
Identifier: 0x0301
System name: ESP EBC430
Hardware number:12801327
Part Number:13136694
Software version number: 00C3552E
System description: TRW 0300
Alpha code: EZ
U2143 - <Unknown DTC>
(71) - Not present
Source Address: EHPS
Source Address: 0x00000244
Identifier: 0x0104
System name: EHPS GEN3 TRW
Hardware number:24444336
Part Number:0
Software version number: V21_
Alpha code:
Code Index and version: 003 02
ECU variant coding: 0x00000105
U2139 - CAN-Bus No Communication with CIM (Steering Column Module)
(00) - Not present
U2139 - CAN-Bus CIM Message Range/Performance
(71) - Not present
Source Address: IPC
Source Address: 0x00000255
Identifier: 0x0102
Part Number:13186696
Software version number: 8.39 16/03
System description: VDO 0400
Hardware key number: 0000000000
Alpha code: EG
Manufacturing date: 041105
Code Index and version: 001 05
U2107 - Invalid Data from BCM (Body Control Module)
(71) - Present
Source Address: AIRBAG SDM
Source Address: 0x00000257
Identifier: 0x0101
Part Number:13170589
Software version number: 0C0C3303
Alpha code: DX
No fault codes stored.
Source Address: BCM
Source Address: 0x00000252
Identifier: 0x0109
Part Number:13199490
Software version number: C13C96 13041704
System description: TEMIC04
System description: 0x20202020202020303030373930313835
Alpha code: KH
Manufacturing date: 000401000202
B2996 - Rear Left Door Switch Circuit Open or High Voltage
(05) - Present
Source Address: REC
Source Address: 0x00000254
Identifier: 0x0104
System name: REC
Part Number:13189925
Software version number: 00000BBD
System description: LEAR 0400
Alpha code: EW
B3596 - Invalid Trouble Code Please Ignore!
(00) - Present
Source Address: UEC
Source Address: 0x00000253
Identifier: 0x0104
System name: UEC
Part Number:13187505
Software version number: 00000BBC
Alpha code: EJ
Number of stored fault codes: 3
B2585 - Front Left Parking Lamp Circuit Open
(04) - Not present
(00) - Present
B1375 - Switched System Voltage (Ignition ON) Circuit Malfunction
(00) - Not present
Source Address: DDM
Source Address: 0x00000259
Identifier: 0x0301
Part Number:13170178
Software version number: OP1D 190000
System description: SIEM 0401
Hardware key number: XXXXXXXXXX
Alpha code: EL
Manufacturing date: 310140
B2966 - Driver Doorknob Circuit Open or High Voltage
(05) - Present
Source Address: PDM
Source Address: 0x00000258
Identifier: 0x0301
Part Number:13170177
Alpha code: EN
Manufacturing date: 200140
Source Address: DIS
Source Address: 0x00000246
Identifier: 0x1201
System name: CID/GID Epsilon
Hardware number:13178572
Part Number:13178765
Software version number: GE55-/00050
System description: SIEM 0400
Alpha code: SD
Code Index and version: 002 01
Source Address: ECC
Source Address: 0x00000248
Identifier: 0x0201
System name: ECC 0620
Hardware number:13131021
Part Number:13138198
Software version number: C502 V40D201
Alpha code:
Code Index and version: 001 03
Užívatelia prezerajúci fórum: Žiadny registrovaný užívateľ nie je prítomný a 5 hostia
