Ahojte.
Potreboval by som poradiť ohladom mne nejasnej veci.
Mám vectru c 2004 1,6 16v 74kw
Auto asi po 10 minutach jazdy zhaslo.Keď som skušal štartovať tak samozreme nič.
Keď som ho nechal cca hodinku schladiť tak nakoplo ale len na 2min.Potom zase konec.
Dal som to na opcom a vytlačil chyby.Lenže neviem od čoho sa mám odpichnúť.Tolko chýb naraz.
Prikladám aj zoznam.
Bol by som rád keby niekto vedel ako mohlo vzniknúť tolko chýb naraz bez najmenšieho varovania.
Budem vdační za kazdú radu.
A ešte otázočka.
Moze kvoli CIM auto zdochnúť poprípade nenaštartovať?
U2108 - CAN-Bus No Communication with ABS (Anti-Lock Brake System)
(00) - Present
U2107 - CAN-Bus no Communication with BCM
(00) - Not present
P0230 - Fuel Pump Primary Circuit High
(05) - Not present
P0351 - Ignition Coil Cylinder 1 Circuit Malfunction
(00) - Not present
P0352 - Ignition Coil Cylinder 2 Circuit Malfunction
(00) - Not present
P0353 - Ignition Coil Cylinder 3 Circuit Malfunction
(00) - Not present
P0354 - Ignition Coil Cylinder 4 Circuit Malfunction
(00) - Not present
P0615 - Starter Relay Circuit Low Voltage
(06) - Present
P1481 - Fan Control 1 Circuit Low Voltage
(06) - Not present
P1482 - Fan Control 2 Circuit Low Voltage
(06) - Present
P1483 - Fan Control 3 Circuit Low Voltage
(06) - Not present
U2108 - CAN-Bus no Communication with ABS/TC
(70) - Present
P0500 - Vehicle Speed Signal Range/Performance
(71) - Present
B0550 - Mileage Circuit Range/Performance
(71) - Present
U2139 - CAN-Bus No Communication with CIM (Steering Column Module)
(00) - Not present
(00) - Not present
U2113 - CAN-Bus No Communication with SDM (Airbag)
(00) - Not present
U2139 - Invalid Signal from CIM (Steering Column Module)
(71) - Present
U2105 - CAN-Bus No Communication with ECM (Engine Control Module)
(7F) - Not present
(7F) - Present
U2111 - CAN-Bus No Communication With EHPS (Electro-Hydaulic-Power-Steering)
(7F) - Not present
B1480 - Inadvertent Load Circuit Low Voltage
(02) - Not present
B3901 - Wrong Environment Identifier Received
(00) - Not present
B2545 - Rear Left Reverse Light Circuit Open
(04) - Intermittent
B1330 - System Voltage Malfunction
(00) - Not present
(00) - Not present
(00) - Not present
B1325 - System Voltage Low Voltage
(03) - Not present
(00) - Not present
(03) - Not present
(00) - Not present
(00) - Not present
(00) - Not present
