Zdravim,
mam gts 3.2 v6. Ked autu dupem tak mi zacne blikat kontrolka motora vtedy auto akoby na moment stratio vykon a po chvili je vsetko ok a taha dalej v plnom vykone. Niekedy mi kontrolka ostane svietit a auto trasie a je v nudzovom rezime. Ked znova nastartujem je vsetko v poriadku. Vymenil som sviecky, predny zvod kedze kat bol zly. lambdy su nove, palivovy filter novy. Taktiez som vymenil zapalovaciu listu pre valce 1-3-5. Na opcom mi vyhodilo nasledujuce chyby:
P0170 - Fuel Trim Malfunction (Bank 1)
(15) - Present
P0141 - O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
(0D) - Not present
P0135 - O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
(0D) - Not present
P0130 - O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
(02) - Not present
P0130 - O2 Sensor Circuit Range/Performance (Bank 1 Sensor 1)
(04) - Not present
P0130 - O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
(08) - Not present
P0300 - Random/Multiple Cylinder Misfire Detected
(01) - Not present
P0301 - Cylinder 1 Misfire Detected
(01) - Not present
P0303 - Cylinder 3 Misfire Detected
(01) - Not present
P0305 - Cylinder 5 Misfire Detected
(01) - Not present
Vedel by mi niekto poradit kde by mohol byt pes zakopany a co treba este vymenit? Dakujem
